Transmission crossmember+Tree Stump! Pics - Page 2 - JeepForum.com
post #16 of 22 Old 10-27-2013, 08:24 AM
brianjw
An afe y pipe will move the cross pipe behind the cross member and above the skid plate. They also sell an exhaust loop delete kit.
brianjw is offline
post #17 of 22 Old 10-27-2013, 08:32 AM
Yendor
The most interesting thing to me, was how the tree stump jumped out of no where. Around here, tree stumps pretty much stay anchored to the ground, and don't move. But deer..... You have to watch for those.
Yendor is offline
post #18 of 22 Old 10-27-2013, 03:28 PM
Jollydodger
Originally Posted by brianjw View Post
Synergy has a center skid with a heavy duty cross member all in one. It looks great in pictures but I haven't a clue how you service your aftermarket drive shafts with it. The skid doesn't separate from the crossmember!
I have one of these I just put in, the driveshafts are accessible, the trans pan (auto) however is not.
Jollydodger is offline
post #19 of 22 Old 10-27-2013, 06:54 PM
brianjw
Have any good pics? I'd like to see some better angles of it if you get a chance.
brianjw is offline
post #20 of 22 Old 10-28-2013, 08:14 AM Thread Starter
Mfrancis
2014 JK Wrangler
I'd like to see that too. The problem I'm facing with my issue of the op is the front lip of the skid plate is bent completely back over the bolt to remove it. I read through the instructions for swapping to the poison spyder cross member, and it says to brace the transfer case before removing it. If I can't get it bent enough to get to the bolt to remove the skid, is cutting it out my only option?
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #21 of 22 Old 10-23-2014, 10:10 AM
davekrick
JK aFe Y-Pipe
Hi brianjw,
I just installed the JK aFe Y-Pipe and loop delete. By looking at your picture I see that the y-pipe is either close to or touching the transfercase bolt. On my installation the pipe is touching the bolt and I get a rattling sound when I hit bumps and so on. I wanted to know if you are experiencing the same issue and if there was a fix you did to avoid this. Thanks.
davekrick is offline
post #22 of 22 Old 10-23-2014, 03:10 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Not to hijack - just wanted to share - it's the jumping out in front of you part that you have to watch out for and its not just trees - in my parking lot the light posts dart in front of you with no warning at all and NO ONE is immune....
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
