Quantcast Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION
Old 09-18-2008, 09:05 AM   #1
makstuss
Hello,
I just purchased a 2008 Wrangler Unlimited X, I am looking to upgrade the
tire and rims, P225/75R/16 with 255/70R/18. Is there any other modifications needed to make the change or anything I should look out for when doing so?
thanks, MAK
makstuss is offline   Reply With Quote
Old 09-19-2008, 01:39 PM   #2
kjcdc090385
I think that is still a factory size...so it should not matter if that is the case..it is like on a wj going from 225/75r16 to a 245/65r17 (not exactly the same but the same concept)...chances are if it is a factory size then there is nothing different between your wrangler and a wrangler that has them on it..just a guess though
and then when you switch..you can ship your old ones to me!!
kjcdc090385 is offline   Reply With Quote
Old 02-20-2011, 04:23 PM   #3
mdnky
2010 JK Wrangler
~ Michael
2010 Wrangler Sport, 6MT, 3.73, Shrockworks Stubby Front, BFG 255/85-16 KM2s (33.3" x 10), 16x8 ProComp 7069s, MileMarker HI9000, Bushwacker Flat Flares, Clarion NZ500, Boston Acoustics SL60 Components, Cobra 18 WX w/3' Firestick II.
mdnky is offline   Reply With Quote
Old 02-20-2011, 05:23 PM   #4
BlueLesPaul2006
Originally Posted by makstuss View Post
Hello,
thanks, MAK
Yes there is only one thing that you need to do. You will have to get Jeep to set your speedo to read the new tire size. that way you will be able to have a correct MPH reading. Or you can get a Superchips flashpaq. If your not planning on going bigger with tires or a lift than have your local dealer update the speedo. The tires will work just fine and will not rub since they are a stock size. I have the same JKU as you do and I run the 255/75/17 that the dealer put on before I bought it. I have had no issues.
OK, then...the hood is not supposed to flop up and down??
Dang, all this time and I thought it was the famous Jeep Wave!! ~bluegrassguitar
BlueLesPaul2006 is offline   Reply With Quote
Glock Forum
