Traction Control??? - JeepForum.com
post #1 of 15 Old 09-24-2013, 01:14 PM Thread Starter
JeepMama07
Traction Control???
I bought this 2007 JK Wrangler a week ago and has already been in the shop. Slight curves and turns, the traction control kicks on and it feels like its sliding. The dealership said it was a sensor and replaced it, I finally got it back yesterday and it did it again. It has a 3.5' rough country lift and 35's.
I have read that it could be from the computer.
Anyone else have these issues or advice?
JeepMama07 is offline
post #2 of 15 Old 09-24-2013, 01:19 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I think your answer is the RC lift. Not the best of lifts and probably incomplete
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 15 Old 09-24-2013, 02:10 PM
JIMBOX
Is your steering wheel straight/level, when you're going straight ??
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 15 Old 09-24-2013, 04:15 PM Thread Starter
JeepMama07
Originally Posted by JIMBOX
Is your steering wheel straight/level, when you're going straight ?? JIMBO
It's shaky but doesn't seem off
post #5 of 15 Old 09-24-2013, 04:30 PM
JIMBOX
"Shaky", must be outta round tire/improper toe-in/unbalance/steering wheel off-center and that upsets the ESP/BCA-traction control, which may be a little outta whack, because the jeep is over 6 years old and
Somebody did an incomplete lift and suspension install/adjustment-
Find someone knowledgeable--forget the dealer, finda club/group of jeepers-offer some incentives-ie, pizza/beer/whatever, you're driving a time bomb-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #6 of 15 Old 09-24-2013, 05:22 PM
RockyClymer
RedRock4Wheeler
Yeah. Incomplete lift at 3.5 in is my guess.
NRA Life member
post #7 of 15 Old 09-24-2013, 09:38 PM Thread Starter
JeepMama07
Ok!!!! Sounds good. Thanks a bunch.
post #8 of 15 Old 09-25-2013, 06:16 AM
zjilla
Get an alignment with the correct lift components ie: adj CAs so u can set ur caster and pinion angle correctly and have them make sure ur steering wheel is perfectly straight. Bam! I dont know what components ur RC lift kit has on it but thats the jist of it
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #9 of 15 Old 09-25-2013, 06:45 AM
ronjenx
ronjenx's Avatar
Straightening the steering wheel by eye works sometimes, but only if you are lucky.
What's important is the fact there is a sensor in the steering wheel that tells the computer when it's centered. Straightening the steering wheel while monitoring what the computer sees is the best way to go.
ronjenx is online now
post #10 of 15 Old 09-25-2013, 11:32 AM
Stag
How would you accomplish straightening the steering wheel while monitoring what the computer sees is the best way to go
Stag is offline
post #11 of 15 Old 09-25-2013, 11:58 AM
RockyClymer
RedRock4Wheeler
An AEV Procal works to monitor the output of the steering wheel while centering the steering wheel...probably others do it too.
NRA Life member
post #12 of 15 Old 09-25-2013, 04:29 PM
Vin
Did you adjust your computer for the new tire size? The T/C will kick in if the computer senses one wheel is spinning faster that it should be compared to the other wheels. If it is kicking in on turns, I'm wondering if the computer is seeing this because of the new tire size.
Vin is offline
post #13 of 15 Old 09-25-2013, 07:34 PM
04WJfreedom
04WJfreedom's Avatar
Do you have an AEV Procal? I would get one if you don't, and set the tire size with it. That might help.
When my steering was off center my traction control would kick on also. And after straightening it with the Procal it was fine.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #14 of 15 Old 09-25-2013, 10:52 PM
suicideking
I just fixed this last week -- My steering felt loose like yours and steering wheel was off center. I have a procal, used to straighten the wheel. Also had a loose bolt in the steering (tie rod). The light hasn't comeon since.
suicideking is offline
post #15 of 15 Old 09-26-2013, 02:07 PM Thread Starter
JeepMama07
Thank you all so much!!!!!
