Ways to improve driving stability of lifted Jeep - JeepForum.com
post #1 of 15 Old 01-23-2012, 06:29 AM Thread Starter
Hambergler
Hi Guys,
Just bought my second Wrangler ('07 JK 4DR) a month ago. Got it with a 4"inch lift already on to save some labor money. As a result I don't know what the manufacturer is or what all the kit included since I'm not real knowledgeable about lifts.
I put a 2 inch on my old TJ and noticed a reduction in stability on the highway (as expected). But the 4 inch on the 4 door has caused random fits of instability above 50mph. I wanted to know if there is a way to create more stability at speed. I don't think it's what people are describing as the death wobble-more of lateral movement at speed. I know you can't change the dirty air or bad aerodynamics so please don't say "get another vehicle", "take off the lift" or something similar. I know there is a ton you can do to improve suspension performance with many cars so I was wondering if anybody has found an effective upgrade for lifted jeeps.
Thanks guys.
2007 Jeep Wrangler Unlimited
Black on Black
4" Lift 35" M/Ts
Hambergler is offline
post #2 of 15 Old 01-23-2012, 06:32 AM
Irongrave
really need to know what brand it is and what type of shocks and tires your running. photos work well for that.
Current
2002 WJ 2wd DD
Irongrave is offline
post #3 of 15 Old 01-23-2012, 06:59 AM
KPJ
2010 JK Wrangler
How is caster corrected by your suspension? Adjustable upper or lower front control arms? AEV or some other brackets? Not at all?
Have you been to an alignment shop to get your alignment numbers? Flighty steering is a symptom of insufficient caster angle.
Also, are your axles centered on the Jeep? Do you have adjustable trackbars or relocation brackets either frame or axle side to center the axles? You can check for centered axles by looking at the tire/fender relationship on each side at each axle. If the tires stick out further on one side while the Jeep is at rest the axles aren't centered. (Unlikely, but it could be that an adjustable track bar has been set too lng too.)
My bet is that its an incomplete lift that doesn't properly resolve caster angle issues and/or doesn't center the axles.
Check out the Jeep and answer the questions and you will be providing answers to Q's that are needed to help further diagnose your issues.
JPK
KPJ is offline
post #4 of 15 Old 01-23-2012, 07:14 AM
Joevacs
2010 JK Wrangler
I would take it to an experienced shop that lifts and modifies Jeeps. Let them see what needs to be adjusted or replaced. A 4" lift on a JK shouldn't alter performance or drivability.
and btw WELCOME TO THE FORUM
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #5 of 15 Old 01-23-2012, 07:23 AM
jstrubberg
2009 JK Wrangler
On my rig, lifting reduced the caster angle to the point the thing flitted all over the road. I had the adujstable cam bolts instaleld and teh caster angle brought back to fiveish degrees, and it much, much more stable now.
I'm told this makes low speed steering more difficult, but with power steering, I just really don't care.
jstrubberg is offline
post #6 of 15 Old 01-23-2012, 07:34 AM
182329
2009 JK Wrangler
As a previous post said, you probably need adjustable control arms. Anytime you add a lift, it throws off the suspension geometry, which could cause the exact problem you are describing.
I would start with purchasing the adjustable lower control arms,and go from there.
182329 is offline
post #7 of 15 Old 01-23-2012, 07:40 AM
Imped
Imped's Avatar
Proper caster and toe, appropriate track width for the height, properly setup tight suspension and steering with no play, sway bars on both ends.
OlllllllO
IndyORV
Imped is offline
post #8 of 15 Old 01-23-2012, 08:03 AM
MTBryan
Originally Posted by Hambergler
Hi Guys,
Thanks guys.
Yes, adjustable front control arms to fix your castor is the answer. Also reduce the air pressure in your tires.
I bought my '07 with a 4 inch lift in Georgia and it was so scary on the highway, I took back roads all the way back to Nashville.
I aired down my 35's to 26 psi and that helped some. I then put adjustable uppers and that helped immensely. I just got done putting on adjustable lowers and it is even better.
If I had to do it over again, I would probably get fixed lowers that are about 1/2 inch longer than stock, then the adjustable uppers. That would have accomplished the same thing but would have saved me some bucks.
MTBryan is offline
post #9 of 15 Old 01-23-2012, 10:03 AM
KPJ
2010 JK Wrangler
Before committing to adjustable control arms, which are pricy, take a look at AEV's front control arm brackets, which run $100 the pair and which will probably save your front drive shaft, as well as reduce break dive and body roll.
JPK
KPJ is offline
post #10 of 15 Old 01-23-2012, 10:10 AM
Vince1
2010 JK Wrangler
You likely need a high steer kit to correct the front geometry. Post a photo of drag link, track bar, etc...
Vince1 is offline
post #11 of 15 Old 01-23-2012, 10:12 AM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
X2 - Nail on the head. Let's get this before throwing out random solutions like adjustable CA's and drop brackets.
PhatBasturd is offline
post #12 of 15 Old 01-23-2012, 03:13 PM
Jowlz
If you can't find someone to tell you what the lift is, I would at least take it for an alignment before you start throwing parts at it....
Jowlz is offline
post #13 of 15 Old 01-23-2012, 09:44 PM
Rudinater
2009 JK Wrangler
Just a FYI, I have a 4inch long arm lift with 37inch tires. I cruise at 80+ on the freeway and it's very stable. It also handles very well in the turns as well.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #14 of 15 Old 01-23-2012, 09:48 PM
ytowntj
Yes. Good shocks as well.
I'd be willing to bet that my TJ handles better than a stock jeep off the showroom floor by a good bit.
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #15 of 15 Old 01-24-2012, 03:07 AM
SubAtomicGenius
2011 JK Wrangler
I believe that I've got 5-to-6-degree caster on my stock front axle with my 3" TeraFlex lift (TeraFlex designates length measurements for upper/lower control arms, thus automatically setting caster). With wheel centered and proper toe-in she drives perfect up to 80mph (130km/h - I rarely drive that speed and I don't drive faster that that). I have the full-flexarm lift kit and she drives like a dream, pretty sure that the adjustable control arms is key.
SubAtomicGenius is offline
Driving LONG distances in a lifted Jeep??? tkatc TJ Wrangler Technical Forum 18 02-26-2011 08:42 PM
sure ways to improve MPG cp10goat71 TJ Wrangler Technical Forum 23 02-26-2011 05:26 AM
Looking for suggestions to improve lifted '89 YJ ride quality KennedyYJ YJ Wrangler Technical Forum 9 04-06-2010 12:30 PM
Ways to improve the JK IWantAGladiator JK Wrangler Technical Forum 45 08-20-2009 10:06 AM
Ways (replacements) to improve mileage.... Alheim YJ Wrangler Technical Forum 4 05-27-2002 04:28 PM
