Trouble Starting 2008 RHD Wrangler - JeepForum.com
post #1 of 3 Old 08-04-2010, 08:24 PM Thread Starter
bdobbi
We have intermittent cranking problem with the Jeep. Most of time, it cranks fine. But, periodically it clicks like a dead battery when you turn the key. Try several times and it won't crank. Then, it may crank on the next turn. Use to could tap the battery connection and it might crank or take the connection loose and then reconnect and it would crank. Neither works consistently, though. This week, had it towed to dealer and then it cranked every time for them and they said they couldn't diagnose anything wrong. There is another postal carrier in the Post Office that has the same Jeep and it is doing the same thing. Dealer says nothing is showing on their machines and it cranks every time for them. Any ideas?
bdobbi is offline
post #2 of 3 Old 08-07-2010, 08:12 AM
okie63
Hey Dobbi.
I did a search on my wife's converted RHD 07 and found a site that listed a number of TSB's (Technical Service Bulletins)for the Wranglers. Seems jeep has one out for no crank. Here's the link;
Project-JK.com - Jeep JK Wrangler Resource Electrical TSB
okie63 is offline
post #3 of 3 Old 08-08-2010, 07:51 AM
Bakers4Pack
I know how you feel, we have had 4 - 5 trips to get our starting problems fixed. We have had a battery cable replaced, Starter replaced and an assortment of switches replaced. Just about every time the darn thing would start just fine in the shop at the dealership. It was very sporadic and would happen at the worst time. So we had a remote start installed and that would work no matter what. The next to the last visit to the dealership fixed the starting problem for about a week and then the jeep completely stopped starting using the key. I figured that this was a good thing, so that finally the dealer may see it not starting. I can happily say that it has started each and every time since my last visit. I highly recommend getting the remote start put in. This will help the non starting times. One last thing, there was no apparent rhyme or reason to the timing of the no start. Sometime is would happen on cold starts, short trips or long trips. It did not matter which key we used either. Mine would eventually start after about 15 - 20 minutes. That kinda sucks when you need to pick up your kids from school.
Missy
'08 JK Rubicon Unlimited ~ Detonator Yellow
Bakers4Pack is offline
battery , crank , starter
2008 JK Starting Problems stereoman03 JK Wrangler Technical Forum 102 08-06-2016 12:07 PM
98 Wrangler trouble starting jkburros TJ Wrangler Technical Forum 3 02-27-2010 12:29 PM
'89 YJ 4.2L has trouble starting up case'sjeep YJ Wrangler Technical Forum 3 01-24-2008 02:44 AM
Trouble Starting coachtucker9 YJ Wrangler Technical Forum 12 03-12-2007 06:55 AM
Trouble Starting Sometimes killamike YJ Wrangler Technical Forum 1 04-21-2005 08:23 PM
