vibrations at certain speeds - JeepForum.com
post #1 of 17 Old 07-01-2013, 08:43 PM Thread Starter
AK49
Looking for some ideas on why i'm getting vibrations at certain speeds. Vibrations will kick in from 10-20 and around 30-35 and 50-55. Coilover lift was installed along with 35" Toyo MT's and new driveshafts. Anything I can do to help narrow down the problem?
AK49 is offline
post #2 of 17 Old 07-01-2013, 09:55 PM
Tbasham
Make sure the tires are properly balanced and your drive shaft angles are correct.
Tbasham is offline
post #3 of 17 Old 07-02-2013, 08:50 AM Thread Starter
AK49
Thanks! I had the tires balanced before going on. You think I should have them rebalanced? Also when the lift was installed, new 1350 drive shafts were also installed.
AK49 is offline
post #4 of 17 Old 07-02-2013, 08:59 AM
Tbasham
What size lift and do you have adjustable control arms?
Tbasham is offline
post #5 of 17 Old 07-02-2013, 09:02 AM
C2U5H
C2U5H's Avatar
have someone turn the steering wheel back and forth with the jeep on while you look at the components up front. looking for moving hardware or any component that seems to move within its mount. most likely your axle-side track bar mount. alignment's easy since we have knuckle to knuckle tie rods, so i'm assuming that's not it.
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #6 of 17 Old 07-02-2013, 09:07 AM
222Doc
222Doc's Avatar
No info on this in the profile , but I will put on my mindreading hat. Sounds like the start of DW. we are talking about the FRONT right? It is a Jeep cj-jk? Its old or new?
Why? Because a new Jeep we can safely say it is not the ball joints, tre's carrier bearing, drag link etc..
But we know you lifted something and put 35"s. Sounds like the lift is not installed correctly and or something wore out. Going 35"s brings out the unknown DW in used jeeps. If its new your install is off or the lift might be cr@p for the height. check all bolts, be sure to have tightened all suspension joints with the Jeep on the ground with the jeeps weight on it.
read the DW thread sticky
222Doc is online now
post #7 of 17 Old 07-02-2013, 09:52 AM Thread Starter
AK49
My fault. Lift is an EVO 4" Long Arm with Coilovers. It's on a 13 JKUR. Driveshafts were also replaced the same time the lift was done. The vibration at 10-20 is most noticeable. The vibrations at 30-35 and 50-55 is very mild (can't even feel it through the steering wheel).
AK49 is offline
post #8 of 17 Old 07-02-2013, 09:54 AM Thread Starter
AK49
It's a 4" evo long arm with coilovers. It's set at 3" right now. It does have adjustable control arms.
AK49 is offline
post #9 of 17 Old 07-02-2013, 10:00 AM
boon4376
1973 CJ5
Some places just do a terrible job balancing tires... So it could be as simple as that.
boon4376 is offline
post #10 of 17 Old 07-02-2013, 10:56 AM
Tbasham
Since you have the rubicon make sure both of your pinion angles are set and pointing right at the ouput of the transfer case. If your pinion angles are correct, that will eliminate your driveline as the cause, I doubht the driveshafts are out of balance since they are new.
Tbasham is offline
post #11 of 17 Old 07-02-2013, 01:26 PM Thread Starter
AK49
I took a few pictures of the driveshaft (sorry about the crappy quality. It's a pain getting a full shot of the entire front driveshaft. I'm completely confused about the angles. Does this look totally off?
AK49 is offline
post #12 of 17 Old 07-03-2013, 12:00 PM
Tbasham
It looks like from those pictures your pinion needs to be angled up a little bit more. Here is a link to a picture that explains the whoel angle situation better. For your front and rear axles you will want them like ti shows in the picture for a CV driveshaft.
http://www.jeepforum.com/forum/f9/un...angles-763367/
Tbasham is offline
post #13 of 17 Old 07-03-2013, 12:16 PM
Tbasham
http://www.4xshaft.com/driveline101.asp
here is where that picture came from. Also this is a good read that will explain why you need adjustable control arms with that much of a lift. In theory you can drive like you are and just ignore the vibrations, you will just wear out your u-joints much much faster.
Tbasham is offline
post #14 of 17 Old 07-03-2013, 03:42 PM Thread Starter
AK49
This is a stupid question...but if I adjust the lower control arms to set the driveline angles so they're more in line. Will it cause any issues (assuming there are no major drivability issues) if it takes a few days before I can get it to be realigned?
AK49 is offline
post #15 of 17 Old 07-03-2013, 10:28 PM
motoguy1251
Not to thread hi jack, but what are the stock drive shafts considered as. There is no U joints in the rear and just one on the front. So does that make both shafts a cv joint. ALso what should pinion angles be for various normal lifts: say- 2.5 to 3.5 in lifts?
motoguy1251 is offline
