Wanting largest shackles possible on Rugged Ridge stinger/bumper... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Wanting largest shackles possible on Rugged Ridge stinger/bumper...
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 02-07-2015, 07:40 AM   #1
Neo1130
2015 JK Wrangler
Got the Rugged Ridge winch bumper with stinger and stubby ends. Now I am needing to get the shackles but not sure on size. They offer 3/4", 7/8" and even 1" pin diameter shackles. The hole in the stinger where the shackle mounts is every so slightly under 1". I don't have my calipers available since I've moved recently but I would say the hole is around .925" to .950"... I keep seeing that the 7/8" shackles have a 1" pin and sometimes don't fit... Can anyone help me out? I don't want to get to small of a shackle and have it flop around....
Neo1130 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 08:12 AM   #2
JIMBOX
Get some 3/4" shackles and keep them in your recovery box--
No reason to leave them on your bumpers and available for theft/weather degrade/noise-
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 08:15 AM   #3
79cj7amc304auto
Originally Posted by JIMBOX
Get some 3/4" shackles and keep them in your recovery box-- No reason to leave them on your bumpers and available for theft/weather degrade/noise- Good luck JIMBO
Now there's a brilliant idea. Heading outside to remove my shackles right now.
79cj7amc304auto is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 08:21 AM   #4
JIMBOX
Heh Heh, thanx 79cj, but
It ain't brilliant, years ago I just got tired of the shackle noise and since my use ofem was-seldom, I just decided to keepem inside--along with the HiLift-
That just keepsem outta the weather/theft beckoning and noise reduction-
Whatever !
JIMBO
Yellow Jeep No. 683
Unread 02-07-2015, 08:31 AM   #5
Neo1130
2015 JK Wrangler
I was going to keep them tucked away until needed. I just was more worried about the slop when trying to recover. The more slop if and when a situation comes to jerk using shackles, the more chances there are to break something. So the 7/8" won't fit in the holes? As I said, I am getting a ton of conflicting info when I google it...
I am seeing as the 3/4" shackle has a 7/8" pin... A 7/8" shackle has a 1" pin and so on... Again, the 1" pin size is what I want IF it will work.... Unless that slop is actually something that's wanted...
Unread 02-07-2015, 08:36 AM   #6
JohnRodriguez
shackles aren't measured from the pin diameter. the measurement is taken on the diameter of the curved part. Crosby is the only manufacture that you can use the advertised measurement as the real pin diameter. the 5/8 Crosby shackles I use are rated at 4 1/2 tons and the 1" around 12 tons.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 08:38 AM   #7
JIMBOX
Well, keep in mind that under recovery, the shackle will not have any slop, because it'll be under constant tension/pressure, to maintain the pin/hole contact and
Sometimes when a HEAVY DUTY recovery is needed, both shackels on the SAME bumper are "trussed" together, to split the load-
Any slop that you experience is only gonna wear the bumper BKT paint off, over years of use--No Problemo !
Maintain-
JIMBO
Yellow Jeep No. 683
Unread 02-07-2015, 02:32 PM   #8
JTPhoto
There are also rubber gromlets you can purchase that go on the pin on each side of the attachment point and keep the D ring tight and rattle free.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline   Reply With Quote Quick reply to this message
Unread 02-08-2015, 07:26 AM   #9
Neo1130
2015 JK Wrangler
For those curious about this, 7/8" shackles will not work on a Jeep Rugged Ridge bumper. 7/8" are for large trucks and 3/4" are for Jeeps. That is how Rugged Ridge explained it anyways. Thanks for the info and help guys....
