unlevel jeep - JeepForum.com
post #1 of 5 Old 09-16-2010, 06:21 PM Thread Starter
mtxhooligan
2010 JK Wrangler
unlevel jeep
i have a 2010 jk and the front end is about an inch or so lower than the rear. im wandering if most lifts will make it level once installed or am i going to need some sort of spacer kit as well. your help would be greatly appreciated.
thanks
mtxhooligan is offline
post #2 of 5 Old 09-16-2010, 07:09 PM
Charles
2017 WK
I've not seen a kit that doesn't (mostly) level it. You want some "rake" in it though because if you put any gear and people in it your jeep will be pointed up. Also, once you level, your hood is going to flutter. The wind pushed down on the hood pre-leveling, now, when it's level the wind will try to get under it.
Charles is offline
post #3 of 5 Old 09-16-2010, 07:12 PM
phdsk8
Unleveller TJ!
Mine is unleveled too. drivers front the most sagged and the passengers rear least! front and rear difference is 1".
Planning on BDS 2 " lift to fix that.
phdsk8 is offline
post #4 of 5 Old 09-16-2010, 07:27 PM
Charles
2017 WK
He wasn't talking about the "left to right" lean, he was talking about the rake that is there so the Jeep looks normal with full occupants and max towing payload. You're talking about both at the same time it sounds like. The left to right lean is called "The JK Lean". It is usually fixed by a spacer on the leaning side.
Charles is offline
post #5 of 5 Old 09-16-2010, 08:39 PM
wilywillie
Teraflex 1155200 - Teraflex Leveling Kit for 07-10 Jeep® Wrangler JK & Wrangler Unlimited JK - Quadratec
This is inexpensive, and it really helped my Jeep drive like a "Jeep". I can't recommend it enough.
wilywillie is offline
Jeep Unlevel lukera TJ Wrangler Technical Forum 6 03-07-2010 12:30 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
Jeep rear sits unlevel aklsufan TJ Wrangler Technical Forum 6 06-25-2007 02:26 PM
Rough Country4"x install, unlevel rear chutta TJ Wrangler Technical Forum 3 04-27-2007 07:16 PM
Looks unlevel after BB and BL 0blcktj6 TJ Wrangler Technical Forum 10 12-18-2006 09:31 PM
