UConnect Issues - Anyone Else? - JeepForum.com
post #1 of 6 Old 12-10-2010, 12:29 PM Thread Starter
02 Grand
2015 JK Wrangler
I just recently got a 2011 Unlimited in natural green. I have been a Grand Cherokee guy in the past (hence the screen name), but am really loving the wrangler.
I have started having some issue with the UConnect package. The phone functions stopped working as well as the USP drive in the center console. We have a pretty good dealer down here and messing around with go the phone functions to work again, but the USB is still not working. The drive has power and recognizes the thumbnail drive, but isn't able to read the files. The tech is trying to figure it out, but thought I would check in here to see if anyone else is having problems too?
I am just using a loaded thumbnail drive in the USB so I can't say for sure if the IPOD functionality is dead too. It all worked great at first, but...
Thanks
Now: '15 JKU Rubi
In the past: 05 WK, 02 WJ, 11 JKU
02 Grand is offline
post #2 of 6 Old 12-10-2010, 12:34 PM
Spank
2014 JK Wrangler
Was the USB stick/drive working before? How is it formatted? I don't believe MyGig/Uconnect units can read anything but a FAT32 file system from the USB port. If you formatted it for NTFS, it won't read it.
Spank is offline
post #3 of 6 Old 12-10-2010, 01:01 PM Thread Starter
02 Grand
2015 JK Wrangler
Good point, I should have mentioned that the USB functions worked great for the first month or so and then started failing all with the same drive.
Now: '15 JKU Rubi
02 Grand is offline
post #4 of 6 Old 12-10-2010, 01:07 PM
Joevacs
2010 JK Wrangler
every time I plug in a thumb drive to load music, mine tells me there is nothing to read. I leave it in anyway and it eventually reads it. Don't know why. It will also not transfer a whole CD if one little thing on the CD is unreadable.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #5 of 6 Old 12-10-2010, 01:44 PM
Spank
2014 JK Wrangler
Sounds like the Nav unit might be bad. I'd take it into the dealer.
Spank is offline
post #6 of 6 Old 12-10-2010, 07:00 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Be sure to close the CD session so it cannot be written again.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
how to add uconnect TYPHOON4X4 JK Wrangler Technical Forum 19 02-12-2010 04:36 PM
UConnect. yellowx13 JK Wrangler Technical Forum 5 02-04-2010 08:18 PM
UConnect Ole Yeller JK Wrangler Technical Forum 3 02-03-2010 02:19 PM
uConnect activation issues cwoodffr JK Wrangler Technical Forum 5 11-06-2009 08:00 PM
UConnect Grims JK Wrangler Technical Forum 28 02-21-2009 11:01 AM
