two questions - JeepForum.com
post #1 of 12 Old 05-09-2013, 04:57 PM Thread Starter
straight-pipe
two questions
first questions...one of my hood straps broke and I rednecked elastic bands to hold down as a temp solution, anyways can I just replace the elastic strap or do I replace the whole thing?
second question...concerning the front removable roof sections on the hard top, does anyone run the jeep without the rear bolt tie downs? just asking cause for easy on/off it would be nice to just leave it unbolted.
94 ZJ 5.2L
07 JK 3.8
straight-pipe is offline
post #2 of 12 Old 05-09-2013, 06:06 PM Thread Starter
straight-pipe
road-side hood latch repair
it may be ugly but it got me home met up with a highway tractor and the wind almost blew the hood off
94 ZJ 5.2L
07 JK 3.8
post #3 of 12 Old 05-09-2013, 06:26 PM
1222
RIP John
1222's Avatar
Damm I didnít think they could actually break like that. Could have turned out a lot worse; very lucky.
1222 is offline
post #4 of 12 Old 05-10-2013, 09:18 AM
222Doc
222Doc's Avatar
i put a heavy duty zip tie on mine. no futter. But you can buy the daystar(?) rubber one. There is a thread here on this somewhere, buried like Jim Hoffa.
222Doc is online now
post #5 of 12 Old 05-10-2013, 09:55 AM
Godholio
Based on advice here, I stopped using the bolt-cup things in the soundbar about a year ago. No problems, not a drop of water or any extra noise.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #6 of 12 Old 05-10-2013, 01:20 PM
222Doc
222Doc's Avatar
I did the reverse. removed the rear hard top left the front panels. The panels have a flip down foot, then the bolts hold it down. been like this most of its life now.
post #7 of 12 Old 05-10-2013, 01:28 PM
Astennis1
I forgot to put those bolts back in and I haven't seen an issue. I drive back and forth from Texas to Mississippi going 75-80mph so I assume its okay. Ill let you know if I loose them going down the road.
I LOVE LAMP
13 JKUR
Astennis1 is offline
post #8 of 12 Old 05-11-2013, 01:30 AM
HOKIES2010
2011 JK Wrangler
Never used the bolts and the daystar latches are a cheap and super easy upgrade. Not a hint of wobble in the hood at 80 mph.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #9 of 12 Old 05-11-2013, 06:45 PM Thread Starter
straight-pipe
Thanks guys I added a pic of the rubber band roadside repair haha still makes me laugh every time I see it. Anyways I ordered new Daystar latches and the price way sweet! Called a local dealer here and they wanted something like 50 bucks a pop! found the Daystars on E-bay, 2 for 32 bux and I found a windshield hood bumper for 8 bux. awesome!
94 ZJ 5.2L
07 JK 3.8
post #10 of 12 Old 05-14-2013, 05:42 AM
Remmy18
X2. Running with the freedom panels only is what the screw pins are for.
Remmy18 is offline
post #11 of 12 Old 05-14-2013, 11:38 AM
Spike6901
Same here, daystar latch rubber and no bolts, hell, I only use a total of 4 bolts for the hard top when its on...no problem.
'17 JKU, '97 ZJ - Built
Past: CJ-7, XJ, KJ, JKU
Spike6901 is offline
post #12 of 12 Old 05-31-2013, 01:56 PM
sgtmajor138
2009 JK Wrangler
Just ordered a set from http://www.quadratec.com/ for $24.99 for my '09 JKU. I have bought these before for other TJs I have had in the past and they are a super upgrade to the OEM straps.
'09 JKU Wrangler - Seize the Opportunity!
sgtmajor138 is offline
