Water Pump help - JeepForum.com
post #1 of 4 Old 10-02-2013, 08:48 AM Thread Starter
darrin823
Water Pump help
I am new to the Jeep world and I have a 2007 Wrangler. It appears my water pump is leaking and I am planning on replacing it myself. When i search online for the part it tells me I should replace the fan clutch at the same time. I am not sure this is neccesary as it looks like I have an electric fan. Any thoughts would be great. Thanks.
darrin823 is offline
post #2 of 4 Old 10-02-2013, 10:11 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
JK has no fan clutch, try a better online site...also, there was a thread here earlier this year on a water pump replacement, might try a forum search.
Ohhhh, and welcome to the JK forum.
edit: try this link: http://www.jkfreaks.com/forums/showt...ular-demand%29
note that torque is given in inch-lbs....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 10-02-2013, 11:07 AM Thread Starter
darrin823
Thanks for the reply. I didn't think it had a fan clutch but when I looked at Autozone and O'Reilly auto parts they both said to replace the the fan clutch. thanks fo the help.
post #4 of 4 Old 10-02-2013, 01:52 PM
JIMBOX
If you're getting an aftermkt pump, check with FEL Pro for special JK water pump gasket--it has an integral HiTemp (O) ring imbedded on the block side of the gasket-
Can't tell you the Pt#--I'm in Minnesota at the moment-
I got my Water pump/gasket from NAPA auto pts-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
