Upper Dash Panel Removal (How-to Guide w/Pics) - JeepForum.com
post #1 of 11 Old 01-31-2010, 03:39 PM Thread Starter
DANJEEPO8
Since this topic comes up a LOT and I couldn't find a good thread on it, I figured I'd make a thread to help everyone out. Not that it's that hard, but anyhow...
DANJEEP08
DANJEEPO8 is offline
post #2 of 11 Old 01-31-2010, 03:53 PM
ribs
And now for the rest of the dash?
Originally Posted by notoriousdoa View Post
we had a peep hole looking into the girls jeep forum, but someone used it as a glory hole so they patched it up.
Originally Posted by LarryGrant View Post
...And no the truck dont give BJs but guess you are not married as wifes dont give them either. :rolleyes:
ribs is offline
post #3 of 11 Old 01-31-2010, 03:57 PM
Seanie
Unscrew the 4 screws on the 4 corners of the front of the dash (7mm I belive), and pop of the dash. Now you can get to your radio.
Seanie is offline
post #4 of 11 Old 01-31-2010, 04:00 PM Thread Starter
DANJEEPO8
Check the title of this post. It wasn't meant to be full dash removal guide.
Anyhow...if you want to get your radio out, all you have to do is loosen the two tops screws on the dash.
If you want to remove the bottom two, you need to pop the panel off the bottom first to get to them.
DANJEEP08
post #5 of 11 Old 01-31-2010, 04:02 PM
Seanie
I know, someone asked how to get the rest apart, so I threw in my $.02. Forgot about the lower panel though.
Seanie is offline
post #6 of 11 Old 01-31-2010, 04:37 PM
wilywillie
Cool! Instead of me trudging through the snow to go look, can you post their locations? (I have the Tuffy stereo cover/dish, so no easy accesss to top)
wilywillie is offline
post #7 of 11 Old 01-31-2010, 04:58 PM
Seanie
I got a picture of the dash from google images, and put arrows/dots at the approx. location of the screws. (the top ones are higher.. i dunno why I put them so low ) You'll see them once you get the top cover and bottom cover off (they both pop off, the bottom one all you have to do is put a screw driver under the top, pop it out, and it kind of pulls upward and out).
Once you get those 4 screws off, the dashboard around the radio all the way down to the bottom cover just pops off. It's hard to get off the first time because it's such a tight fit, but all need to do is pull from the bottom and put your fingers under it to keep it flat so it doesn't snap. It's pretty strong, so you should be ok.
Seanie is offline
post #8 of 11 Old 01-31-2010, 05:10 PM
wilywillie
Sweet! thank you!
the jack for my ipod is screwy, and I only get the DS speakers most of the time (depends on cord's position). Bought new cord, same problem....so I wanna pull the radio and check the set screws on the jack are tight before I cry warranty!
post #9 of 11 Old 01-31-2010, 05:29 PM
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
I posted a redirect to this thread on my mygig database thread, http://www.jeepforum.com/forum/f96/m...thread-960968/
and I credited the OP.
cheers.
p.s. if you have the daystar or whatever it's called, the aftermarket stereo cover, you just yank it up, no tools required.
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline
post #10 of 11 Old 01-31-2010, 07:15 PM
dirtyjpwrangler
It should be noted that if you have the compass, the compass component is wired to the inside of the dash panel, so be careful when pulling it off, it could be attached to wires.
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline
post #11 of 11 Old 10-06-2010, 04:59 PM
InDurango
Pics helped alot, thanks.
InDurango is offline
Dash panel removal help RogueStatus JK Wrangler Technical Forum 4 12-30-2009 10:48 AM
Upper Dash Panel? Hellbound13 JK Wrangler Technical Forum 17 04-19-2009 12:36 PM
Daystar Upper Dash Panel JK_Jeep JK Wrangler Technical Forum 14 04-08-2008 07:22 PM
panel removal? mytj TJ Wrangler Technical Forum 4 04-14-2005 10:19 PM
Dash Panel - Removal sky-raptor TJ Wrangler Technical Forum 11 12-15-2003 12:57 PM
