Void warranty - JeepForum.com
post #1 of 19 Old 05-11-2013, 12:49 PM Thread Starter
jk13crush
Void warranty
I have a 2013 jk and I'm planning on putting a rockkrawler 2.5 xfactor lift on it and running 35s. Does this void my warranty?
jk13crush is offline
post #2 of 19 Old 05-11-2013, 12:56 PM
LVCapo
2015 JK Wrangler
're going to get a lot of varying opinions on this...but the short answer is you will only void your warranty of they can say that your modification caused the warrantied part to fail. The 35"s will be a point of contention with the axles, drive shafts, and transfer case.. The lift will be an issue with the driveshafts.
I've got the 2.5" stock mod with add ons and 33" Duratracs and havent had any issues with warranty work......but it'll come down to how slimey your dealership is and how you let them deal with you. If you go in knowing your rights and have a general idea what the issue with your vehicle is...the less likely they are going to try anything underhanded.
LVCapo is offline
post #3 of 19 Old 05-11-2013, 01:07 PM Thread Starter
jk13crush
Thank you. Front axle will get Artec truss and gussets. are the drive shafts that much of a problem with 2.5 inches of lift?
post #4 of 19 Old 05-11-2013, 01:07 PM
222Doc
222Doc's Avatar
you going to leave the 3:21 gears in it? If not would be thetime for lockers too. why pay for the same labor again? I think that lift has alot of drop so drive lines might be needed ina 2d the rear will be steep at drop. Y pipe mode andor front drive line to clear ypipe. again depending on shock lenght. you have 2.25 inch of drop over stock before that drive line will rub
As for the warranty. No/yes/ depends on what breaks, how you break it and the dealer. Off road they can pull the abuse card at will. The tires are not stock so that could effect anything up the drive line and be said to have lead to the what ever is up stream. I have heard of dealers flagging Jeeps that are modded as void. Some seem to try and help out as much they can. Its more a crap shoot in the end.
222Doc is online now
post #5 of 19 Old 05-11-2013, 01:12 PM
222Doc
222Doc's Avatar
D30 might be a waist of money to sink truss and guss. I would just sleeve it at most and gussets. If you weld that truss on it, i would bet a beer they ruin the front seal and it will leak. You need to remove the front carrier, back to might as well regear it lock it. Your weak link on that d30 is the axles. 35 are pushing that d30 alot, at 18 i would bet you have a heavy right foot with a new Jeep to boot.
post #6 of 19 Old 05-11-2013, 01:20 PM Thread Starter
jk13crush
Thanks for your advice.http://www.artecindustries.com/JK-Fr...uss_p_312.html
Wouldn't you think this is cheap insurance for the c-nuckles? I would regear to 4.56 or 4.88 and I'm putting lockers in myself.
post #7 of 19 Old 05-11-2013, 02:11 PM
wranglerboy13
On the gear subject. 4.56 is as deep as you are going to want to go unless 37's are in your future indefinitely. And even then, 4.56 is what I would go with. And just to be sure you know re-gearing and lockers are part of the same process. So getting someone to re-gear the jeep and then you put in lockers does not make any sense. I vary well could have mis-interpreted what you were saying so dont' be insulted . And if you are re-gearing yourself, good for you! I would like to do the same thing maybe one of these days.
wranglerboy13 is offline
post #8 of 19 Old 05-11-2013, 02:51 PM
222Doc
222Doc's Avatar
so you know how to set a gear set? have to tools needed. 37 and a d30 will break under most people. 37 on d44 is pushing that.
you must have deep pockets to have anew jeep and be able to do all this too. and know how to set a ring and pin. or you are a troll. no offence. Just say at 18 years old................
remember the start of this thread was a WARRANTY, now we are rebuilding a new jeep.
post #9 of 19 Old 05-11-2013, 02:55 PM Thread Starter
jk13crush
Thanks for the advice on the gears I'm probably regearing myself. And I wouldn't run 37s with the Dana 30 up front.
post #10 of 19 Old 05-11-2013, 03:00 PM Thread Starter
jk13crush
I was wondering about the warranty and 35s originally and I know how to the gears and the backlash. I grew up in a garage. The plans for the 35s will happen over the next year or two. I go to school and just started a full time job. But now I know about the warranty. So thank you and thank you for the other advice too.
post #11 of 19 Old 05-12-2013, 10:46 PM
joe108
My experience with the warranty and my local dealer was that they will try to get out of any and all work by blaming it on what ever they can. Mine had a 2" lift and they would not cover the driveshaft because it was "modified". However, in their lot were several lifted(4" to 6") jeep in their lot which they said were covered....
joe108 is offline
post #12 of 19 Old 05-12-2013, 11:08 PM
Godholio
Having the dealership do the work is actually a workaround because it's their work.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #13 of 19 Old 05-13-2013, 01:32 AM
SubAtomicGenius
2011 JK Wrangler
Doing a re-gear is easy peasy as long as you are mechanically inclined and have the right tools. THAT is the expensive part. My ****ty dealer told me upfront (after I bought her) that I'd void the warranty with anything over stock tires. Two years now almost and she hasn't been back, regeared, locked up and and 35's. If you're concerned with warranty, you have to call the dealer. IMHO, if anything driveline-related breaks, it is just an opportunity for an aftermarket upgrade! Congrats and have fun!
SubAtomicGenius is offline
post #14 of 19 Old 05-13-2013, 06:02 AM
rha600
See if you can find a dealer that is modify friendly. Mine is owned by a man that actually sponsors one of the local Jeep clubs and won't even deny warranty work on a Jeep with a 3.5" lift and 37s. Although I wouldn't be surprised if you totally thrashed it, they may.
One question I do have, is why would you buy a Sport/Sahara and then spend all that money upgrading axels, gears, etc? wouldn't it have been cheaper/easier to just buy the Rubicon? I can understand if you were throwing a set of 60's in there, then it would be cheaper to go with the sport.
rha600 is offline
post #15 of 19 Old 05-13-2013, 08:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Here's the "official" wording from the 2013 Jeep Warranty Manual regarding modifications:
3.1 Modifications Not Covered
A. Some Modifications Don’t Void the
Warranties But Aren’t Covered
Certain changes that you might make to your
vehicle do not, by themselves, void the warranties
described in this booklet. Examples of some
of these changes are:
• installing non-Chrysler Group LLC
(Chrysler) parts, components, or equipment
(such as a non- Chrysler radio or speed control);
and
• using special non-Chrysler materials or
additives.
But your warranties don’t cover any part that was
not on your vehicle when it left the manufacturing
plant or is not certified for use on your vehicle. Nor
do they cover the costs of any repairs or adjustments
that might be caused or needed because of
the installation or use of non-Chrysler parts, components,
equipment, materials, or additives.
Performance or racing parts are considered to be
non-Chrysler parts. Repairs or adjustments caused
by their use are not covered under your warranties.
Examples of the types of alterations not covered
are:
• installing accessories — except for genuine
Chrysler / MOPAR accessories installed by an
authorized Chrysler, Dodge, Jeep or Ram dealer;
• applying rustproofing or other protection products;
• changing the vehicle’s configuration or dimensions,
such as converting the vehicle into
a limousine or food service vehicle; or
• using any refrigerant that Chrysler has not
approved.
B. Modifications That WILL Void Your
Warranties
These actions will void your warranties:
• disconnecting, tampering with, or altering the
odometer will void your warranties, unless
your repairing technician follows the legal
requirements for repairing or replacing odometers;
or
• attaching any device that disconnects the
odometer will also void your warranties.
JeepCares is online now
