vibrations at certain speeds - Page 2 - JeepForum.com
post #16 of 17 Old 07-03-2013, 11:25 PM Thread Starter
AK49
Originally Posted by motoguy1251 View Post
Not to thread hi jack, but what are the stock drive shafts considered as. There is no U joints in the rear and just one on the front. So does that make both shafts a cv joint. ALso what should pinion angles be for various normal lifts: say- 2.5 to 3.5 in lifts?
I've been reading a lot of previous posts and it seems like 3-4% is normal. Hopefully someone with experience will chime in since I'm currently sitting at 3" lift and would also like to know before experimenting any further.
AK49 is offline
post #17 of 17 Old 07-08-2013, 10:33 AM
Tbasham
There is no set pinion angle for a specified height. All lifts will yeild different heights depending on vehicle weight which will lead to slightly different pinion angles to have the pinion pointed right at the transfer case.
When adjusting the control arms, I know it will throw off caster. Search for how to do an at home alignment and you will find tons of information regarding this.
Tbasham is offline
