Track lock: do you need it? - JeepForum.com
post #1 of 6 Old 01-13-2007, 05:13 PM Thread Starter
mr.grumpy
You guys are all enthusiasts. Did you get the tracklock? Why or why not? I have to order a Jeep to get one: there are none on lots around here!
mr.grumpy is offline
post #2 of 6 Old 01-13-2007, 05:24 PM
SecondTJ
SecondTJ's Avatar
its worth it.
or you can wait and get a rear locker when it becomes available. (cant have both though)
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 6 Old 01-13-2007, 06:12 PM
jarettms
I got the trac lock
It was a requirement for me...this is my first jeep, but my family has had 4WDs in the past and the ones without a limited slip always struggled when the going got rough. Some may say that the traction control system negates the need for limited slip, but having had my Jeep in the snow today in 2WD, I could feel both rear wheels pushing without the annoying electronic nanny kicking in.
jarettms is offline
post #4 of 6 Old 01-13-2007, 06:44 PM
UTAH
UTAH's Avatar
I'll offer a different view here.
The JK is the first Jeep I've owned that does not have a limited-slip or locker in the rear diff. I thought it would be a problem, and it's not. Seriously, the traction control works VERY well in the JK. Originally, I figured I'd want to put a locker in - but the performance of the JK in slippery situations has changed my mind.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #5 of 6 Old 01-13-2007, 11:27 PM
soldierguy
soldierguy's Avatar
I know I don't own a JK, but I'll chime in here.
Traction control may be great for on pavement...I know the traction/stability control works great on my WK on the road when things get slick. But if you're off road and want to disable the traction/stability control to allow for some wheelspin (in mud for example), then the vehicle will function exactly like one with an open differential...the torque will take the path of least resistance and one wheel per axle will spin like mad while the other just sits there.
So yeah, go for the traction-lok. Traction/stability control will help on the road, but it won't be effective off road if you disable it using the button on the dash.
soldierguy
2012 Wrangler Rubicon 2-door
2009 Aprilia Dorsoduro 750
2008 MV Agusta Brutale 910S
soldierguy is offline
post #6 of 6 Old 01-14-2007, 12:02 AM
JK_Jeep
JK_Jeep's Avatar
NAAAAAAAA You can always use high speed instead
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline
How to identify if I have track lock... snakehunter TJ Wrangler Technical Forum 13 10-30-2006 07:48 AM
aussie, 3.73s and track lock going in, what next? kenn YJ Wrangler Technical Forum 1 03-25-2005 08:37 PM
track lock and cruise control Capone TJ Wrangler Technical Forum 4 06-22-2004 07:22 PM
Re: Track- lock AKA: Trash-lock UPnOVER YJ Wrangler Technical Forum 2 07-25-2003 08:59 AM
rear Track-Lock sulaco TJ Wrangler Technical Forum 7 09-25-2002 09:09 AM
