Want comments on Brake Shoe replacement - JeepForum.com
View Poll Results: Pads only, or rotors and pads...
Replace pads only 7 53.85%
Turn rotors and replace pads 5 38.46%
What, who needs brakes? 1 7.69%
Voters: 13. You may not vote on this poll
post #1 of 22 Old 08-18-2013, 03:54 PM Thread Starter
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Time for brakes. The rear pads are thin and the front are getting well worn. Question is, I have always just replaced the pads on my other vehicles and never had the rotors turned unless they were gouged by letting the pads go too far....
So, since the rotors look nice and smooth at this point, would you have the rotors turned (have the work done at a shop) or just replace the pads?
Oh, and before a bunch of smartass comments, I mean pads, but wrote shoes....I do know the diff.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #2 of 22 Old 08-18-2013, 04:01 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I usually just change the pads unless there is pulsing in the pedal or while coming to a stop indicating warpage or there is a significant ridge on the edge of the rotor from wear.
Jim
JLC08JK is offline
post #3 of 22 Old 08-18-2013, 04:21 PM
Jiblet
I replaced my rears at around 38k. Left the rotors alone. When these pads are gone i'll install new pads and rotors.
My front pads are about 2/3 gone, not bad for 60k.
All my rotors are wearing evenly, no real grooves to speak of.
You could alway get out the calipers and see what you have left.
Jiblet is offline
post #4 of 22 Old 08-18-2013, 05:07 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
No reason to change rotors ever unless as stated above there is a lot of pulsing in the pedal when stopping or there is groves cut into the rotor (run your fingernail from inside to outside, there shouldn't be anything stopping it)
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #5 of 22 Old 08-18-2013, 05:19 PM
krutj
2009 JK Wrangler
My rear pads lasted for 88k, rotors were smooth and true..I went with pads only. I have a 6sp and commute in a very rural area, hardly ever use the brakes, other than a touch.
I'd say if they run true and look good, just do the pads this time.
-- Joel --
krutj is offline
post #6 of 22 Old 08-18-2013, 06:37 PM
tjkj2002
2002 KJ Liberty
In bold is the problem.The new pads will not "bed in" correctly.You need to mic the rotors to make sure they have enough material left,then turn them.Granted you can buy new rotors(yes even good ones) for a little more then the cost of having them turned.The rough surface left by turning the rotors,if done correctly,will help bed in the pads.
I personally never turn rotors for any vehicle I own,just replace the pads and rotors everytime.Not a time to be cheap.
tjkj2002 is offline
post #7 of 22 Old 08-18-2013, 07:41 PM
TheBoss
I agree with the above post , mic the rotors and turn them or spring for new rotors. Being as these newer Jeeps with the esp , esc and bls go through the rear brakes harder than the fronts it would be money well spent . After all look how much we all sink into other areas of the Jeep, why skimp on stopping power.
TheBoss is offline
post #8 of 22 Old 08-18-2013, 09:29 PM
tjkj2002
2002 KJ Liberty
At least someone else has some common sense
tjkj2002 is offline
post #9 of 22 Old 08-18-2013, 10:17 PM
pentastarguy
2015 JK Wrangler
op, i voted for "shoes" and turn rotors. had it been offered i would have voted for turn rotors if needed.
pentastarguy is offline
post #10 of 22 Old 08-19-2013, 01:13 PM Thread Starter
RockyClymer
RedRock4Wheeler
More info. Spoke with a fellow jeeper who does all his own work. He said the pads alone will work fine, but will not last as long as if the rotor is turned a thousandth or so....he takes his rotors to a shop and pays them to mic and turn them when needed, but does the install himself.
NRA Life member
post #11 of 22 Old 08-19-2013, 02:00 PM
duneslider
All the mechanics I know say to turn them. I usually don't and can't say I have noticed a difference. It seems not as many places local to me have the service to turn them. I may try to have them turned this next time just to see, I think the new parts store by me has a machine to do it. Although the cost of new is almost the same.
duneslider is offline
post #12 of 22 Old 08-19-2013, 02:08 PM
ncb
OEM rotors are cheap from Quadratec and there's a free shipping code for JF members.
ncb is offline
post #13 of 22 Old 08-19-2013, 09:07 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
ALWAYS TURN.
The bedding of old pads is still in the pores of the cast rotors - turning is the only way to get the new pads a fresh surface to bed-in to. failing to turn is "okay" mechanically - most drivers would never notice the difference - except that one time you really really need stopping power all the way from 70 mph to zero - is when the fade from unbedded brakes will bite you in the rear (of the car in front who DID properly bed-in his brakes!). Without proper bed-in your brakes just do NOT perform as well as they could. 70-80% efficiency may be good enough 99.99% of the time - but not for me.
I used to run with a championship race team - we changed pads and turned every four races selling our old stuff to our competitors, who could never figure out how they were getting beat going into the corners. Good brakes are a very high priority in MY book. not just for performance driving - to have a safety factor when dealing with other peoples screwups while driving.
for more info. It aint just money - its yours (and you childrens?) life we are talking about!
I mean its silly - a guy who would NEVER drive with a sloppy spongy pedal saves 8 bucks and reduces his brakes overall efficiency for what good reason? simply because he has not yet had to demand the brake load that would cause fade? Ive never needed my fire extiguisher so maybe I should just toss it off the side of the road....
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #14 of 22 Old 08-19-2013, 09:11 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
At least until kotex makes combat boots...
post #15 of 22 Old 08-19-2013, 10:15 PM Thread Starter
RockyClymer
RedRock4Wheeler
I have decided on either turning them or getting new rotors...the sloted and/or drilled rotors look mighty good to me.
NRA Life member
