Violent front end shaking - Page 2 - JeepForum.com
post #16 of 29 Old 05-10-2011, 04:52 PM
lawnboys02
I've had the DW since Aug and started out occasionally driving 40mph on a road with a lot of potholes. Then months later 90 mph coming home from out of town the car started wobbling violently. Ever since it's been happening at slower speeds like 65 and even at 30mph. So I replaced the steering stabilizer shock and now at any speed no DW. It's not a smooth ride but i bought a Jeep not a Cadillac. Someone post in the forum that with every DW more suspension parts can start to fatigue. Take it for what it's worth.
lawnboys02 is offline
post #17 of 29 Old 05-10-2011, 05:50 PM
papaw
2009 JK Wrangler
Mine would also stop after stabilizer shock replacements - but not for long.
papaw is offline
post #18 of 29 Old 05-10-2011, 09:32 PM
Hellbound13
I sugest everyone with this dangerous problem, report it here.. Jeep needs to built this **** out of better components, solid axle or not..
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
Hellbound13 is offline
post #19 of 29 Old 07-18-2011, 09:11 AM
papaw
2009 JK Wrangler
Well, I think my DW has mostly been eliminated after re-torquing the trackbar. The passenger side of the trake bar was OK (125#) but the driver side of the bar was only 100 ft #. I re-torqued both to 130 ft lbs and have not had any excessive DW for the past 3 months although I can tell at times it would like to start after hitting a bump, it dissipates instead of getting worse. Hard to believe 30 ft lbs of torque could make that much difference but it apparently did.
papaw is offline
post #20 of 29 Old 07-18-2011, 09:25 AM
terrahawk
A steering satabilizer has ZERO...NADA to do with death wobble, hell, you don't even need one of the damn things if your suspension is set up correctly. It should never be a part of your solution.
Speed has never killed anyone - suddenly becoming stationary, that's what gets you!
terrahawk is offline
post #21 of 29 Old 07-18-2011, 12:42 PM
WXman
I find it hard to believe that Jeep would go to the significant extra cost involved to put a steering stablizer on these things if they truly did nothing for the ride quality/handling. At $10 bucks a pop, or whatever they pay the supplier for them, times the hundreds of thousands of JKs sold... I don't see Jeep putting them on here just for looks.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #22 of 29 Old 07-18-2011, 01:46 PM
ncb
He was emphasizing that a SS isn't a cure for death wobble. It's there to dampen feedback while wheeling rocky trails or from bumps in the road.
ncb is online now
post #23 of 29 Old 07-18-2011, 02:49 PM
terrahawk
Think of a steering stabilizer like taking any kind of cold medicine; it doesn't cure the cold, it just masks the symptoms.
post #24 of 29 Old 07-19-2011, 11:37 AM
Avernar
2010 JK Wrangler
Steering stabilizer--zero impact. You don't even need one.
While a bad stabilizer won't cause DW, it will hide it until the DW damages the stabilizer. That's why most dealers think replacing the stabilizer "fixes" it. All that happens is the DW is hidden again until the new stabilizer dies but this time more damage has been done to other components.
My dealer replaced the stabilizer and I can still feel the front end trying to start the DW but the new stabilizer won't let it. I'm replacing most of my front suspension with a lift kit (springs are backordered ) which will truly cure my DW.
Avernar is offline
post #25 of 29 Old 07-19-2011, 01:03 PM
williewvr
No lift can cure dw. It isn't the lift, it's stuff coming loose that causes it. Buy a torque wrench and learn to use it and say goodby to dw..dw is more noticeable in lifted jeeps but can occur even in stock solid axle jeeps and trucks. Number 1 cause seems to be loose tracbar ends.
williewvr is offline
post #26 of 29 Old 07-19-2011, 01:46 PM
Avernar
2010 JK Wrangler
Have a torque wrench, know how to use it and dw was still there.
I should have worded that last sentence better though. The lift kit has many new brackets and bolts which will replace any worn out ones. If the trackbar bushings are damaged I'll replace the trackbar as well while things are apart. That will cure my dw.
Avernar is offline
post #27 of 29 Old 05-24-2015, 09:27 PM
Texazone
I have a 2007 Jeep Unlimited and have experienced the same problem. Someone mentioned that he inspects the aforementioned parts for tightness etc at every oil change which sounds like a good idea. Does anyone know if certain preventive maintenance or improvements is recommended by Jeep engineers so this can be avoided in the future?
Texazone is offline
post #28 of 29 Old 05-25-2015, 05:54 AM
YATZI1980
2011 JK Wrangler
Do yourselves a favor. Go to this link and follow planmans directions for how to identify the cause of DW and how to correct it.
http://www.jk-forum.com/forums/jk-wr...obbles-260145/
YATZI1980 is offline
post #29 of 29 Old 05-25-2015, 07:17 AM
zjilla
Did the OP come here to complain or actually fix the issue?
Im not gonna even help or state my opinion on the original post.
Do yourself a favor and sell your jeep. You dont deserve it
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
ball joints , shaking , steering , suspension , tires
violent front end shaking. alc20754 TJ Wrangler Technical Forum 11 04-07-2010 11:59 AM
violent shaking at 60 mph Aduffy32 YJ Wrangler Technical Forum 20 03-13-2010 11:55 PM
Violent shaking from front end Radimus TJ Wrangler Technical Forum 5 08-10-2009 11:09 PM
violent shaking xitsjaybird90 YJ Wrangler Technical Forum 7 06-02-2009 07:02 PM
violent shaking jeeptj00boy TJ Wrangler Technical Forum 7 11-16-2004 03:48 PM
