Transfer case shifting issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Transfer case shifting issue
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 12-07-2010, 07:38 AM   #1
51M38
2011 JK Wrangler
I bought a 2011 Jeep® Wrangler Rubicon last week & have one issue on which the dealer is proverbially clueless. The transfer case shifter will not shift from 2H into 4H when the jeep is not moving; it works fine as soon as it’s in gear and rolling. Thre is only 89 miles on it. The owner’s manual clearly states that this shifter should work either when stopped or moving. What could be causing the problem, or is it a problem?
New to this Forum and haven’t had a chance to use the Jeep yet as work has taken over my life for the last ten days. I’ll post more interesting items after I’ve been in the saddle awhile.
51M38 is offline   Reply With Quote
Unread 12-07-2010, 07:46 AM   #2
ronjenx
ronjenx's Avatar
It's possible when stopped the splines are not lining up.
Not an indication of anything wrong.
ronjenx is offline   Reply With Quote
Unread 12-07-2010, 09:29 AM   #3
Prot
Gold Member
Prot's Avatar
I always shift while moving, anyhow it is very slowly.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
Prot is offline   Reply With Quote
Unread 12-07-2010, 09:36 AM   #4
yoda13
Force Wheeler
yoda13's Avatar
I always shift while moving too...it works much easier. Many times mine won't shift either if I am not at least rolling a bit...
yoda13 is offline   Reply With Quote
Unread 12-07-2010, 09:37 AM   #5
fan45acp
2010 JK Wrangler
View your owners dvd,it clearly shows you how to change from 2wh-4wh-4wl..No problem...
fan45acp is offline   Reply With Quote
Unread 12-07-2010, 10:12 AM   #6
paul84043
I didn't get a DVD...
paul84043 is offline   Reply With Quote
Unread 12-07-2010, 10:15 AM   #7
fan45acp
2010 JK Wrangler
Go back to your dealer,they owe you a" owners'manual" and it comes on a dvd.
Unread 12-07-2010, 10:24 AM   #8
tavic
2010 JK Wrangler
Same here on shifting while moving, its all about getting the splines to line up. In fact, 4WD Hi can be shifted on the fly up to 55 mph.
tavic is offline   Reply With Quote
Unread 12-07-2010, 10:31 AM   #9
1222
Make mine a Jeep!
1222's Avatar
Welcome to the forum and congrats on your new Jeep.
Like the others stated, it’s normal, especially since everything is nice and tight. Now go get that owners manual.
1222 is offline   Reply With Quote
Unread 12-07-2010, 10:46 AM   #10
SLIM_SNOOPY
Your transfer case in the JK Wrangler is a non sycronous transfer case. As what other members' mentioned , the splines must line up or the transfer case will not engage, forcing it will leave you with a broken linkage, if it does not want to engage, do not force it, just drive up a little and it should be a smooth transition.
Hope this helps
SLIM_SNOOPY is offline   Reply With Quote
Unread 12-07-2010, 12:24 PM   #11
51M38
2011 JK Wrangler
Thanks for the responses. The dealer did get back to me today with a version of "they all do that". I'm going just drive it and not be concerned.
I do have the manuals and DVD; I copied the DVD onto a flash drive to for easy ready on my laptop in the garage. For those that didn't get a DVD, both manuals (Guide & OM) can be downloaded from the jeep.com site. After reading them completely, I do believe I know more about Wranglers than the salesman.
This is my 3rd jeep and spent late into the morning over last weekend (major blizzard going on outside) in my garage detailing it and learning what I could. As an engineer, of course I started taking it apart. Very interesting.
Already received an order from Quadratech; decided on some MOPAR accessories like front bumper, taillight guards, and front skid plate, Warn 9.5ti winch, etc. I’ll post some photos when I’m done.
Unread 12-07-2010, 12:26 PM   #12
smooth9883
I had and have the same problem. You will also notice that your lockers don't disengage after you try to disengage them. I have found that shifting from 2H to 4H is getting easier. 4Lo is the tough one. Owners manual says to roll at 2-3 mph and shift. You can try that but every time I've done it I get nothing but grinding. I found the best way to do it is try to shift, if it doesn't go do not force it, simply put it back in the last state and drive forward a few inches, then try again.
smooth9883 is offline   Reply With Quote
