very impressed with my 2012 JKUR towing a 4k lb boat - JeepForum.com
post #1 of 31 Old 07-25-2012, 10:55 PM Thread Starter
barry1me
barry1me's Avatar
Hey guys I have about 4200 miles on my wifes 2012 JKUR. We went with the 3.73 gears as it worked the best for our needs. In the last month we have towed almost 1000 miles with the Rubi and our boat which is about 4400lbs. I installed the Mopar 7pin wire harness to work with the factory surge brakes. This little pentastar has done great. Im averaging about 11.5-13mpg towing the boat depending on speeds. Im surprised how well the pentastar/tranny works towing and does it effortless. Anyone debating what a wrangler can or cant tow Im confident in mine and it does it pretty easily.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #2 of 31 Old 07-25-2012, 10:57 PM
pentastarguy
2015 JK Wrangler
when did they raise the tow rating to over 3500 pounds?
pentastarguy is offline
post #3 of 31 Old 07-25-2012, 11:07 PM
ronjenx
ronjenx's Avatar
What role does the 7 pin plug play in the application of the surge brakes?
ronjenx is online now
post #4 of 31 Old 07-25-2012, 11:22 PM
crazycalvin
I imagine that the trailer has a five pin plug the extra being for reverse so when you're backing the trailer up it doesn't allow the brakes to lock up.
crazycalvin is offline
post #5 of 31 Old 07-25-2012, 11:27 PM
ronjenx
ronjenx's Avatar
Could be. I've seen only the type with a disable pin for reverse.
post #6 of 31 Old 07-29-2012, 08:28 PM Thread Starter
barry1me
barry1me's Avatar
not that im aware of.
Sport TJ build
barry1me is offline
post #7 of 31 Old 07-29-2012, 08:30 PM
robplumm
Just b/c the engine's capable....
robplumm is offline
post #8 of 31 Old 07-29-2012, 08:31 PM Thread Starter
barry1me
barry1me's Avatar
Factory boat trailer has 7 pin hookup(for reverse lights, and so brakes dont lock up in reverse)
Sport TJ build
barry1me is offline
post #9 of 31 Old 07-29-2012, 08:43 PM
jeeptrix
2009 JK Wrangler
That's an excellent point. I'm sure no one on the forum has broke any laws in their jeep or installed anything that would make it less safe than it was to begin with..
2009 Wrangler Sport JKU: 35" Mickey Thompson MTZ/17" Pro Comp Xtreme Wheels/ 3" BDS Lift/4:88 gears/ARB Lockers/ARB Air Compressor/Rugged Ridge Front Bumper/ Rugged Ridge 8500lb Winch/Cold Air Intake/Borla Dual Exhaust/Tuffy Underseat Security and Trunk Enclosure/etc. etc. etc.
jeeptrix is offline
post #10 of 31 Old 07-29-2012, 09:15 PM Thread Starter
barry1me
barry1me's Avatar
my point exactly....
Sport TJ build
barry1me is offline
post #11 of 31 Old 07-29-2012, 09:25 PM
maniacal_rick
Going off roading is one thing. Towing a boat on a freeway with other drivers/families around is different. Either way, good to know your JKU towed well.
maniacal_rick is offline
post #12 of 31 Old 07-30-2012, 08:04 AM
WXman
I guess I shouldn't have gone across the CAT scales at 11,000 GCW in my Jeep Liberty towing a flatbed with a load a few times? Oops..
If the JKU had a diesel engine, I'd tie even more than that onto the back of this thing...it's WAY more heavy duty and stable than a KJ. The ONLY thing that holds the JKU back from being the best tow rig in the entire Jeep lineup is the fact that the hitch mounts to a crossmember instead of mounting down both frame rails.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #13 of 31 Old 07-30-2012, 08:36 AM
ronjenx
ronjenx's Avatar
I'm not convinced that's the limiting factor.
The boxed cross member is welded to the frame rails, so the load ends up at the same place as a hitch that's bolted to the rails. The tow rating isn't based on the class of hitch installed.
post #14 of 31 Old 07-30-2012, 10:36 AM
Joe Diver
2009 JK Wrangler
Just about anything can pull it and get it going.
Controlling the load is the most important thing. Stopping it. Maneuvering it. Keeping it behind the vehicle.
Just because you "can" tow it doesn't mean you "should" tow it.
But I do agree that the long wheelbase JKU is probably an underrated tow vehicle.
2009 Sahara, Red Rock, auto, MyGig REN, Trac-Lok, remote start, soft top, Nuvi 765T, Escort X50 Blue, Cobra 29WXNW, Firestick II, Recovery Kit, Bestop Bikini Top, Soft Top Cover, Jeep Hood Bra
Joe Diver is offline
post #15 of 31 Old 07-30-2012, 10:40 AM
HurricaneRZA
Is the tow rating for the JK and the JKU the same?
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
Access through the firewall on a 2012 JKUR? socal_rubi JK Wrangler Technical Forum 17 07-10-2012 06:46 AM
2012 JKUR Build smooth9883 JK Wrangler Technical Forum 20 01-18-2012 02:12 AM
2012 JKUR Auto w/4.10 and 35's Impressions? Keiff JK Wrangler Technical Forum 2 11-07-2011 01:44 PM
2012 JKUR Auto Tranny + 35s = ReGear? PJ33P JK Wrangler Technical Forum 14 10-12-2011 01:22 PM
Towing this Toy Hauler with a JKUR? JK4Three JK Wrangler Technical Forum 52 03-31-2011 12:22 AM
