Water drips when door opens, any suggestions? - JeepForum.com
post #1 of 20 Old 09-19-2010, 01:39 PM Thread Starter
Mala
2009 JK Wrangler
Hey all! I have had the problem (and I can see so have others) with water dripping into my interior when I open either front doors. It seems the drain channels on top stop just short of the windshield so it makes it pretty annoying when getting into or out of the jeep when it has rained. I know this isn't a huge deal just wondering if anyone has found a solution to it, thanks!
2009 Rubicon
4 Door Hardtop
Mala is offline
post #2 of 20 Old 09-19-2010, 01:42 PM
Slenny
I rock the Jeep before I get in. Never been an issue getting out of the Jeep unless I been sitting in it parked while it was raining.
Slenny is offline
post #3 of 20 Old 09-19-2010, 01:44 PM Thread Starter
Mala
2009 JK Wrangler
It happens when its raining mostly, and after I have washed the car. Doesn't seem to be much of a problem when it's been sitting idle for a while once the rain has let up
Mala is offline
post #4 of 20 Old 09-19-2010, 02:45 PM
ls6tt
2010 JK Wrangler
carry a towel. nothing seems to fix it, and it annoys me. but the spot under neath the driver seat is prime for a big towel
ls6tt is offline
post #5 of 20 Old 09-19-2010, 02:48 PM
krutj
2009 JK Wrangler
It's just water, put a rag in the side pocket..........
Come on....
-- Joel --
krutj is offline
post #6 of 20 Old 09-19-2010, 03:02 PM
tclaremont
2014 JK Wrangler
Put a dab of RTV at the front of the water channel.
Tim C.
Rochester, NY
tclaremont is offline
post #7 of 20 Old 09-19-2010, 04:51 PM
jeepcache
2010 JK Wrangler
Come on....
bwahahaha i sat there and stared at your smilie for the whole thing
jeepcache is offline
post #8 of 20 Old 09-19-2010, 04:53 PM
TheDustMan
Mine does it too, especially when it rains hard. Not alot you can do about it. If I could find exactly where it was leaking from, I would do as tclaremont said and run a bead of RTV over it.
TheDustMan is offline
post #9 of 20 Old 09-19-2010, 05:08 PM
krutj
2009 JK Wrangler
Ain't that funny? Didn't want to be too harsh..lol
-- Joel --
krutj is offline
post #10 of 20 Old 09-19-2010, 05:58 PM
bigredisb
1979 CJ7
I just waxed the the drip rails and top and have had a lot less water since it runs right off. Even after a hard rain the top is mostly dry.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #11 of 20 Old 09-19-2010, 06:26 PM
IWantAGladiator
IWantAGladiator's Avatar
I posted a solution for this about 6 months ago, add about 1/2"-1" of rtv (silicone) at the very front of the drip channel. this won't eliminate the drip as much as it will let the channel hold more water. simplest thing to do after rtv'ing is to run your finger in the channel to push the water out before you get in.
if you aren't happy with this fix, jump in a buddy's cj with a hardtop during a rain. you won't complain about the jk roof again.
IWantAGladiator is offline
post #12 of 20 Old 09-19-2010, 08:00 PM
bigredisb
1979 CJ7
Thats why I gave up on my CJ's hardtop. Its like a wet dog shaking inside the whole time your driving with completely fogged up windows. Of course the previous owner had hacked in a sunroof which was the majority of the problem.
A buddy of mine with leveling kit on his JK does not have as much of an issue maybe because the factory rake causes water to run towards the front. Maybe I can use this to leverage some slush fund money for a lift on my JK!
post #13 of 20 Old 09-20-2010, 07:16 AM Thread Starter
Mala
2009 JK Wrangler
Yep, that's what I have done from the beginning. Just started carrying spare towels in the back, thanks
Mala is offline
post #14 of 20 Old 09-20-2010, 07:21 AM Thread Starter
Mala
2009 JK Wrangler
Thanks a ton for the advice, I will definitely be adding rtv to the channel. I know people just said "carry a towel". But when its down pouring and I'm getting a water fall inside when I open the door it can get a tad annoying. Thanks for helping instead of making fun.
Mala is offline
post #15 of 20 Old 09-20-2010, 07:22 AM Thread Starter
Mala
2009 JK Wrangler
Come on....
Great advice. Thanks.
Mala is offline
Onboard Water - Any Suggestions? sinjin313 JK Wrangler Technical Forum 17 04-07-2010 02:40 PM
Snapped bolt, door opens way too far now PDX_XJ TJ Wrangler Technical Forum 2 05-27-2009 03:14 PM
TJ Driver door only opens from the inside... Moose-A-Fis TJ Wrangler Technical Forum 2 04-22-2009 02:39 PM
Door opens on it's own while driving ZeroGravity YJ Wrangler Technical Forum 29 02-07-2009 08:37 AM
How much water drips when you're running your a/c? jeeptrix TJ Wrangler Technical Forum 28 08-29-2007 05:28 PM
