Trimming Pinch Seam - Seems Dangerous - JeepForum.com
post #1 of 11 Old 01-30-2013, 11:43 AM Thread Starter
screameans73
2010 JK Wrangler
Hello all.
My JKU is currently sitting on 33" tires on 20" wheels. After a few times out and running some easy to moderate trails and hitting some rocks and stumps I'm not real comfy with the sidewall in my current set up and I'm considering moving to a 16" or 17" wheel and 35" tires.
From what I gather from the FAQ tire and wheel section, I should be good considering I have a 3" lift and stubby front bumper. But just in case, what's the best way to trim the pinch seam?
I attached a pic to give some idea as to my lift and bumper clearances.
Thanks in advance.
screameans73 is offline
post #2 of 11 Old 01-30-2013, 12:09 PM
DBA2GO
So, besides a great looking Jeep, what is the question?
Guess #1: Do you need to trim pinch seams w/ 3" lift & 35" tires: yes.
Guess #2: Will your bumper rub: don't know - test it.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #3 of 11 Old 01-30-2013, 12:09 PM
MeatCurtains
Mark the cut off with some tape and cut the seam off with your choice of cutting tool, I prefer a cut off wheel. Fill the hole that is left with a quality epoxy and let it cure. Check it for gaps fill and repeat until sealed. Then paint it with a rust protectant paint.
Not as hard as you would think. Just take your time don't be in a hurry
MeatCurtains is offline
post #4 of 11 Old 01-30-2013, 12:17 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Not sure the epoxy is needed. Expanding foam or body putty works just as good with less hassle.
But - hey - epoxy will bond forever.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 11 Old 01-30-2013, 12:38 PM Thread Starter
screameans73
2010 JK Wrangler
Thank you very much!
Guess#1: Exactly, and crap....
Guess#2: Will do, I plan to ditch the rear bumper and stock carrier for an Ace bumber and carrier, that I "think" is shorter so rubbage may not be an issue there, but I won't know until it's installed obviously.
post #6 of 11 Old 01-30-2013, 12:43 PM Thread Starter
screameans73
2010 JK Wrangler
Not as hard as you would think. Just take your time don't be in a hurry.
Does this create any more vibration in the body? Also, am I looking to cut it diagnally or across and then down? Will either direction cause an issue with nearby welds?
I like forever, and won't mind the extra time it takes. Heck, I plan on finding a cutting tool and a really long extension cord before sneaking into a junk yard and "practicing" lol So patience is something I will definitely use.
post #7 of 11 Old 01-30-2013, 12:47 PM
brianjw
Careful if you cut deep, there is expanding foam crap back there and it is very flammable. I had a lot of smoke coming from my fender when the last piece fell out with foam. I thought "surely they wouldn't put something highly flammable in all the cavities", so I put a lighter to the little piece that fell out and "poof!"
Using a recip saw would probably create a lot less heat.
brianjw is offline
post #8 of 11 Old 01-30-2013, 12:48 PM
MeatCurtains
You are only cutting off a little piece.
post #9 of 11 Old 01-30-2013, 12:48 PM
DBA2GO
No
I'm guessing you're kidding; but, IMHO I wouldn't sneak into any junk yard unless I knew the dogs the owner lets out at night.
DBA2GO is offline
post #10 of 11 Old 01-30-2013, 12:53 PM
Demp
That video gives a decent description. Using a sizable rotary tool as he does definately simplifies versus a tiny rotozip or dremel. Reminds me that I need to get a new one, F little dremels.
Edit: Because Meat posts faster than I do AGAIN
Demp is offline
post #11 of 11 Old 01-30-2013, 01:06 PM Thread Starter
screameans73
2010 JK Wrangler
Thanks for the tip, I don't think GEICO would cover me if my Jeep went up in flames and it never occurred to me that noise suppression material would be in there.
Awesome, appreciate the video, that helps alot.
Correct, the junk yards are way to risky. My idiot neighbor kids Vega is much less dangerous, and I won't need as long of an extension cord Kidding again.
Edit: Because Meat posts faster than I do AGAIN .
Appreciate the input. I've used Dremels for radio control gas cars, but man....just thinking of using it for this makes my head spin.
For some reason it seems what I'm giving up in the 20" rims and gaining in the 35's would be a wash. I'm missing something here I'm guessing.
