Transmission crossmember+Tree Stump! Pics - JeepForum.com
post #1 of 22 Old 10-20-2013, 07:36 PM Thread Starter
Mfrancis
2014 JK Wrangler
I hit a tree stump that jumped out of nowhere. It hit the transmission crossmember just right. Crazy how it just missed the exhaust. These pics are from the driver side looking to passenger.
[ATTACH][ATTACH][ATTACH]Name:  DSC01128 (800x600).jpg
Size:  263.4 KB[/ATTACH][/ATTACH][/ATTACH]
This is the rubber pad connecting to the transmission. A little out of whack, but still intact.
Name:  DSC01130 (800x600).jpg
This is the front of the skid plate bent completely over the bolt that attaches in the front.
Name:  DSC01131 (800x600).jpg
Nothing else is damaged other than the skid plate and the crossmember itself. It looks pretty easy to disassemble to put a new one on, mopar.com says $377. The lift fund takes another hit
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #2 of 22 Old 10-20-2013, 07:45 PM
brianjw
Poison spyder makes a heavy duty crossmember. My 2013 crossmember is a little "tacoed" from rocks too. Surprisingly the skid plate held up but the crossmember is bent.
brianjw is offline
post #3 of 22 Old 10-20-2013, 07:46 PM
brianjw
Also, damaging anything stock is the best reason ever to upgrade to quality aftermarket stuff. Sometimes I intentionally do this and show my wife "look, see that?! I have to buy stronger parts!"
brianjw is offline
post #4 of 22 Old 10-20-2013, 08:00 PM Thread Starter
Mfrancis
2014 JK Wrangler
I haven't gotten that far to look into HD ones, good info. I hit it just right, looks like it was almost designed to crumple that easy.
Mfrancis is offline
post #5 of 22 Old 10-20-2013, 08:04 PM
awinski
same thing happened to my four door. ran it for months after without any problems haha
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #6 of 22 Old 10-20-2013, 08:12 PM
1222
RIP John
1222's Avatar
Well Iíd say you were very lucky if you can call it that, being that you didnít take out your exhaust too; must have been one hell of a jolt to say the least.
1222 is offline
post #7 of 22 Old 10-20-2013, 09:04 PM
SubAtomicGenius
2011 JK Wrangler
Stock crossmembers are POS, any HD series are great. Only disadvantage is the stock chassis mounts are still flimsy when using an aftermarket crossmember.
SubAtomicGenius is offline
post #8 of 22 Old 10-21-2013, 09:57 AM
jay1335
You are lucky you didn't crumble your tcase!! Had a stump do the same thing to an xj I had but I destroyed my tcase. Def upgrade to a stronger cross member. It will offer more strength and more coverage. That'll be one of my next mods on my 13 jk.
My Build Thread -
jay1335 is offline
post #9 of 22 Old 10-21-2013, 10:17 PM
73azbronco
Kudos for missing the exhaust pipe, if it was me, I would have taco'd the exhaust, and missed the crossmember.
73azbronco is offline
post #10 of 22 Old 10-22-2013, 12:28 PM
SoK66
2009 JK Wrangler
When I went to a long arm suspension I had to get rid of the Synergy main skid I had installed previously. Since I had the Synergy oil pan/trans & t-case skids I opted for their "budget center piece and used aPoison Spyder crossmemeber. Whole thing fit together perfectly and the crossmember is bulletproof.
SoK66 is offline
post #11 of 22 Old 10-23-2013, 12:10 AM
brianjw
Synergy has a center skid with a heavy duty cross member all in one. It looks great in pictures but I haven't a clue how you service your aftermarket drive shafts with it. The skid doesn't separate from the crossmember!
brianjw is offline
post #12 of 22 Old 10-26-2013, 09:03 PM
SoK66
2009 JK Wrangler
That's the one I was refering to. it wouldn't work with a TF long arm without serious modification, so I replaxed it with a PSC crossmember and the Synergy "budget" center skid.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #13 of 22 Old 10-26-2013, 09:07 PM
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Yeah, you were lucky it didn't take out the exhaust pipe (good reason to always carry a hack saw, btw). I bet that was one helluva jolt!
A little duct tape and it'll be as good as new/stock.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #14 of 22 Old 10-26-2013, 10:11 PM
222Doc
222Doc's Avatar
Go with a flat belly and ditch that cross member. That is what I am hopping to get done in the next year. Jk's have a lot of belly up that can be done its just so freeking expensive. But that way nothing is below frame.
222Doc is offline
post #15 of 22 Old 10-27-2013, 08:55 AM Thread Starter
Mfrancis
2014 JK Wrangler
Is there any way to tighten up all the low hanging exhaust?
Mfrancis is offline
