Transmission Cooler - Page 3 - JeepForum.com
post #31 of 55 Old 06-23-2012, 06:49 PM
bigapplephx
2009 JK Wrangler
AUX Transmission Cooler
The early TJs with the 42RLE Transmission had the transmission oil cooling in the radiator.
The JK 42RLE transmission cooling is in the lower portion of the AC condenser, in front of the radiator.
It is my personal belief that the cooling of the transmission oil by the AC condenser is the reason for the transmission hot oil light so many JKs have experienced. You very rarely had trans hot oil in the TJs.
Anyway, in my 09 JKU Rubicon, I installed a Derale finned cooler on the rail in front of the condenser. The 17" long cooler holds 28ozs of trans fluid which aids cooling. It's mounted low so it does not restrict airflow to the radiator/condenser. I measured oil temp with a lazer thermometer at the pan, after a long hot run in AZ (100 plus degrees) the pan temperature was 180degs, oil cooler was 145degs.
bigapplephx is offline
post #32 of 55 Old 06-23-2012, 07:12 PM
Ben_88Jeep
2010 JK Wrangler
I agree it's the design. I think if anything they should have used the top 2/3rds of the system to cool the transmission... I've altered my system to use the entire cooler since I have no A/C on my Jeep. System works great and because it gets the needed airflow, my transmission remains a lot cooler even under demanding situations.
Ben_88Jeep is offline
post #33 of 55 Old 06-23-2012, 07:20 PM
SoK66
2009 JK Wrangler
Aside from having insufficient capacity, placed where it is at the bottom of the A/C condenser the pre '12 JK automatics trans cooler gets virtually no air flow. One step above utterly useless.
SoK66 is offline
post #34 of 55 Old 06-23-2012, 07:36 PM Thread Starter
waterboarder
waterboarder's Avatar
Well, AEV bumper and winch has to come off to get this stupid thing installed, so it is an all weekend job. I dunno when I'll get it done.
waterboarder is offline
post #35 of 55 Old 06-23-2012, 07:59 PM
ncb
Can you take the grill of for access instead of pulling the bumper?
ncb is offline
post #36 of 55 Old 06-24-2012, 12:50 AM Thread Starter
waterboarder
Can't get the grill off with the bumper & winch in the way, that's why they have to come off.
post #37 of 55 Old 06-24-2012, 06:00 AM
ncb
This is good to know. I'm thinking about purchasing this bumper. I thought there was a way to mod the lower portion of the clips on the grill so it could be removed with the bumper in place. I'll see what I can find.
ncb is offline
post #38 of 55 Old 06-24-2012, 10:07 AM Thread Starter
waterboarder
Definitely install a trans cooler and replace stock headlights BEFORE installing this bumper. Also, make sure you get the winch you want before installing it too.
post #39 of 55 Old 06-24-2012, 10:36 AM
jrmars07
2010 JK Wrangler
You can... You have to basically bend off the clips and you might scrape the paint of your grill that you cant see anyway... Its a real pain I think it took me 20minutes of pulling and prodding around with a long flat head to pop it off. And then once I had it off I trimmed the bottom clips so it will be easier next time.
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #40 of 55 Old 06-24-2012, 04:35 PM Thread Starter
waterboarder
It's not a matter of clips - with my winch in the way, there is physically no way to pull the grill out at the bottom. It's got nowhere to go, the winch is in the way.
Can't get the winch off without taking the bumper off.
post #41 of 55 Old 07-22-2012, 04:14 PM Thread Starter
waterboarder
I have an appointment at the local dealer on Thursday to have installed the Mopar aux trans cooler I bought on-line. They said they would charge me $192 - accounting for the bumper. That's worth it for me, to not have to mess with it.
Looking back at my previous posts, I wrote:
Update: So, I called them back with this part number (82212486AB) to see what they would have to say. $300 for the part, $566 with installation. I can get the part for about $266 on-line, shipped - so that means it is $300 to install.
So, I don't know if they're keeping track of what they say, or what, but now I'm getting a savings of about $75 on the install, and I'm still saving about $35 on the part, so I'm about $110 cheaper than I was at the beginning of this thread. So, that's cool.
Now let's just hope they don't come up with some BS reason to increase the price. If not, then my total P&L cost is about $458.
post #42 of 55 Old 07-22-2012, 07:43 PM
mrbillbrown
2010 JK Wrangler
So you called the dealership and said... "I have my Mopar aux cooler in hand, an AEV premium bumper, and a winch (mine happens to be a Warn 9.5ti). How much to remove the bumper/winch, install the cooler, then replace the winch/bumper?" Then they quoted you the $192 out the door price?? I'm dreading putting my cooler on because of that damn bumper/winch combo. I think I'd gladly pay the $200 to have them do it. Just curious how much grief they gave you when you called.
'10 JK Rubicon Unlimited, AEV front bumper & skid w/ Warn 9.5ti sitting on top
mrbillbrown is offline
post #43 of 55 Old 07-22-2012, 09:44 PM Thread Starter
waterboarder
No.
I was picking up my vehicle from them after a repair, and I asked them how much it would be to install it - pointing out that I already had the part. He quoted me $199. Then I reminded him that I have the bumper, and I wanted him to come out and look at it to be sure - because I didn't want any price increases later - then he looked at it, and told me to send him the PDF for the install. So I did, and he said he would check with the mechanic who would do it - and he did, and then he said they would do it for $195.
post #44 of 55 Old 07-27-2012, 03:22 PM Thread Starter
waterboarder
So, I dropped it off at the dealer on Thursday around 8AM. Around 1:30PM or so, I got a call from the dealer.
1). Turns out they DO have to take the bumper off, and this is more work than they anticipated, but they are going to stick to the original quote.
2). They need the winch controller (which is at home).
3). Turns out I have a transmission line leak (not part of this install), that is going to cost $300 to fix (P&L).
My response is:
1). Thank you for sticking to the original quote.
2). I'll bring them the winch controller.
3). My Jeep is under warranty.
When I tell the service adviser #3, he says something like, "ooooh, you have warranty. OK, we'll go ahead and fix that then - but Jeep is probably not going to be ready until tomorrow." That's fine - I'm in no hurry.
So, today I go pick it up at noon. I check out, pay my $195 - and before I leave, I ask how long it took to install the aux trans cooler. The answer? FIVE HOURS (including taking the bumper off and putting it back on) - and he clearly was not pleased about it. I am SO glad I spent the money to have them do it! If it took them 5 hours, it would have taken me all weekend. PLUS they noticed the other thing leaking and fixed that (which took time on top of the 5 hours). So, overall, a win for me.
Total cost of P&L for the aux trans install was $476.
post #45 of 55 Old 07-27-2012, 03:30 PM
ronjenx
ronjenx's Avatar
I would be suspicious as to whether or not there was an actual leak. Could have been a plan to gain some compensation for the extra labor.
Look at all your transmission cooler lines for the following, including the lines at the side of the transmission:
ronjenx is offline
Transmission cooler pwcracer TJ Wrangler Technical Forum 36 08-15-2012 07:30 AM
Transmission Oil Cooler jeepadactyl JK Wrangler Technical Forum 2 07-17-2010 11:41 AM
Transmission cooler Telnet TJ Wrangler Technical Forum 4 07-11-2010 05:04 AM
Transmission Cooler Toltecatl TJ Wrangler Technical Forum 26 03-05-2010 10:32 AM
Which Transmission Cooler? cvd TJ Wrangler Technical Forum 15 12-10-2008 06:17 PM
