Turn Signal Relay - JeepForum.com
post #1 of 5 Old 06-18-2011, 08:23 AM Thread Starter
whitejeep2010
2010 JK Wrangler
Turn Signal Relay
I switched out to LED lights on a 2010 Wrangler. Anyone have a good how to on locating/changing the relay? Thought it would be located in the fuse/relay panel, but that doesnt appear to be so.
Also interested in knowing where people got thier relays; local parts shops say they don't have one for a Jeep that new. Now I know that Wranglers are known for being right out front on new technology and all, but I think there is likely a pretty run of the mill relay I can get.
Thanks,
whitejeep2010 is offline
post #2 of 5 Old 06-18-2011, 08:39 AM
ronjenx
ronjenx's Avatar
The JK has no turn signal relay. It is all computer driven.
The noise you hear when the turn signal is operating is an electro-mechanical device whose only function is to produce the sound we are all so familiar with.
The computer sends the pluses to it and the turn signal lights.
If you are having trouble with the speed of the flashing, due to decreased load, you may have to install a resister in each circuit.
There may be a thread on this here, or one of the other forums.
ronjenx is online now
post #3 of 5 Old 06-18-2011, 08:45 AM Thread Starter
whitejeep2010
2010 JK Wrangler
Thanks. Any ideas on how I can deal with fast blinking LED's? Do I just need to install load equalizers on each blinker?
post #4 of 5 Old 06-18-2011, 08:48 AM
ronjenx
ronjenx's Avatar
I must have been adding to my post when you posted.
Do a search for LED turn signal lights for info on increasing the electrical load.
post #5 of 5 Old 06-18-2011, 09:14 AM
versoel
2009 JK Wrangler
poison spyder customs sells the resistor that you splice in line to adjust your blinking speed for LEDs.
http://shop.poisonspyder.com/LED-Res.../41-04-650.htm
09 JKU Rubi, 37s, 3.5 Rock Krawler lift with 3 link rear
versoel is offline
electrical , relay , turn signal , wtf
Turn Signal Relay Wacky happy_guy TJ Wrangler Technical Forum 1 02-24-2011 05:55 PM
Turn Signal Relay rvsmith88 TJ Wrangler Technical Forum 5 10-03-2010 04:13 PM
turn signal relay deerslayersh TJ Wrangler Technical Forum 1 06-17-2010 03:43 PM
Turn Signal Relay?? rich_87_03 TJ Wrangler Technical Forum 4 04-18-2007 05:33 PM
LED Turn Signal Relay Cale TJ Wrangler Technical Forum 2 10-14-2006 07:18 AM
