TPM error not sure what it means? help - JeepForum.com
post #1 of 10 Old 08-31-2012, 08:54 AM Thread Starter
apentivolpi
I have a 2013 rubicon and I just got the truck yesterday and the tire pressure system came on. one tire says 38psi and the other 3 dont have a number just a dash - net to the 3 other tire. just dont want to have to go to the dealer if its a quick fix.
apentivolpi is offline
post #2 of 10 Old 08-31-2012, 09:32 AM
COLOUXJ
2010 JK Wrangler
Either you have to drive a bit or have them reset. Tire shops can normally do this too. Not sure on the 13's yet though I know they have a new TPMS frequency.
If it does not correct itself in the next couple of days of driving its an easy fix at the dealer, just have to reprogram the sensor. about 5 min.
COLOUXJ is offline
post #3 of 10 Old 08-31-2012, 11:35 AM
tavic
2010 JK Wrangler
It should be corrected within 5 miles of driving. There has been situations in the past where folks have come across bad batches.
tavic is offline
post #4 of 10 Old 08-31-2012, 12:50 PM
paul84043
have you checked them to see what they're actually running at?
Typically they will go off if you go under about 30psi, or I believe if the computer sees a large disparity between one and the others.
Check them yourself, including your spare, just to make sure that everything really is good to go. Give it a day or so of driving, if it hasn't reset, then take it back to the mothership.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #5 of 10 Old 08-31-2012, 02:36 PM
1222
RIP John
1222's Avatar
Donít just assume that they came from the factory with the proper psi. Always check (all 5) the pressure yourself especially if they came from a tire shop.
(2011-2016)
1222 is offline
post #6 of 10 Old 08-31-2012, 07:57 PM
Butterbuddha
2010 JK Wrangler
X2 on that. I got 5 wheels and tires from Discount Tire Direct, they ranged 16 psi across the five!!!!!!!
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #7 of 10 Old 08-31-2012, 08:21 PM
1222
RIP John
1222's Avatar
^^^ Funny you should mention them (discount, a store by me) because thatís the tire shop that I use and it happens more times than not over the years.
(2011-2016)
1222 is offline
post #8 of 10 Old 09-05-2012, 08:29 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
from the service manual:
When diagnosing a tire pressure issue, always check air pressure in the tires first with a known accurate air gauge. Adjust air pressure as necessary to that listed on the Tire Inflation Pressure Label (Placard) provided with the vehicle (usually applied to the driver’s side B-pillar). After adjusting air pressure in a tire on the vehicle, allow approximately two minutes for the message or indicator lamp to go out.
JeepCares is online now
post #9 of 10 Old 09-05-2012, 08:32 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
The 2013 Wrangler uses the 433 MHz TPM sensor. Although 315 MHz and 433 MHz sensors are identical in size and shape, they are not interchangeable.
post #10 of 10 Old 09-05-2012, 08:46 AM Thread Starter
apentivolpi
yep that what was wrong they put in 2012 sensors, I will be getting the jeep back today.... thanks guys for all the help.
stubby bumper means less MPG?! Jodyblip JK Wrangler Technical Forum 22 04-21-2012 11:35 AM
Figured out what JK actually means 91YJcharlie Wrangler General Discussion 47 12-25-2010 09:36 AM
any idea what this stamp means? headstrong50 YJ Wrangler Technical Forum 4 01-25-2010 08:41 PM
Anyone know what a Manufacturer Vehicle means? StealthAWD JK Wrangler Technical Forum 3 05-27-2008 07:39 AM
Anyone know what this means? 08Rubicon JK Wrangler Technical Forum 7 03-19-2008 08:44 PM
