Using under body space - batter and/or air tank? - JeepForum.com
post #1 of 16 Old 08-30-2009, 11:29 PM Thread Starter
PrinceBondar
Using under body space - battery and/or air tank?
So, when I was under my Jeep changing the diff fluids the other day, I was admiring all that underbody space. I was wondering about using some of it for a second battery (I don't see any way to get one in the engine bay) and/or a small air tank (for example, Sears has a 135psi, 5 gallon tank for $25 - Craftsman 5 gal. Horizontal Air Tank, 135 psi), or possibly a PowerTank (CO2).
Thoughts?
PrinceBondar is offline
post #2 of 16 Old 08-30-2009, 11:59 PM
SaharaBlackNo1
Benchmark Designs makes an underhood dual battery kit:
I don't know that anyone has thought to run anything extra under their JK, especially a tank that probably wouldn't take too well to being beat up, considering the contents are under pressure. Although anything custom is always cool if done right. Most people seem to just end up mounting their air in the trunk area.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on...
SaharaBlackNo1 is offline
post #3 of 16 Old 08-31-2009, 12:07 AM Thread Starter
PrinceBondar
Hm....interesting. I don't see how they made the space. I'd love to see a writeup on that install. Update:$220?!?!!? Yowza! Pretty sure I could do a decent under body install for a lot less.
Yeah, it would have to be suitably armoured of course - that's a given.
Definitely not interested in that, for various reasons.
post #4 of 16 Old 08-31-2009, 12:58 PM
N2rock
N2rock's Avatar
Definitely can't mount a Co2 tanks. Co2 Tanks can not be laid flat, they must be at 45-degree or more... Actually I'll re-word that before someone comes and corrects me They can be stored flat, but can not be used while laying flat.
So if you mounted a Co2 under there, you would have to lay it flat in order to fit, and then you would have to pull it out & stand it up anytime you want to use it. That would be very impractical.
Now as far as a 5 gallon air tank- completely useless unless you have an onboard compressor filling it. A 5 gal tank would maybe fill up one tire, so you would need a compressor to replenish it... And 135psi would be inadequate to run air tools (if that was the plan).
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #5 of 16 Old 08-31-2009, 02:46 PM
dstephns
2015 JK Wrangler
Somehow compressed gas canisters and the underside of a jeep make me nervous.
2016 JK Rubicon
dstephns is offline
post #6 of 16 Old 08-31-2009, 02:50 PM
waterboarder
waterboarder's Avatar
Well, sounds like that wouldn't work anyway - so that just leaves the battery.
waterboarder is offline
post #7 of 16 Old 08-31-2009, 10:35 PM
Enforcicon
What about an axillary gas tank?
Now a Forum Supporter! Previously: Hyperjeevz
2007 JK Wrangler X (2dr)
255/75R17 Goodyear Wrangler SR-A's on 17" Rubi Wheels, 4.10 Gears/Tow Package, 6" KC Slim Lights w/ Windshield Mount, Rugged Ridge Tubular Side Steps, Rugged Ridge Headlight and Tail Light Gaurds, Brushed Aluminum Grill Inserts, Cool Tech Switch Panel, CB Radio w/ 4ft FireStik
Someday: Shrockworks Bumpers Front and Rear, 2-3 inch lift, Winch, etc...
Enforcicon is offline
post #8 of 16 Old 08-31-2009, 10:36 PM
waterboarder
I can't even afford to fill up the tank I've already got.
post #9 of 16 Old 08-31-2009, 10:41 PM
Enforcicon
x2 on the cost of gas.
But I only get about 210 miles per tank (give or take) and I don't think I could say no to extending the range I can drive between fill ups.
post #10 of 16 Old 08-31-2009, 10:47 PM
waterboarder
Yeah, I know. That was tongue in cheek (:
I'd love to have an aux gas tank. Probably wouldn't put it next to my aux battery though (:
I'd be more inclined to replace the stock gas tank with a bigger single tank. Going from memory - seems like there should be room to expand that sucker. I'd love to see someone do this mod so I could copy them (:
post #11 of 16 Old 09-03-2009, 04:18 PM
Enforcicon
Exactly how I feel. One larger tank seems like the way to go.
post #12 of 16 Old 09-03-2009, 06:10 PM
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
relocate the muffler and mount the air tank here... It is very out of the way. I have bent axles, knocked the rear bumper all over, bent my crossmember so bad I had to make a new one, broke rear shocks, etc. and this tank has been fine.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline
post #13 of 16 Old 09-03-2009, 06:13 PM
waterboarder
Nice mod!
That space on my jeep is reserved for storage area expansion though (:
post #14 of 16 Old 09-03-2009, 06:55 PM
N2rock
N2rock's Avatar
yes, but you have a compressor feeding that tank, right?
N2rock is offline
post #15 of 16 Old 09-27-2013, 11:10 AM
Josephus
Long Ranger Fuel Tank
http://thelongranger.com.au/jklongra...k.html#TA64PHD
This is the Long Ranger secondary fuel tank with heavy duty skid plating.
It is designed to tuck up inside the framerail just like the factory OEM fuel tank. Although not quite double the capacity, it does significantly improve your range.
It utilizes a transfer pump, so we get to use the same filler cap.
Problem is $1600 before shipping and installation.
As my Rubi is already built to within 50 lbs of the GVWR, I couldn't install it yet alone fill it with fuel (legally) :'(
Using that same location you could mount a few air tanks and make a 1/4" steel skid plate to protect it.
What? Just because i say it like it is - and you don't like it, doesn't make me evil. . .
or wrong.
Josephus is offline
Batter cable end is in 2 pieces? help mgaither0 Wrangler General Discussion 9 01-12-2010 07:39 PM
air compressor tank that doesn't take space. mikesbeachhut TJ Wrangler Technical Forum 32 09-08-2009 12:10 PM
What are the white plug things next to the batter for? JwlmanWu YJ Wrangler Technical Forum 4 07-22-2008 03:50 PM
wheel spacers. to space or not to space? Slickdaddydax YJ Wrangler Technical Forum 12 09-24-2007 09:55 AM
How much space between gas tank and floor Brindle19 YJ Wrangler Technical Forum 2 12-20-2005 04:17 PM
