Warning on Bestop Wraparound Windjammer and Soundbar Cap - JeepForum.com
post #1 of 117 Old 08-02-2010, 05:06 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Just to give you guys the heads up, I purchased the whole works. Bikini windjammer etc. Went to install the wraparound windjammer and mate it to the soundbar cap (a reguired part) and found opposing j channels. 4wd hardware was absolutely no help at all , to the point of rudeness as always, so I called bestop. Apparently the soundbar caps, they feel, were shipped out with the J-channel sewn on backwards. I went to a store locally and tried two, then went to call 4wd hardware and the ignorant chick said theres faces the same way. She told me to flip it around . Bestop is getting back to me tommorrow and I will let you know how widespread it is.
dvdsjk is offline
post #2 of 117 Old 08-02-2010, 06:05 PM
krutj
2009 JK Wrangler
Wow, JK's are going into the 5th year of production and still having issues.(Bestop)
Seems like last month it was the trek top.
Guess 4wd won't be getting any more of your $$$
Hope you get it worked out!
-- Joel --
krutj is offline
post #3 of 117 Old 08-02-2010, 06:11 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Bestop seems to want to help.But theres no excuse for the issues. As for 4wd, there customer service sucks royally but there sales are to good to pass up. Sort of a damned if you do or dont situation.
dvdsjk is offline
post #4 of 117 Old 08-03-2010, 07:50 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Little update,Bestop is full of sh*t. Customer service never called back as promised on there junk! Talk about a business that goes backwards instead of ahead in todays economy.
dvdsjk is offline
post #5 of 117 Old 08-03-2010, 07:55 PM
BinaryPie
2010 JK Wrangler
I was going to buy this exact setup or the trek top. I just can't decide. Although both seem like either direction is going to cause me some pain.
BinaryPie is offline
post #6 of 117 Old 08-03-2010, 08:03 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Just check the parts before you buy. Prefit the winjammer to the sound bar. If that works your in business.
dvdsjk is offline
post #7 of 117 Old 08-03-2010, 08:56 PM
Charles
2017 WK
I bought their softdoors for my 4door. They aren't well made...the uppers don't fit into the lowers correctly. They sent me another door and it had the same problem. I had to grind half of the guide pins off. I mailed them back with a picture of the problem and never heard from them again. It's like the welders are human and do everything by "eying" it up. It's really bad. Apparently they outsourced everything overseas instead of making it in Colorado and ever since the the quality has been poor.
Charles is offline
post #8 of 117 Old 08-03-2010, 09:00 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Thats Funny! The set for my 2dr came that way also. 4WD parts told me to bend it! I told them it was off 3/4's of an inch so they said send them back!I,m waiting for another set also. Not having good luck at all with this Bestop crap!!!!
dvdsjk is offline
post #9 of 117 Old 08-03-2010, 09:08 PM
Charles
2017 WK
Yeah, the problem isn't that the pins don't line up the bottom, they don't line up where they are welded on the upper. So, if you bend the pin at the bottom, it just jams/binds as the upper meets the lower. It's complete BS that a product with that high cost has such poor quality. My passenger door fits differently than my drivers side too. If a competitor comes out bestop is screwed. I'd try anything other than bestop...
Charles is offline
post #10 of 117 Old 08-03-2010, 09:19 PM Thread Starter
dvdsjk
dvdsjk's Avatar
X2!!!!!!
dvdsjk is offline
post #11 of 117 Old 08-03-2010, 09:36 PM
TheShift
2010 JK Wrangler
The High Rock skids and runners i installed today from bestop were a [size=f'n huge]PITA[/size]
I had to literally heat the back of the skids up and tweak them a bit so they would fit snug on the jeep..... should have took pictures of how much they laid away from the rockers.... my buddy that was helping me was like''just get some black silicone and fill it in''.... pffft f that... i told him to stfu and hand me the torch...
They look great... had i not tweaked it a little....i would have sent them packin...
I will never buy anything from bestop again....
TheShift is offline
post #12 of 117 Old 08-03-2010, 09:42 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Glad to hear its not only me! Out of five parts ordered only three parts were right. Doors bad, Sound bar cover sewn wrong and the people at bestop didnt have the technology to look at there own parts to tell me what part was wrong on the sound bar cover!!! 4WD hardware chick didnt even know what a soundbar cover was!
dvdsjk is offline
post #13 of 117 Old 08-03-2010, 10:02 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Heres a couple of pics. First is how the J channel should be in the yellow. The second is what the soundbar cover J channel I purchased locally had and the second one and also the one described from 4wd hardware.
dvdsjk is offline
post #14 of 117 Old 08-03-2010, 10:04 PM
Charles
2017 WK
That stinks.
Charles is offline
post #15 of 117 Old 08-03-2010, 10:10 PM Thread Starter
dvdsjk
dvdsjk's Avatar
That stinks.
For me and them. You would think that there would be some concern from 4wd hardware or at the very most from bestop on this problem, but I was just blown off by both of them! I guess they don't need my money!!
dvdsjk is offline
bestop , JK Wrangler , problems , solution , windjammer , wrangler
LJ Pick-up Conversion with Bestop Wraparound Windjammer and Steel Bulkhead undercoverfab TJ Wrangler Technical Forum 66 05-06-2015 01:51 AM
Bestop Wraparound windjammer... plays well with others? tjsahara1979 TJ Wrangler Technical Forum 30 11-17-2014 09:15 AM
Anyone got a wraparound windjammer on an 03 + TJ bobthetj03 TJ Wrangler Technical Forum 2 06-25-2012 07:41 AM
Smittybilt tonneau cover and bestop wraparound windjammer wmeyer116 TJ Wrangler Technical Forum 0 12-04-2009 02:23 PM
