-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Transmission broken? (http://www.jeepforum.com/forum/f96/transmission-broken-1633081/)
orangera1n 09-28-2013 09:57 PM
So today I was picking up my girlfriend at her house. Now she lives on a bumpy road and I was having fun splashing around and hit a bump kinda hard and afterwards I started hearing a loud buzzing noise like metal vibrating. I just ignored this noise because my jeep makes that noise all the time with the heat shielding. Now after I picked her up me and another jeep buddy headed towards a new offroad spot. However once we got there, the notice turned into a loud grinding noise at around 25mph. I foolishly ignored it again... So we enter the offroad place and there's mud and water about as high as a foot and some areas up to the door line. Everything was okay until all of a sudden I hear this very loud grinding noise them the "hot oil" light came on with a p0218 code. Hot transmission oil. I shut the engine off and waited about 5 mins then turned her back on and turned back towards the exit. I ran into the same error and alarm about 6 times before getting out. Along the way out I heard grinding noises and what sounded like ungreased bolts turning (sorry it's hard to describe). After getting out the noise continued for about 5 miles then going away only to rest urn with a different noise (sounded like a ungreased merry go round). I checked the tranny oil, it's tannish. Any advice?
ronjenx 09-29-2013 05:16 AM
Originally Posted by orangera1n (Post 16399593)
Any advice?
Move to where there is a good public transportation network.
orangera1n 09-29-2013 05:41 AM
Any real advice on the PROBLEM.
orangera1n 09-29-2013 07:17 AM
Follow up:
Took a look this morning. Transmission caked in mud and heat shielding was wrapped around it.
Is the transmission just prone to overheating?
rirrgang 09-29-2013 07:43 AM
Caked in mud? Yes, over heating will hapen. It's also prone to failure if you don't heed the warning signs and continue to abuse the JK the way you did. Hope it was worth it?
JIMBOX 09-29-2013 08:02 AM
:cool:I haven't got much I can say to mud dubbers, but
Take your water hose and clean the radiator/FAN/tranny/Driveshafts/entire bottom of jeep and stay away from mud-
:rofl::rofl: JIMBO
orangera1n 09-29-2013 08:03 AM
No when the warning signs came on I shut down the jk and let it cool off. And I did not know how muddy it was till this morning.
Jiblet 09-29-2013 08:57 AM
The correct response to the hot oil warning is to stop driving the vehicle and run the engine at idle or faster, with the transmission in neutral until the message turns off.
Need to keep the overheated ATF flowing or it just sits and bakes.
orangera1n 09-29-2013 10:07 AM
Yeah it's weird though. Never had this issue before and my jeep gets muddy all the time. My friends TJ had no problem where we were at. I just got worried because the noise I was hearing from the bottom of the car and it was too dark and late to check under it. Thinking about adding a aux transmission cooler. Would this help for mud or no?
JIMBOX 09-29-2013 10:30 AM
:cool: I don't know how long you've had this '08, but
It shoulda hadda aux cooler 5 years ago--because of the auto,cooling design, an aux cooler is REQUIRED FOR EVERYTHING--
google "JK aux cooler"
Good luck
:tea JIMBO:
jabsther 09-29-2013 10:44 AM
I think me meant the noise that you kept hearing getting louder was the warning sign not the idiot light/ warning.
Ruby_Tuesday 09-29-2013 03:44 PM
Best advise. Stay out of the mud
1222 09-30-2013 04:15 AM
An aux cooler is a great idea for all 07 11s but not sure if it would have made much of a difference in the situation you described above though.
Just a bit of friendly advice, get yourself a good working flashlight (everyone should have one) and carry it in your Jeep at all times. Most likely all of your troubles could have been avoided if you would have just looked under your Jeep when the noise first started.
:cheers2:
jdhaas3 09-30-2013 04:54 AM
So is the noise gone now?
orangera1n 09-30-2013 08:14 AM
Yeah I just hard to put the heat shield back on. Mud caused it to fall off (it's just crimped on)
The time now is 03:01 PM.
