Tpms - JeepForum.com
post #1 of 4 Old 01-10-2015, 07:45 AM Thread Starter
rider251
2014 JK Wrangler
Tpms
The "Tire Pressure Monitoring System (TPMS)" indicator light has illuminated in my new 2014 Wrangler. More than likely because the temps went into the single digits. Tires don't look low and been to cold to add air until later today. Will this light automatically go off once I add air or does it now need to be reset? And if so how?
I hate technology!!!
rider251 is offline
post #2 of 4 Old 01-10-2015, 08:11 AM
14Sport
Proud Deplorable
14Sport's Avatar
After a little driving around it will clear itself after you properly inflate the tires. You also can use a programmer to lower the threshold or turn it off.
My observations are based on my experiences...YMMV.
14Sport is offline
post #3 of 4 Old 01-10-2015, 09:09 AM
ncb
No reason to hate the technology. It did its job and with out checking the tires it's only a guess if the tires are slightly below the threshold psi or maybe one has a leak.
As stated there's no need to have the system reset after airing them up.
Edit-Do the newer JKs have a page that reports the exact pressure of each tire on the EVIC?
ncb is offline
post #4 of 4 Old 01-10-2015, 10:10 AM
christensent
2014 JK Wrangler
Yes, my 2014 does. I assume that is part of the 2014 EVIC upgrade.
christensent is offline
