Towing a JK from the rear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Towing a JK from the rear
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rock
Unread 03-07-2014, 01:47 PM   #1
jester116th
I want to tow my JK with the rear wheels on a tow dolly and the fronts on the ground. Can I do this without dropping a Driveshaft?
Wheels Up Wheelin'!
jester116th is offline   Reply With Quote
Unread 03-07-2014, 03:03 PM   #2
Ancient Mariner
Rear Towing
I think the Owner's Manual says NO. I am just recalling this from glancing at it while looking at other stuff. If you don't have access to the Manual, I will be glad to take another look and see if I was right and shoot you a copy. I pull my '12 behind my motor home so I have been in the towing section tho I was looking for other info. Lemme know if you want me to root around for you. Glad to do it.
'12 X 2dr 6spd Freedom Top RED
NITTO Trail Grappler 285-70-17R" on Fuel Hostage wheels - 2" BB lift.
IPF 55w Sport Lights on QuadraTech Windshield mounts. IPF out front on light bar.
Ancient Mariner is offline   Reply With Quote
Unread 03-07-2014, 04:19 PM   #3
flsailor
I'm not sure if this would be different for auto vs. manual trans, but I know I can (and have) pulled my manual with all 4 on the ground. Leads me to think there should be no issue drivetrain-wise with towing in that setup. My concern would be with the steering. You would need the steering wheel to be locked perfectly straight, and in my mind that would be putting a lot of undue stress on the locking mechanism, which probably wasn't designed for handling that much force.
Any particular reason you want to pull it that way? Why not put the front wheels on the dolly?
flsailor is offline   Reply With Quote
Unread 03-07-2014, 04:26 PM   #4
ronjenx
ronjenx's Avatar
The owners manual says no towing on a front or rear wheel lift.
"CAUTION!
Front or rear wheel lifts should not be used. Internal
damage to the transmission or transfer case will occur
if a front or rear wheel lift is used when recreational
towing."
ronjenx is online now   Reply With Quote
Unread 03-07-2014, 06:43 PM   #5
JIMBOX
At 5 mph in a parking lot--no trouble-but
If you think you can cruise at 40/50/60 mph towing the JK in REVERSE--"BAM" undue stress not only on the ring/pinion gears (they're not unidirectional ground teeth), but-
The xfer case isn't geared/chained for that reverse wear at rpm, even pulling the Driveshafts would still subject the differential to the wrong wear and-
--BYBY WARRANTY--
Other than that how was your day ?
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
Unread 03-07-2014, 07:00 PM   #6
ronjenx
ronjenx's Avatar
--BYBY WARRANTY--
JIMBO
Regarding the differential turning when being towed backward...
Wouldn't the tooth contact and direction of thrust on the pinion be the same as when the vehicle is being driven forward under its own power?
It's being towed forward when all the forces in the differential are reversed, and that isn't a problem.
Unread 03-07-2014, 07:17 PM   #7
JIMBOX
Well, when towing forward, yes the ring gear is driving the pinion, same way the front diff. operates on the hiwy in 2wd, but
when (if), you tow in reverse, then the ring gear is driving the pinion gear--BACKWARDS--OPPOSITE DIRECTION OF THE GEAR DIRECTIONAL FLOW CUTS !
Like I said for a short/no speed tow, shouldn't be a problem, but at speed the reverse gears wear/thrust and more important--the diff. fluid wouldn't get 100% contact activity--now that might not be that crirical for "X" miles, but remember this is a Chrysler JK !!!
In the final analysis--I wouldn't doit--except in recovery !
Smpkemifyougotem
JIMBO
Yellow Jeep No. 683
Unread 03-08-2014, 04:59 AM   #8
jester116th
I had it repo'd once and they towed it all over gods green earth with the rear in the air no damage. But it's mute anyway as Uhaul informed me that with the 37x12.5's I'm running that I'm to wide to fit on tow dolly or auto transport
Wheels Up Wheelin'!
Unread 03-08-2014, 07:57 AM   #9
rirrgang
Is it a 2WD or 4WD? 2nd question. Why would you want to?
-Rick
07 Sahara Unlimited
rirrgang is offline   Reply With Quote
Unread 03-08-2014, 08:14 AM   #10
jester116th
4 wheel drive of course. And because my wife doesn't have a DL so I wanted to tow it behind the Uhaul truck
Wheels Up Wheelin'!
Unread 03-08-2014, 08:31 AM   #11
rirrgang
Put it on a trailer and do it the right way if that's all you need to do.
-Rick
07 Sahara Unlimited
Unread 03-08-2014, 08:42 AM   #12
JIMBOX
Good grief, guys have been towing these JKs for over 6 years, behind motorhomes/w no problemo-
Do you think that yours is different?
Uhaul can outfit you with the towinglights/wiring for cheap, if you talk to them when you get ready to move !
Good luck
JIMBO
Yellow Jeep No. 683
Unread 03-08-2014, 08:50 AM   #13
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
Buy a set of cheap wheels and tires, load it up and sell them when you get to where you are going. Will still be cheaper than a new txfer case.
Black 2011 JKU Rubicon/ 6spd w/5.13 gears/ 5.5" RK X-Factor Mid Arm (3.5") Springs, RRD Shocks/ Poly Inner/Outter Sleeves and C-Gussets/ Reid HD Knuckes/ 37" Nitto Trail Grapplers on 17" MB72s/ ACE Flat Fenders/ JCR Front Stubby Stinger, Rear Stubby Bumper and JCR Deluxe Sliders/ Warn 9.5 cti w/Syn line/ OR-Fab Swing Away Tire Carrier w/Fuel Can mounts
Oct 2012/Dec 2013 JKOTM
My work in progress:http://www.jeepforum.com/forum/f96/r...dated-2206865/
Couldn't have done it without Jason@KrawlOff-Road.com!!!
HOKIES2010 is offline   Reply With Quote
Unread 03-08-2014, 10:28 AM   #14
Wubicon
2010 JK Wrangler
Get your wife a DL?
+1 on they cheap wheel and trailer idea.
Sent from AutoGuide.com App
Wubicon is offline   Reply With Quote
