TPMS after Rotating Tires - JeepForum.com
post #1 of 7 Old 03-16-2017, 03:53 PM Thread Starter
DotNetRob
2015 JK Wrangler
I am used to TPMS lighting up, especially after airing down for offroading, but today I did a 5 tire rotation on my jeep and the tpms has been light up ever since. TPMS is set at 29 psi with my AEV Pro Cal, and all tire pressure are 29/30 psi. Drove for around 10 miles, but the light is still on and blinks for the first few minutes the jeep is on, then turns solid, never says anything about a particular tire. Usually it resets pretty fast after offroading. Not to worried about it but wondering if there is something special I need to reset to get tpms back to normal.
DotNetRob is offline
post #2 of 7 Old 03-16-2017, 10:12 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I would give it a little time to work itself out. It probably is a little confused with the spare being rotated in.
Jim
JLC08JK is offline
post #3 of 7 Old 03-17-2017, 12:03 AM
Kiwi Jeeper
Something is odd. I do 5 tyre rotation and never experienced something like this.
Sent from my Pixel using Tapatalk
'12 JK Rubicon V6 3.6L
'15 KL Trailhawk V6 3.2L
Kiwi Jeeper is offline
post #4 of 7 Old 03-17-2017, 07:36 AM
LMB
2016 JK Wrangler
I just had the same problem after 5 tire rotation. I finally took to the dealer, there was not a sensor in the spare. I had a discussion and they put one in under warranty.
LMB is offline
post #5 of 7 Old 03-18-2017, 02:57 PM
justals
Had a similar issue. Purchased 4 new tires and 3 of the sensors stopped working 15 mikes after install. All of a sudden the 3 tires don't have sensors...
85 CJ - Renegade; 85 CJ - Base; 86 CJ - Laredo
14 JKU - Rubicon; 14 Cherokee - Latitude
justals is offline
post #6 of 7 Old 03-20-2017, 10:35 PM Thread Starter
DotNetRob
2015 JK Wrangler
Apparently I just wasn't patient enough, after about 30+ miles the light finally went off. Have put 100+ miles on it since and light hasn't come back on.
post #7 of 7 Old 03-21-2017, 04:30 AM
Wrigley
That has happened to me a couple of times. Recently I had a flat and put the spare on. It took about 3 days for the light to go off.
Mike
Wrigley is offline
