Water, Mud leads to all sorts of crap - JeepForum.com
post #1 of 23 Old 06-04-2013, 12:27 PM Thread Starter
Lito
Had a much longer day than anticipated out in the boonies with a buddy (and the impending father in law).... and managed to get home. Mud holes deep enough to have the engine fan chopping hard in the water, lots of water leaked past the door seals, blew tyre off the rim, that sort of thing.
2012 Rubi, auto, all the (standard Jeep) trimmings.
Problems:
a) Something near the alternator whines. Rev the engine, it whines. Something definitely wrong.
b) Intermittent power steering assist. Mostly gone. Heavy as a mofo to turn without the power steering assist.
c) Internal fan/aircon unit - intermittent action too. Seems to work now that its been drying for two days - but half the power it used to work at.
d) Sometimes the engine doesnt start. No starter action, despite all the internal lights working and no warning signs. Switch off, retry - then engine starts as normal (with engine whine)
As mentioned, she's drying out in the sun (plus vacuumed out water internally) and looks like I will strip her as far as is necessary to get her back to perfect shape. Idled her in the sun today for half an hour, lots of steam coming from rad area, enough to keep the alternator steamed up in wafts during that period.
Will do the oil change and will do a diff oil change too. She's only 8000 miles old.
Any pointers/ advice for the four main issues? I'd appreciate that very much.
Lito is offline
post #2 of 23 Old 06-04-2013, 12:42 PM
Jeffro06
Jeffro06's Avatar
Stay out of deep water/mud.
Sounds like the alternator may have gotten wet, which could squealing, but that'd be easy to tell. You can always put a screwdriver tip on what you think may be squealing and place your ear on the handle, you'll know....it works like a stethoscope (that works better if you have one).
Check all you electrical contacts, you may have mud interfering with them.
You belt may be slipping too.
Jeffro06 is offline
post #3 of 23 Old 06-04-2013, 12:58 PM Thread Starter
Lito
Will do the makeshift stethoscope method, I like that sort of thing.
Just came back from the vehicle - fans worked for around a minute - now dead. When I adjust climate control/ manual control, I can hear whirring as it tries to direct air - but def no fan action.
Power steering dead for sure.
When I put it in neutral, and I floor it - it will spin up to 4050 rpm odd, and thats it. Not sure if thats a protection mechanism, but seems... wrong.
I should have mentioned that I also powerwashed her hard and got all the mud out. Theres likely 1-2% mud left if that...
Lito is offline
post #4 of 23 Old 06-04-2013, 01:06 PM
Jeffro06
Jeffro06's Avatar
Hopefully you don't have water in your intake. Is your air filter good and dry?
Jeffro06 is offline
post #5 of 23 Old 06-04-2013, 01:49 PM
JTPhoto
JTPhoto's Avatar
Sounds like the power steering pump is fried. Thats the wine you hear upfront below the alternator. Must have taken in a fair bit of water/mud. If you are lucky you may be able to drain and add some fresh power steering fluid. Hopefully the steering box can be flushed as well.. Good LUCK!
I have a quad to play in mud. Play for 10min in the Jeep and it takes 3 days to clean everything out. It is fun though for that 10 min.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #6 of 23 Old 06-04-2013, 05:48 PM Thread Starter
Lito
Thanks gents - question: where do I find a manual/ parts disassembly manual on the web? I'm keen to go through all the connectors and clean them out
Jeffro - the air filter has mud residue on it, and its damp. But its not dead awful by any means. Just a drop or two of water in the airbox, although the butterfly intake had dirt residue around it. Cleaned that of course.
Lito is offline
post #7 of 23 Old 06-04-2013, 06:47 PM
Jeffro06
Jeffro06's Avatar
A wet air filter is no bueno. Hopefully you didn't get water in the engine.
Jeffro06 is offline
post #8 of 23 Old 06-04-2013, 09:25 PM
taoshum
This one didn't have a snorkel either.... water locked the engine...3 weeks to replace it
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
post #9 of 23 Old 06-05-2013, 07:17 AM
Noxian
2011 JK Wrangler
Stock intake or cold air?
Noxian is offline
post #10 of 23 Old 06-05-2013, 07:39 AM Thread Starter
Lito
That water pic is minute compared to what we went through. Worse off, we had no choice but to do it or else the vehicles would still be there.
Having said that, I think I am going to be ok with the engine - at present.
Removed the horn, because that sounded like a farting mouse, cleaned and lubed it - now it sounds normal again.
Removing the seats and carpets to remove all the mud inside the vehicle.
Removed the fan system and will continue to nurse that. - edit: fixed now. lots of gunk inside, and its attendant parts.
Bigger question is: is there a pdf or some resource on the web for a schematic of the JK? (I'm not finding one using the googlemacheeen)
Lito is offline
post #11 of 23 Old 06-05-2013, 04:37 PM
taoshum
stock. he was probably going about 45-50 mph when he hit the water which was about 3' deep...
Geezer from NM
taoshum is offline
post #12 of 23 Old 06-05-2013, 04:44 PM
taoshum
You got out without a blown engine under your own power, we had to tow him out, the engine was locked up tight. Next time take some pics! Glad you got home OK.
Geezer from NM
taoshum is offline
post #13 of 23 Old 06-05-2013, 09:53 PM
trw
2011 JK Wrangler
I learned the hard way on my YJ that mud sucks and destroys everything.
I keep my JK out of the mud as much as possible now.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #14 of 23 Old 06-06-2013, 12:20 AM
smcutter
I have not been able to find one. Certainly not for the 2012+ Pentastar motor.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #15 of 23 Old 06-06-2013, 06:47 AM Thread Starter
Lito
Taoshum, thanks mate. We made it home alright - even managed to have heated seats on (it was colddd). One of the few things still working. I got some pics and vid of my buddy who was in a LR Disco with a 3inch lift kit (etc). I had to run and jump on the side of his vehicle at one stage to stop him from tipping over onto his side. Pretty close. Happened to each of our vehicles around three seperate times. It was a very eventful day.
TRW - no kidding. I didnt mention that all our nicely cared for rims are now heavily scratched, and I broke the front air dam and rear bumper off. Windows are scraped up badly from the little rocks sticking to the glass. It got so bad that I had to open the door to do reverse moves/ backups which just led to more mud getting inside the vehicle (and yes, I used two bathroom sized towels to clean the windows as often as I could).
Thanks SMCutter. Pretty frustrating, but I'll be sure to add it here if I find it.
edit: ps: carpets are out, washed up (were starting to reek), and today I'll see the tub bare and spotless, all electrical connections cleaned and lubed up. Aircon is now working 100%, and next up is rear bumper/ front air dam repairs (and clean the blown tyre rim from the 20 pounds of mud still inside the tyre mounted on it...)
Lito is offline
