Want to know your gear ratio for sure? - JeepForum.com
post #1 of 28 Old 07-22-2010, 01:58 PM Thread Starter
MilitaryJK4455
2010 JK Wrangler
Thanks ronjenx, for writing this out for us.
Finding Your Gear Ratio
Here is a procedure to get the axle ratio when it is not known. Build sheets (available from your dealer, or from the Jeep web site) will only tell you what the Jeep had from the factory. A used Jeep could have been re-geared.
If you want to know for sure, and remove all doubt, do this:
Chock the front tires, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jack stand and lower jack.
Put transmission in gear or Park, apply emergency brake.
Remove chocks.
If you have limited slip, jack up both rear wheels and rotate one revolution, making sure both tires rotate equally.
If the drive shaft rotated almost 3 1/4 turns, you have 3.21
If the drive shaft rotated almost 3 3/4 turns, you have 3.73
If the drive shaft rotated a little over 4 turns, you have 4.10
If the drive shaft rotated a little under 5 turns, you have 4.88
If the drive shaft rotated a little over 5 turns, you have 5.13
Now go drink a beer and feel confident that you know your gear ratio without a doubt
MilitaryJK4455 is offline
post #2 of 28 Old 07-22-2010, 03:35 PM
fernjack
That IS a very good write-up .........but I think I'll just drink a beer
fernjack is offline
post #3 of 28 Old 07-22-2010, 03:52 PM Thread Starter
MilitaryJK4455
2010 JK Wrangler
post #4 of 28 Old 07-26-2010, 07:47 PM
wrestlerobx
CRAWLED this is cool. I appreciate it
JEEP
wrestlerobx is offline
post #5 of 28 Old 07-26-2010, 08:03 PM Thread Starter
MilitaryJK4455
2010 JK Wrangler
There is a lot more stuff where that came from... Just check out this sticky...
http://www.jeepforum.com/forum/f96/j...reads-1074059/
post #6 of 28 Old 07-26-2010, 08:08 PM
wrestlerobx
yeah ive been peeking in there but i must have missed this one i suppose
JEEP
post #7 of 28 Old 07-27-2010, 11:27 AM
CarolinaPoetic
fore = front
aft = rear
and beer = blue moon!
Its not the destination, its the journey to get there.
CarolinaPoetic is offline
post #8 of 28 Old 01-12-2011, 12:42 PM
OLDGUY19
1946 CJ2A
Thank you
OLDGUY19 is offline
post #9 of 28 Old 01-12-2011, 02:37 PM
jstrubberg
2009 JK Wrangler
Or just get your Jeep up to 70mph, recrd the RPMs then check them against the chart floating around here. Lot less work.
jstrubberg is offline
post #10 of 28 Old 01-12-2011, 02:40 PM
MightyLampshade
1979 CJ7
You can also count the teeth on the gears if you have the diff covers off and a little simple math will provide the ratio as well
MightyLampshade is offline
post #11 of 28 Old 01-12-2011, 03:05 PM
propped1
Dont think this is an easy way.
Take the cover off, dispose of gear fluid, fill with more gear fluid.
50 bucks and an hour to check your teeth? think you're missing the point....
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #12 of 28 Old 01-13-2011, 09:26 AM
MightyLampshade
1979 CJ7
You'll note I said "if you have the cover off" There was also no mention in any previous post about cost, merely a way to find out your gear ratio
I think you missed the point...
post #13 of 28 Old 11-29-2012, 05:07 PM
riot1987
I have a ring gear with 41 teeth and a pinion with 14. Can one of you kind gentlemen give me my ratio? Do you just dived the two numbers? 2.92's..?
Build thread^^
riot1987 is offline
post #14 of 28 Old 11-29-2012, 05:49 PM
Taguilar
You know where I can find this magical chart?
Taguilar is offline
post #15 of 28 Old 11-29-2012, 07:49 PM
ronjenx
ronjenx's Avatar
You did the math correctly.
ronjenx is offline
confirmation , gear ratio , how to , JK Wrangler , wrangler
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
