Unused console buttons - JeepForum.com
post #1 of 3 Old 11-17-2006, 07:52 PM Thread Starter
Diesel0312
Trying to hardwire the garage door opener into the Jeep and want to button beside the emergency flasher button to control it.
From feeling of it, it is stationary and not functional right now. Does anyone know what is behind it? Anyway to make it functional? If not, can I buy a functional blank button from Mopar?
I would like to use it since it would keep a factory appearance wouldn't require cutting any new holes in there.
Diesel0312 is offline
post #2 of 3 Old 11-17-2006, 11:07 PM
tcpatter
From what I was told, the whole unit (all 5 buttons) are one unit with a big circuit board connecting all of them. I was told that there isn't anyway just to swap them out with buttons.
tcpatter is offline
post #3 of 3 Old 11-18-2006, 12:27 AM Thread Starter
Diesel0312
If that's the case, then all that would need to be done is get the button moving and connect straight to the board.
I'm just trying to get as much info as possible on it, since I don't want to be taking the console apart several times, but instead only once when I'm ready to do it.
Unused wire under dash strip? Alexia TJ Wrangler Technical Forum 5 06-19-2016 08:18 AM
Taking out unused switch spots xxf3d3xx TJ Wrangler Technical Forum 8 02-22-2011 06:15 PM
Unused Electrical plug behind black switches? tophog TJ Wrangler Technical Forum 2 10-07-2009 02:08 PM
Pulling out unused wires drespecki YJ Wrangler Technical Forum 12 02-06-2007 12:46 PM
Can you identify these unused wiring harness connectors? gs2offroad TJ Wrangler Technical Forum 6 07-12-2005 03:24 PM
