Unlimited Sahara overall height after 4" lift and 37's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Unlimited Sahara overall height after 4" lift and 37's
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-03-2009, 03:57 PM   #1
ravenite SC
2009 JK Wrangler
Does anyone run a 4 suspension lift and 37's with a hardtop?
I am trying to figure out if I will fit in my garage after its lifted.
Im running a 4" Rough country lift with 37" Kumho KL71 tires
Can anyone with this type of set-up measure for me?
My math is as follows:
Overall height 72.1 inches + 2.5 inches (difference between tire size from stock) + 4 inches (lift) =78.6 inches
Garage opening 79.2 inches !!!!!
Anyone?????
ravenite SC is offline   Reply With Quote Quick reply to this message
Unread 09-03-2009, 04:44 PM   #2
gpb
Can't directly help you out, but a couple thoughts:
You might lose a little height due to the sidewall compression at the bottom of the tire. How much? No idea.
Don't whip it into the garage with the softop in sunrider position...
gpb is offline   Reply With Quote Quick reply to this message
Unread 09-03-2009, 04:55 PM   #3
Enforcicon
Also depends on the actual amount of lift you get vs. the advertised amount. I know some lifts tend to net more then promised.
Now a Forum Supporter! Previously: Hyperjeevz
2007 JK Wrangler X (2dr)
255/75R17 Goodyear Wrangler SR-A's on 17" Rubi Wheels, 4.10 Gears/Tow Package, 6" KC Slim Lights w/ Windshield Mount, Rugged Ridge Tubular Side Steps, Rugged Ridge Headlight and Tail Light Gaurds, Brushed Aluminum Grill Inserts, Cool Tech Switch Panel, CB Radio w/ 4ft FireStik
Someday: Shrockworks Bumpers Front and Rear, 2-3 inch lift, Winch, etc...
Enforcicon is offline   Reply With Quote Quick reply to this message
Unread 09-03-2009, 04:57 PM   #4
SaharaBlackNo1
With the hardtop on you will be right around 78 inches. I can just clear a garage that's 6'8" with the hardtop on or off. Can't make it with the soft top up though.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on...
SaharaBlackNo1 is offline   Reply With Quote Quick reply to this message
Unread 09-03-2009, 09:04 PM   #5
ravenite SC
2009 JK Wrangler
Thanks Saharablackno1
Thats what I needed to know. We are running almost the same setup. I remember you answering my previous posts.
