Towing a trailer - JeepForum.com
post #1 of 8 Old 07-30-2010, 08:38 PM Thread Starter
FLHTCUI05
Towing a trailer
New here. Hello to everyone. Hope to learn alot. Sorry if this has been ask before, but does anyone tow an enclosed trailer with a Wrangler? My trailer with my motorcycle loaded probably weights in at 1800 lbs. I know the Wrangler is rated at 2000 lbs towing. Would only be towing about 1000 miles a year when I go on vacation and take the bike. Thanks for your help.
FLHTCUI05 is offline
post #2 of 8 Old 07-30-2010, 08:45 PM
ronjenx
ronjenx's Avatar
Your Wrangler, or Wranglers in general?
3.21 gears = 1,000 lbs., 2dr and 4dr.
3.73 and 4.10 gears = 2,000 lbs. for the 2dr, and 3,500 lbs. for the 4dr.
ronjenx is offline
post #3 of 8 Old 07-30-2010, 08:48 PM Thread Starter
FLHTCUI05
Wranglers in general. 3.73 gears with tow pkg. 2 dr Wrangler. All stock.
post #4 of 8 Old 07-31-2010, 07:51 AM
MarkBevans
It will tow fine, just get ready for a decrease in fuel economy 5 mpg +/-.
And losing about 30 Hamsters that reside in your engine........
I tow all the time with my 6speed Rubicon with 35's. My 5x8 trailer with motorcycles, it works fine, it just loses power and mileage.......
2007 Unlimited Rubicon
1983 CJ5
MarkBevans is offline
post #5 of 8 Old 07-31-2010, 07:58 AM
Coop02x
x 2. Seems to be a pretty good overall analysis of what you can expect. You will be fine towing it though. I wouldn't have any worries at all. Later down the road if you start doing some mods, then you can adjust for some of the power loss when choosing a new gear ratio should you ever do that.
Coop
Coop02x is offline
post #6 of 8 Old 07-31-2010, 08:15 AM
Warlord2
If you have a Automatic its a good idea to invest in a tranny cooler, the stock on is junk.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #7 of 8 Old 07-31-2010, 08:46 AM
Hilldweller
2014 JK Wrangler
X2
I've towed this thing about 11,000 or 12,000 miles; it's a 2,000 pound brick when loaded. I've had the trans overheat 3 times so far and have to wait on the side of the road a while.
I'm still contemplating which trans cooler; I'd rather have the dealer do it under warranty though.
4.56 gears, 33" tires, autotrans:
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #8 of 8 Old 08-01-2010, 06:34 AM
miked2905
2009 JK Wrangler
I have a 2 door X, just flat towed a YJ about two hours. She did fine.
'09 JK- 3.25", 35s, 5.13s, trussed/sleeved d30 ARB
'88 Grand Wagoneer - 6", 33s, 5.3L/4l60e/241C
miked2905 is offline
JK Wrangler , questions , towing , towing capacity , wrangler
Trailer Towing??? LRod TJ Wrangler Technical Forum 16 06-26-2010 11:26 AM
Towing A Trailer profile YJ Wrangler Technical Forum 8 09-19-2009 10:51 AM
Towing a Trailer mhizzle1341 YJ Wrangler Technical Forum 8 08-12-2008 03:36 PM
Towing a 1k lbs trailer 90SaharaJeep TJ Wrangler Technical Forum 6 01-18-2005 05:32 AM
towing a trailer wayward YJ Wrangler Technical Forum 15 04-28-2002 09:48 AM
