Water pump 2013 JKU - JeepForum.com
post #1 of 34 Old 09-10-2013, 07:06 PM Thread Starter
Wrigley
Water pump 2013 JKU
2013 JKU Sahara with 8220 miles on it. The water pump is singing like a bird. Took it into the dealership today. YES......it's your water pump and they are 4 to 6 weeks back ordered.
What they told me next is what I am having a problem with. They said: "The water pump is mechanically sound and functioning properly. It is making the squealing sound because the clearance between the shaft and the bearing it rides in is too close which causes the noise".
I then asked them: "If the water pump is functioning properly, why is Jeep agreeing to change them simply because of the squealing noise"?
He just looked me with a blank stare on his face and couldn't answer my question.
So......does anyone know if there is in fact a mechanical problem with these water pumps or is it just a tight bearing around the shaft?
Thanks
Mike
Wrigley is offline
post #2 of 34 Old 09-10-2013, 07:15 PM
awinski
Thanks
Mike
Depending on where you were yiu may have been talking to a sales rep, customer service etc. Sometimes they know what they're talking about and sometimes they dont, remember these arent techs. They read off the work order and what the tech tells them, so if they miss read or the ibfo wasnt clear its easy to mix it up.
Just my theory
Theres tons of threads here and other places about water pump, alternator, and tensioner bearings going bad with nothibg more than a trip to the beach. Some times youll make it through the deepeat pit and nothing happens to the bearings, then sometimes you drive through a coastal town a mile from the beach and sand manages to make its way in there. My guess is there's debris somewhere in the bearing. But a tight clearance is possible
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #3 of 34 Old 09-11-2013, 12:47 AM
suicideking
It's still functioning and doing what it should do, so no emergency. They're replacing it because it's just DAMN ANNOYING and they know people won't put up with that BS.
I had mine replaced at around 10K miles.
suicideking is offline
post #4 of 34 Old 09-11-2013, 05:03 AM Thread Starter
Wrigley
http://www.youtube.com/watch?v=f6Fg6eqioxY
Mine isn't making as much noise as yours is in the video you provided. Actually, you can't even hear it if you are sitting inside the Jeep. You have to be standing outside in front of the Jeep when it is running and it doesn't always make the noise.
Is there a technical bulletin or any other correspondance from Chrysler concerning this issue that you know of?
Thanks
Mike
Wrigley is offline
post #5 of 34 Old 09-11-2013, 07:33 AM
rock-rocker
I had mine replaced at around 1700 miles. Mechanic said the pump works fine just noisey. Why should we spend as much as we do to drive a vehicle that squeals?? I hope they keep replaceing them as needed...
BTCS, USN, Retired
2013 Jeep JKU Rubicon 10th Year Anniversary.
rock-rocker is offline
post #6 of 34 Old 09-11-2013, 09:22 AM Thread Starter
Wrigley
Auto manufacturers would be replacing a whole lot of parts during the warranty period if the "it makes noise now but didn't when I bought it" theory applied. There must be some underlying mechanical issue with these water pumps that warrants them to be changed.
Mike
Wrigley is offline
post #7 of 34 Old 09-11-2013, 07:07 PM
rock-rocker
Wrigley, So if I understand you right you feel that just because it makes noise it's okay? Buy a new car and just because it squeals it's okay just wait until it breaks? You work for a Dealership or something? I'm sorry, if I buy a $50k vehicle your damn right I'm going to bring it back for noise, rattles and squeaks and I'd expect you to fix it otherwise I'd go on a mission to let people know what kind of product your selling the people and if this is what you are selling the price better be allot cheaper...
BTCS, USN, Retired
post #8 of 34 Old 09-11-2013, 07:25 PM
Remmy18
He was probably staring at you in disbelief as if to say "man, I can't win. This guy comes in here with a problem, we're fixing it and he's still giving me a hard time."
Remmy18 is offline
post #9 of 34 Old 09-11-2013, 07:26 PM
suicideking
Thanks
Mike
Mine started out occasional to the point where I couldn't get it to act up when I took it to the dealer. One time during my lunch hour it was making the noise so I raced to the dealer so they could finally hear the noise. Apparently it was their lunch hour too, they didn't have anyone available to look at it. I showed a mechanic the video above, he still claimed he couldn't do anything unless he was able to re-produce the noise.
It started out not as loud, probably what you hear. After about 3 months, the noise was almost constant and as loud as in the video.
Amen brother! If it's less than a year old, it shouldn't be making annoying noises unless they are a result of me banging it on a rock!
post #10 of 34 Old 09-12-2013, 06:40 AM Thread Starter
Wrigley
I wasn't giving anyone a hard time. I asked the service advisor the same question I am asking here. "Is there an underlying "mechanical issue" with the water pumps, or is Chrysler simply agreeing to change them because SOME of them make noise?"
He went and got a mechanic and the mechanic came out to the Jeep. The Jeep WAS NOT running and the mechanic told the service advisor to order a water pump for my wifes Jeep and they would call me and set up an appointment to change it when they received the pump. The mechanic NEVER asked me to start the Jeep to listen to the water pump. I found that rather odd!!!
My 2013 Sport has 15,000 miles on it and my water pump doesn't make a sound. Does that mean it doesn't need to be changed? Is Chrysler not telling us everything? If there is an underlying mechanical issue with these water pumps I want mine changed regardless if it makes a squealing noise or not!
Mike
Wrigley is offline
post #11 of 34 Old 09-12-2013, 06:57 AM
Remmy18
Mike
I believe you're over thinking it. The water pump is a known issue and when they make noise, they're replaced. If your 2013 is not making noise or overheating, it's fine. I had mine replaced at 13000 miles. If it starts to make noise or run hot, take it in. I don't think there's a conspiracy going on.
Remmy18 is offline
post #12 of 34 Old 09-12-2013, 07:28 AM
rock-rocker
x2 on what Remmy said. If it's not making any kind of noise then don't worry about it. That's what is great about these Forum's. It gives you an idea what to look, listen and feel for with your rig but don't get too anul. It just may not happen to you but if it does you can pretty much be able to diagnose it and identify the problem yourself so that if you take it to the shop they can't blow smoke up your ***. Not only that but it also helps me to know the severity of the problem which helps me to decide the urgency.
BTCS, USN, Retired
post #13 of 34 Old 09-12-2013, 07:50 AM
roughandtangle
I have 4500 miles on mine and it started making this noise occasionally after 2000 and is now constant. I set up an appointment with the dealer so i am hoping that they work with me on this.
There is nothing good in anyone's signature. Especially mine.
roughandtangle is offline
post #14 of 34 Old 09-13-2013, 08:58 PM
roadrunner58
My 2013 has 2,400 miles and I noticed the water pump noise two days ago. The noise comes and goes at a idle when the engine is hot. I have a appointment with the dealer tomorrow morning. I hope it makes the noise, so that the dealer will order a new water pump for my Jeep.
roadrunner58 is offline
post #15 of 34 Old 09-14-2013, 08:56 AM
fitzz47
I own 2, 2013 wranglers, both had to have pumps changed,half day job, dealer sent me on my way no problems.
2015 GC Attitude Black
2015 Wrangler Sahara Hydro Blue
fitzz47 is offline
