11-09-2008, 11:24 PM
#16
Originally Posted by 1222
Well whatever size you pick don’t put it where the evap canister was unless you’re prepared to have it ripped off. Remember, that was the reason for you relocating the canister in the first place. I would think that a 2.5 to 3gal tank would be fine. They are easier to fit and lot faster to fill than the 5gal one. Good luck on whatever you use. Remember to show pics of the install or we will hunt you down cut you’re tires.
Where else would one put an air tank? The dimensions on a 2.5 gal tank are 6.5 x 23. Thats a 6" diameter tank plus a bit for the bracket. I have not been able to find a smaller OD tank. A couple of 4 to 4.5" diam tanks mounted side by side would be sweet. My concern with the evap was not ripping it off only but damaging it and having the computer reduce engine power because of the damage. The evap cannister is plastic and is held on to it's bracket by 3 slide on tabs. A stout air tank firmly bolted to the frame could take much more abuse. And if it was damaged so what; the Jeep will still run.
I'm open for suggestions as to where else to mount a tank. Plumbing it in to the PP will be no problem as I have access to all necessary fittings.
08 JK Unlimited Rubi, Auto, 5.13 gears, RE 3.5" SF lift w Bilstin shocks, BFG 35" KM2's, AEV Pintlers, Alloy USA CM front axles w CTM Ujoints, Superior CM rear axles, JE Reel 1350 driveshafts, RockHard Front Bumper w Warn PP w 3/8 syn rope, RockHard rear bumper and tire carrier, RockHard rocker guards and skid plates, ARB diff covers, ORE C gussets and LCA skids, Tuffy Drawer, Cobra 75, Cibie headlights, Hella 4000 Rally lights, 60" HiLift, PullPal winch anchor, Engle 45 Fridge.
11-10-2008, 12:26 AM
#17
Make mine a Jeep!
I can’t say for sure where to mount it because I’m not at that point yet in my mods. I would think that maybe where some people are relocating the muffler about mid-ship inside the frame rails on the left side is an excellent place. As for the mounting bracket welded to the air tank, if it’s keeping you from tucking it up out of the way, you could cut it off and weld on your own custom bracket to make it fit. I still think that mounting it in the place of your evap canister is a bad idea. You say if it gets damaged what does it matter, it’s just an air tank. Well that air tank cost money too plus with it hard mounted you will get hung up on it with a just a moderate break-over situation. For me, I just look at the spot where the evp canister was at, and think of that spot as non-existing.
On my ’04 Rubi I mounted it inside the Jeep on the back left side finderwell. It was out of the way and that particular place was a blind spot anyway. Later, when I built my roof rack, I mounted outside on the rear of the rack. So in other words, take your time and get creative. Again, good luck.
11-10-2008, 04:11 AM
#18
DETN8R
X2, I was even thinking of a custom air tank... Maybe a rectangular tank made for the old muffler location.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power / Side Air Bags
Installed:
R.E. Modified 4" Super Flex Kit/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Adj. Trackbar/Rancho 9000XL shocks/Superior 4.88 Gears & Evo Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Mount/...
____oooo
[ l_,[____],
l---L -[OlllllllO]
( )_) ( )_)--)_)
11-10-2008, 07:04 AM
#19
Gold Member
Or of someone would make a roll cage that was hollow and sealed that would serve as an air tank. Another option is to make an air tank out of their bumper.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
11-10-2008, 09:12 AM
#20
Make mine a Jeep!
See, creative thinking. Look out of the box. Great ideas guys.
I can’t tell you how many times I’ve walked around, sat starring, laid under on the concrete and went to sleep, yes sleep and so on just trying to come up with a good idea so as to make things fit and not to look like a hack-job on this and my other Jeeps. I’ve learned years ago (from my uncle George) that there is always a way to do things. Some of course much harder than others.
11-10-2008, 10:29 AM
#21
Old 1980's pickup truck trick...
How about building a rear bumper out of whatever material you prefer. Pipe bumper or large tubing. Then make it into an air tank by sealing it up.
2008 Detonator Yellow Unlimited Rubicon -- Daystar upper dash -- Bestop Flexatrunk -- Pioneer FH-P800BT -- Next mod = XHD Modular front bumper
