-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Tru-Lok Inner Workings (http://www.jeepforum.com/forum/f96/tru-lok-inner-workings-941135/)
ronjenx 01-05-2010 02:40 PM
Someone on another forum asked how the Tru-Lok on the JK works.
This is what I posted. Thought some people here might be interested, too.
Reference the picture below.
The Electromagnet causes the Moveable Dog Clutch to engage the square teeth on the side gear.
This locks the side gear to the differential case, making the side gear turn only with the case.
This makes the spider gears unable to spin on their pins.
Since the spider gears can not spin, they drag the other side gear around with the case.
In the JK Tru-Lock differential, there are 4 spider gears, not just two as pictured.
End result: Both axles have to spin with the differential case, all as one unit.
http://i776.photobucket.com/albums/y...ockUp-Diff.jpg
MattJK09 01-05-2010 03:26 PM
I'm lost, but very informative post! :2thumbsup:
USAntigoon 01-05-2010 06:02 PM
Here is some more background music....:thumbsup:
S_Bartfast 03-12-2015 03:52 AM
I've spent a lot of time trying to find information about how the Rubicon locker works and keep coming across this thread.
A couple of years after this thread was made an absolutely fantastic thread was started on this same forum that explains everything really clearly but for some reason this is the thread I keep coming across. I know this thread is now rather old but I thought I'd post a link to the OEM Rubicon Locker Study thread to guide others following the same footsteps as me.
Enjoy: http://www.jeepforum.com/forum/f96/o...study-1476570/ :thumbsup:
LIJeepJC 03-12-2015 06:24 AM
Can you engage, or SHOULD you engage the lockers when driving on say a snow covered road? Or is it strictly for low speed crawling?
jwmbishop 03-12-2015 07:27 AM
Without modification the tru-lock can only be engaged in 4lo.
I would not lock my axles in snow and especially not in snow above 30mph. Reason is when locked the rig does not want to turn (rear wheels both turning at same speed wants to understeer, so more steering input is required). Snow ice etc takes away the front traction, no front traction and severe understeer could be very disastrous.
ronjenx 03-12-2015 07:47 AM
To add to that, lets say you have the rear locked, and the tires lose traction. The rear end can, and probably will, swing to one side, leaving you headed for the ditch, or on-coming traffic.
Unlocked, one tire can spin while the other retains some traction to keep the vehicle straight.
LIJeepJC 03-12-2015 08:43 AM
Makes sense... Thanks!
paul84043 03-12-2015 08:44 AM
This is always a contentions subject with people's opinions spanning the full range....
If you're in 4wd, we're assuming that conditions are bad and hopefully you're not driving very fast... The faster you're driving, the less you're going to be turning so the locker "shouldn't" rear it's ugly head. The side slip should only manifest in low speed driving like turning at in intersection.
You'll find people that have had auto lockers for decades and swear by them. You'll also find people that say lockers will murder your pets in their sleep....
Personally I put an LSD in the rear of mine and a full locker in the front. So far, it's been invisible.
There are some fantastic older videos on YouTube that show step by step how a differential and locker works..
The guy that invented the Diff was a freaking genius.
jwmbishop 03-12-2015 09:30 AM
Absolutely. And I think a GOOD "mechanical operator" can support either style.
Its just not an anticipated vehicle reaction set I prefer!
I kinda like your approach... is your front a detroit or selectable? (I tend to lean away from detroits in front - possibly the old front drive drag experience... no other real world experience)
The time now is 05:42 PM.
