very impressed with my 2012 JKUR towing a 4k lb boat - Page 2 - JeepForum.com
post #16 of 31 Old 07-30-2012, 10:43 AM
ronjenx
ronjenx's Avatar
Originally Posted by HurricaneRZA View Post
Is the tow rating for the JK and the JKU the same?
No.
2dr = 1000 lbs and 2000 lbs, depending on how it's set up.
4dr = 1000 lbs and 3500 lbs, depending on how it's set up.
ronjenx is offline
post #17 of 31 Old 07-30-2012, 10:45 AM
HurricaneRZA
Originally Posted by ronjenx View Post
No.
Ahhh ok, I had guessed that the JKU might be underrated for towing if the rating was the same for both... But never mind that thought then
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #18 of 31 Old 05-25-2013, 01:54 PM
gabejeep
1997 XJ Cherokee
I heard the tow rating is based upon how much the frame of the vehicle is capable of pulling, not the engine or torque. Is this true? I tow my 2,500 lbs boat with my XJ. However, even with my XJ and a towing capacity of 5,000 lbs, I do get some tow sway here and there because of the short frame and wheel base.
gabejeep is offline
post #19 of 31 Old 05-25-2013, 02:07 PM
HoustonRider
I'm not convinced that's the limiting factor.
The boxed cross member is welded to the frame rails, so the load ends up at the same place as a hitch that's bolted to the rails. The tow rating isn't based on the class of hitch installed.
The limiting factor is the ability of the vehicle to keep control and stop safely. I you are in an accident that was caused by u not being able to stop, and its because you were overloaded, it's all on you.
Any of these jeeps can pull 5,000lbs, it's stopping in time that becomes an issue.
Sent from my iPad.
2012 JGC Overland Summit 4x4 Hemi
2013 Wrangler 4x4 Auto - Dozer
HoustonRider is offline
post #20 of 31 Old 05-25-2013, 08:36 PM
TheBoss
I doubt it's based upon frame specs. the XJ is a unitized body as is my WJ which is also rated at 5000 lbs.
TheBoss is offline
post #21 of 31 Old 05-25-2013, 10:28 PM
djm
It's not about what you can pull and get moving, it's about what you can control once you get it moving.
As someone said, be involved in an accident and even though someone else was the initial cause of the accident, a lot of responsibility could be transferred to the vehicle that was towing outside it's approved weight class. Of course all depends upon the circumstances, but everyone is usually looking to blame someone else or at lease spread the blame.
For example in NJ, a DUI involved in an accident that results in a death requires a mandatory jail sentence. True story, a guy who is under the influence, but driving ok, stops at the red traffic light. Someone apparently completely sober but distracted crashes into the rear of the first vehicle stopped at the red light. Second driver is killed in the accident. During the investigation it's determined the first driver, who so far had done nothing wrong to contribute to the accident, is under the influence. He is charged, first offense doing anything wrong in his life, and winds up in jail because the second driver died.
I'm not saying I never did anything illegal, just saying be careful out there because it's so easy for something that should not be a problem to become a big problem. No one ever gets up and says today is the day I'm going to do something to screw up the rest of my life, stuff just happens and we wish we had not done it that way today.
djm is offline
post #22 of 31 Old 05-26-2013, 08:51 AM
rirrgang
I wonder how impressed you'd be when you get in an accident? A lawyer would eat you for breakfast. Towing beyond the factory limits is a STUPID thing to do. Need to tow heavy loads? Buy something that is designed to do so.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #23 of 31 Old 05-26-2013, 10:41 AM
Alaska-HWY JK
Call the forum Police! Someone broke the towing law again.
Alaska-HWY JK is offline
post #24 of 31 Old 05-26-2013, 12:37 PM
rirrgang
You get in front of him in a panic stop. See if you think it's funny then
-Rick
07 Sahara Unlimited
rirrgang is offline
post #25 of 31 Old 05-26-2013, 02:39 PM
djm
Everything will be ok until it isn't. Ya can tow heavy 1,000 times and nothing goes wrong, that's great, but the one time something happens you will wish you were 100% legal. Not saying I never did/do anything that's not 100% legal, but I never advise someone else to do it. I make a value/risk assessment and then do what works for me. Bottom line, that's what you need to do for yourself. You have heard the pros and cons and some opinions, you just have to do what you are comfortable doing.
djm is offline
post #26 of 31 Old 05-26-2013, 02:47 PM
Alaska-HWY JK
Apparently you can drive across a bridge in the USA and it will collapse under you. What's the chances.
post #27 of 31 Old 05-26-2013, 06:03 PM
djm
To make the bridge collapse underneath you, ya have to hit a few of the tops cross members with your oversize load and take a few of them out along the way in order to get the bridge to collapse.
On the bright side we at least have bridges unlike like the pontoon boat that's used as a ferry, crossing the river at Dawson Creek.
Dawson Creek is a great place to visit, even if the roads are dirt, the air conditioning and internet access is rationed so everyone in town gets a chance to use it. Saw my first burlesque show there at Diamond Tooth Gurtie's Saloon.
Great place to visit but I am USA all the way ! God Bless the USA !
djm is offline
post #28 of 31 Old 05-26-2013, 07:06 PM
Alaska-HWY JK
I like it in places down there to, some of you are to worried about litigation. Every time someone pulls over the low legal limit of the Unlimited the tow police are out. There's probably over a dozen threads like this out there. Not all towing 4000lbs but same idea. I guess it's been awhile since you've been through, there's been a bridge at Clayhurst for around 30 years. I regret having never crossed on that old ferry but the Rolla Pub is still open on the way there.
post #29 of 31 Old 05-26-2013, 08:25 PM
djm
Ok my apologies, I was thinking about Dawson City, in the Yukon Territory. I was up there a few years ago and had to take a ferry across the river into Dawson City, the streets are dirt, they ration internet access 1/2 hour per person so everyone gets a chance to use it. I was in Dawson Creek also, that's the base of the Al-Can highway.
No harm meant, all in good fun ! I had my 4wd dodge truck when i was up there, would have really liked to have had the Jeep, what an experience and created a lifetime of memories.
djm is offline
post #30 of 31 Old 05-26-2013, 09:33 PM
WhiteOut
WhiteOut's Avatar
- Full DOT permits
- Escorts present
- Didn't hit "a few" and none were "taken out", single glancing impact that resulted in a minor dent on the load
- Bridge listed as "functionally obsolete"
You didn't miss much in your post.
WhiteOut is offline
Access through the firewall on a 2012 JKUR? socal_rubi JK Wrangler Technical Forum 17 07-10-2012 06:46 AM
2012 JKUR Build smooth9883 JK Wrangler Technical Forum 20 01-18-2012 02:12 AM
2012 JKUR Auto w/4.10 and 35's Impressions? Keiff JK Wrangler Technical Forum 2 11-07-2011 01:44 PM
2012 JKUR Auto Tranny + 35s = ReGear? PJ33P JK Wrangler Technical Forum 14 10-12-2011 01:22 PM
Towing this Toy Hauler with a JKUR? JK4Three JK Wrangler Technical Forum 52 03-31-2011 12:22 AM
