Want warmer floor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Want warmer floor
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lTERAFLEX 1.5" Leveling kit for JK!!NEW NEW NEW XRC M.O.D. Bumper by Smittybilt
Unread 03-12-2015, 01:15 PM   #1
foolery
Want warmer floor
Hi all....
Have a 2008 JK.... here in Ontario it's been a cold winter....
Has any insulated floor to keep cold and drafts out?
What did you use or how was it done?
foolery is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 02:44 PM   #2
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
I wear socks and shoes in the winter.
Seriously, do you not have carpeting on the floor? If not, look into getting some automotive carpeting laid. It should have insulating material underneath it.
i.e.: http://www.quadratec.com/products/14051_830X_PG.htm
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Fox 2.0 shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
"Boing Clash Boom!" - Dada Life
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 03:01 PM   #3
ronjenx
ronjenx's Avatar
Have you reached down there and felt for hot air coming out of the floor ducts?
Mine gets so hot I have been afraid it would melt some of the plastic in the area. Never has melted anything, but it was hot enough to make me concerned when I first noticed it.
And, even when it's far below 0F, I end up turning the heat back to between 1/2 and 3/4 scale on the dial.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 06:53 AM   #4
foolery
heat works good but must be on HIGH.... when its 20F and your on the highway heat can barely keep up.....
Unread 03-13-2015, 07:04 AM   #5
ronjenx
ronjenx's Avatar
Do you get HOT air out of the upper vents?
2008 JKU Rubicon
42RLE Auto
Unread 03-13-2015, 08:22 AM   #6
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Foolery - you may need to flush that heater core... 200 degree air is 200 degree air no matter what the outside temp is! Or in other words - once your engine is warm that air (even if only getting to 100 - half the coolant temp) - should bake you out on high!
J Wm Bishop EA, ASADE
I'm cured, I'm CURED - My psychiatrist said there is nothing more he can do for me!!!
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 08:56 AM   #7
JIMBOX
WOW, the JK heater is usually un-coolable-
DO you have the temp knob all the way CLOCKWISE/FAN KNOB TO THE RIGHT and select knob to feet ?
When it's cold in Nv, I can barely turn the vent fan on/w heater sel on--it gets HOT !
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 03-13-2015, 09:28 AM   #8
Cropduster23
Coldest weather I have been in with my 2012 JKU is -34F. I know there are places that get colder, but 34 degrees below zero is bone chilling cold. Once my Jeeps engine is at operating temperature, the heater blows so hot that I honestly think someone could burn themselves if they left a hand in front of the vent for too long. I have never had a vehicle with such a good heater. Very rarely do I ever run the fan over 3-4 "clicks" on the dial. I've never run my soft top past October or before April, but I really feel like the heater would be adequate even with the soft top on in Northern Michigan winters.
Cropduster23 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 12:30 PM   #9
JLH
2015 JK Wrangler
If you want to insulate the floor sheet metal I would recommend looking at RAAMaudio or Second Skin Audio products. Call both of them up and tell than what you want to accomplish and they can suggest which one of their products will best meet your needs. That being said, I agree with the other guys saying the heater should be hot enough to run you out of the vehicle. The heater core might need to be flushed.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 01:16 AM   #10
FROZEN_INUK
I come from farther north and I find the problem is with keeping heat up top, -60c is hard to keep warm with a 4dr our "redneck" solution was to totally cover the front grill with cardboard God knows how our Canadian winters can be like but the heater in the Jeep isn't built to take the abuse and constantly switch between defrost and floor/defrost ahahah my poor passengers in the back seat end up freezing to death, I have carpeting in the Jeep (horrible idea where I'm at I want to rip them out) and find its partly cause of the floor matt being made of what ever rubbery thing its made of that takes and stores cold like crazy and our boots cold as hell ain't helping much
FROZEN_INUK is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 08:15 AM   #11
JIMBOX
WOW, I apologize for my comments about Nevada--
That is not to close to your environment and I can imagine your traveling in that temp-
You might look into thermal-acoustic insulation, I've used it in Nevada for over 5 years and it makes the JKU comfy in HOT summer (115*) and cold---07--
That doesn't come close to your minus temps, but it could make the diff.-
Good luck-
JIMBO
Yellow Jeep No. 683
Unread 03-20-2015, 08:37 AM   #12
ronjenx
ronjenx's Avatar
Assuming the heating system is working to capacity, it sounds like you need an aux heater in the JK.
2008 JKU Rubicon
42RLE Auto
Unread 03-20-2015, 09:58 AM   #13
VICTIM_OF_PAIN
Make sure all weather stripping around your doors is intact. I feel a cool breeze on right turns, turns out my weather stripping on one door is shot.
VICTIM_OF_PAIN is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 12:42 PM   #14
avatheredjeep
I have bedrug. i live in Hawaii so I don't remember exactly what cold means but I think it'll help you.
avatheredjeep is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 11:02 AM   #15
foolery
I do keep heat on to high most of the time. Heater core has been replaced and Hot air does flow well. It's like a draft down low. A lot in centre console. You can feel the draft.
On the highway it is worse.
Takes 10 minutes to heat up.
New thermostat installed.
Think I will pull console and see if there is an air leak around 4x4 linkage or transmission cut outs.
