Weekend Mods: Winch & License Plate Relocation - JeepForum.com
post #1 of 15 Old 03-13-2010, 03:00 PM Thread Starter
DeepSky
Had a great Friday-Saturday finishing up installing some stuff on the Jeep and figured I'd share.
First was the license plate relocation. I used the "universal" bracket from Rock Hard 4x4. Despite its universality I still had to cut sections of the metal base around the lower mount holes to get it to line up with my tire carrier's lugs.
Instead of spending $40 bucks for their PlateLITE led illumination kit I went to WalMart and got a universal light for $4 bucks: Light After removing the bulb it came with I made some small cuts on the inside of it and was able to fit the factory bulb and base inside the housing. I then sanded and bedlined it.
Then I moved onto the winch. I couldn't believe how simple it was to install. Of all of the mods I've done and broken parts I've replaced this was probably in the top three as far as ease and time it took.
The most time consuming part was wrapping the 2ga wires in the conduit and taping the wires together as they come out of the winch. Haven't had a chance to try it out yet actually pulling something but I definitely have the itch too.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #2 of 15 Old 03-13-2010, 03:24 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
cool.
where did you get the plastic cover thing that covers the hole where the old license plate bracket was?
-Matt
mattman8706 is offline
post #3 of 15 Old 03-13-2010, 03:29 PM
dvdsjk
dvdsjk's Avatar
WOW! Nice job. I want to do the same thing with my plate and even maybe relocate the third brake light.
dvdsjk is offline
post #4 of 15 Old 03-13-2010, 03:38 PM
dvdsjk
dvdsjk's Avatar
Question, you have a sticker or reflector next to the mopar liscence plate delete blank. Is that another hole you had to cover or just decoration.
dvdsjk is offline
post #5 of 15 Old 03-13-2010, 04:02 PM
ribs
Looks great. What is the red part on the winch line?
Originally Posted by notoriousdoa View Post
we had a peep hole looking into the girls jeep forum, but someone used it as a glory hole so they patched it up.
Originally Posted by LarryGrant View Post
...And no the truck dont give BJs but guess you are not married as wifes dont give them either. :rolleyes:
ribs is offline
post #6 of 15 Old 03-13-2010, 04:52 PM Thread Starter
DeepSky
Originally Posted by mattman8706 View Post
cool.
DANJEEPO8 pointed me to this page on JustForJeeps.com: Rear License Plate Deletion Panel
Ugh...well, yeah it is to cover some holes but no ones that are there from the factory. The only holes normally left after removing the license plate bracket are the one you fill with the Mopar plug, and the two screw holes at the bottom.
It indicates the last 10ft of wire rope at this end. It's also color coded in the same manner at the other end.
DeepSky is offline
post #7 of 15 Old 03-13-2010, 05:00 PM
4x4jkx
Is you're stock license plate holder still in one piece? Can I have it if it is?
4x4jkx is offline
post #8 of 15 Old 03-13-2010, 07:27 PM
Grant211
bada$$... i really like the front bumper
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #9 of 15 Old 03-13-2010, 08:23 PM
TRPLXL2
Wow your JEEP is awesome, and I love the Mickey Thompson tires! I have a couple newbie questions for you.
1. Did you have to upgrade the alternator to run the winch?
2. Are you running dual batteries?
Thanks for any info you can give, this is all new to me except the wiring part.
TRPLXL2 is offline
post #10 of 15 Old 03-14-2010, 05:17 AM
richnev
2014 JK Wrangler
love the license plate relocation bracket, but just one question how does it attach? is there another peice that goes behind the wheel?
05 Jeep Wrangler X .... RIP
07 Jeep Wrangler Unlimited X ...... let the build begin
ARMY TEAM MEMBER #4
Originally Posted by ge2 View Post
I just make a BOOP BEEP sound with my mouth (really loud) as I walk away from the jeep, and point the key at it.
Originally Posted by her94yj View Post
lets put it a way a kids will relate......its like a hooker.......... SURE a 15 dollar handy from a detroit toothless 60 year old can get it done....... but NO where is it as nice as the $5000 an hour goddess from vegas or hollywood
....... dont be that fat guy on the beach in the speedo you dont want to be "that guy"
richnev is offline
post #11 of 15 Old 03-14-2010, 07:59 AM Thread Starter
DeepSky
Thanks for the compliments To answer your question:
1. Nope. Superwinch only recommends a 60A alternator for this winch and the factory is 160A.
2. Also no, although I wouldn't mind doing that. The factory battery is kind of crappy, I think eventually I'll replace it with a single Optima yellow top.
Yup, theres a mount that goes between the tire carrier and the wheel. Looks like this:
DeepSky is offline
post #12 of 15 Old 03-14-2010, 08:28 AM
ge2
Gold Member
ge2's Avatar
Love it! The plate relocation is something I've really been interested in. Running the wire for the light is what's holding me back. Tell us about that part. Simple?
ge2 is offline
post #13 of 15 Old 03-14-2010, 09:34 AM Thread Starter
DeepSky
It wasn't bad at all actually. Just had to peel back the carpet at the upper tub corner and pull the wires & connector through the plug there then splice in some wire and run across the back of the tub. I tucked the wire under the weather stripping at the bottom of the tub. After that I just ran it out through the conduit I was already using for the third brake light.
DeepSky is offline
post #14 of 15 Old 03-15-2010, 01:00 PM Thread Starter
DeepSky
PM sent back.
DeepSky is offline
post #15 of 15 Old 03-15-2010, 01:48 PM
ge2
Gold Member
ge2's Avatar
Thanks for the info! It looks awesome.
ge2 is offline
License Plate Relocation elkfan2 TJ Wrangler Technical Forum 6 12-08-2007 10:07 PM
License Plate Relocation Jeeper4ever TJ Wrangler Technical Forum 3 11-25-2006 10:05 PM
License plate relocation bracket MayorMcCheese YJ Wrangler Technical Forum 3 07-03-2006 08:52 AM
License plate relocation project Roach YJ Wrangler Technical Forum 11 01-06-2006 01:03 PM
License plate relocation , need pics jruba YJ Wrangler Technical Forum 8 10-20-2005 12:36 PM
