Upgrade Shocks??? - JeepForum.com
post #1 of 3 Old 04-23-2009, 08:56 PM Thread Starter
kurtjohn
Upgrade Shocks???
I am new to the forum and have just taken delivery on my first Jeep ('08 two door Rubicon). Here goes. . . I purchased my Jeep primarily for weekend driving to/from my lake house on paved roads. I just just replaced the Goodyear's with Firestone AT Destinations. Routing handling (changing lanes, turns, etc.) seems pretty sloppy even with the new tires.
I understand the off-road design characteristics of the Wrangler suspension, but wonder if upgrading the shocks would improve handling? Any advice including brand preferences?
Your feedback is much appreciated!!!
Kurt
kurtjohn is offline
post #2 of 3 Old 04-23-2009, 09:56 PM
tricked919
I personally can't speak for the rubi shocks, but I know from a racing backgroud that compression dampening and rebound settings for a trail specific vehicle are FAR different than shocks designed for road manners. The biggest factor in the equation that your struggling with is the sway bar. Unfortunately I don't know of anyone making a thicker sway bar... if anything, as far as trail driving, they are a nuiscance. I took mine off. The tires are more of a traction thing - especially wet weather (when comparing what you got rid of vs what you have now), other than that, unless you reduced the size to have a shortr sidewall, the tires will have little impact on the "sloppyness" compared to the suspension elements that are the real cause of the poor handling.
Aside from performance parameters - I know my Sahara shocks that are supposed to be HD shocks are GARBAGE. The bushings are junk, the design is faulted and many guys have blown them out with moderate trail use. So to ask if anything would be an improvent over stock, I would have to say yes.
As for the limits of the road handling abilities - I assume this is your first Wrangler. These Jeeps are Ferrari's compared to the older Jeeps. Sloppy road feel is just something that comes with the turf. It ain't a Cadillac, or a Camry, or even a '85 Corolla. Its a Jeep and we should all be thankful that the JK is what it is. Aksing your JK to drive better on the road is no different that someone on a Porsche forum wanting to know what they can do to make their 911 more trail friendly.
tricked919 is offline
post #3 of 3 Old 04-24-2009, 12:41 AM
Swagger
Play with the air pressure a bit. I had to run mine way lower than specs. I have an aggressive mud tire, after mounting them on the Jeep it was all over the place......but when I got the tire pressue down to 27lbs it now rides great. Wearing very good as well. The chalk or water test is helpful to get the proper air pressure. Checking for proper tire pattern on pavement.
Hope that helps
Swagger is offline
Best headlight upgrade for a TJ that does not require new wire upgrade? rescue6 TJ Wrangler Technical Forum 95 06-10-2015 07:46 PM
rubicon express LA upgrade or clayton LA upgrade jeepin01tj TJ Wrangler Technical Forum 11 01-30-2010 07:05 PM
Upgrade Choices-Exhaust and Shocks tdola TJ Wrangler Technical Forum 11 03-24-2009 02:00 PM
Upgrade stock shocks... GoldenP51 TJ Wrangler Technical Forum 2 05-21-2006 05:53 PM
Upgrading Springs...Upgrade Shocks? Flyusaf2002 TJ Wrangler Technical Forum 3 03-27-2006 12:03 PM
