warped pressure plate? Failing clutch system on a stock 2013, Need Help... - JeepForum.com
post #1 of 9 Old 10-18-2013, 08:55 AM Thread Starter
LTGreek
At six thousand miles I had to replace my flywheel, clutch, starter, battery, and all the in between parts. Six thousand miles later, I had to replace the clutch kit-Pressure Pate, lever, bearing, spring and gasket maker. The dealership said that the fingers on the pressure plate were warped. I donít understand how that is possible in a jeep that was brand new in May.
Right now I am building a cases, and I need some technical advice. Is it possible to that the last dealership did a bad job and caused all those parts to fail? Is this going to happen again in six thousand miles?
LTGreek is offline
post #2 of 9 Old 10-18-2013, 09:06 AM
222Doc
222Doc's Avatar
well since I do not see 10 of thousands of people with this complaint. no you should not be replacing this every 6k. you are letting the clutch break in?
222Doc is online now
post #3 of 9 Old 10-18-2013, 09:07 AM
73azbronco
Clutch break-in?
73azbronco is offline
post #4 of 9 Old 10-18-2013, 09:11 AM Thread Starter
LTGreek
Yes, I have been. This is not my first manual vehicle. I had a 2005 six speed TJ, that was lifted with 33 and I had no issues.
LTGreek is offline
post #5 of 9 Old 10-18-2013, 09:12 AM Thread Starter
LTGreek
but a warped pressure plat? that is where things are getting ridiculous.
LTGreek is offline
post #6 of 9 Old 10-18-2013, 09:13 AM Thread Starter
LTGreek
the last time I had work done, I didn't replace the clutch. the clutch has 10,000 miles on it and looked brand new.
LTGreek is offline
post #7 of 9 Old 10-18-2013, 12:44 PM
222Doc
222Doc's Avatar
No offense just asking. Many people today do not know these things.
But again reading this forum for a few years this seems out of normal poor quality. But I think this is more the mechanic that has fubared.
Me if I put in a clutch no matter what its in. I would not put a new clutch pack against a fly wheel that has been used unless its been refaced. Its just not worth the time to skip anything. with out seeing the parts no one here will know.
dealers are hit and miss. I just had the local here do a left head replacement. So far seems the mechanic got all the bolts back were they belong.........
post #8 of 9 Old 10-18-2013, 01:23 PM Thread Starter
LTGreek
I'm sorry, I didn't mean to sound aggressive
LTGreek is offline
post #9 of 9 Old 10-18-2013, 01:29 PM Thread Starter
LTGreek
I am very sensitive about my clutch. I don't even like down shifting on the highway :-\
LTGreek is offline
assistance , chrysler , clutch , mopar
