Towing front bumper for JK? - JeepForum.com
post #1 of 11 Old 01-18-2011, 07:38 AM Thread Starter
cj7ole
Looking at an '11 JK and would need to tow it behind my RV. I like the setup on my CJ with a Body Armor rock bumper with shackle brackets that work with my A frame. Anyone out there add a front rock bumper to trick up the JK that also negates the need for a towing baseplate? I refuse to pay over $800 for a fancy towarm only to have to also add an ugly baseplate.
'84 CJ7, '07 5.3 LMG Chevy, D300, 4L60e, 33's, 4.10, rear Detroit Locker, FG Tub, HOK Tangelo Pearl
Build: http://www.jeepforum.com/forum/f22/ole-jays-cj7-5-3-chevy-swap-1287392/
cj7ole is offline
post #2 of 11 Old 01-18-2011, 09:53 AM
saceone
maybe it's just me but I'd slap that baby on a trailer!!
saceone is offline
post #3 of 11 Old 01-18-2011, 09:58 AM
tclaremont
2014 JK Wrangler
JKs make for awesome toads. There are a couple of members here who are using the JK as a toad. Do a quick search of the JK forum and I am sure they will come up.
A trailer is a PITA because many campgrounds charge extra for the storage, plus your fuel economy goes down the toilet if the trailer weighs anything at all. An aluminum trailer helps, but the cost is triple that of a steel trailer.
While I cant argue the logic and convenience of owning a trailer, setting up your Jeep to flat tow is worlds easier.
Tim C.
Rochester, NY
tclaremont is offline
post #4 of 11 Old 01-22-2011, 02:11 PM
Tom55
I tow my 08 behind my motor home, I have a blue ox base plate with a stock front bumper. Would like to change to a after market front bumper with a winch and keep the blue ox base plate. Does anyone has any ideas.
Tom55 is offline
post #5 of 11 Old 01-22-2011, 06:09 PM
Crasher
I have the Rock Hard full width bumper. For $65 more, I bought their Blue Ox tow brackets that use 2 of the 4 mounting bolts on each side. My Blue Ox tow bar pins to it. It's simple and looks great. I hook the safety cables to the shackle weldments that are on the bumper. Plug in the wiring and it's ready to go.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #6 of 11 Old 01-22-2011, 09:11 PM
Igiveup
I retained the stock bumper and built my own attachment setup. All you can see with the towbar off is a receiver hitch tube back under the bumper on each side of the frame. It's really not very noticeable. I used 2" tubes because I attach a hitch bar to the front to push my boat and trailers around. If you used the 1 1/4" tubes they would hardly show. I also have a winch mounted on the Rough Country winch mount.
Igiveup is offline
post #7 of 11 Old 01-23-2011, 03:48 PM
KPJ
2010 JK Wrangler
Currie makes a skid plate/air dam replacement bracket with tow attachment points incorporated. They offer a complete JK towing kit as well, which includes the bracket and their tow bar.
I have on in the garage but haven't gotten around to installing it on my wife's JKU.
For my JKU I had AEV weld up a bar with a 2" reciever and Currie style bar attachment points that bolts to AEV's front bumper.
Here is a photo of the AEV bar:
Hope this helps.
JPK
KPJ is offline
post #8 of 11 Old 01-25-2011, 08:00 PM
yoda13
Force Wheeler
yoda13's Avatar
I have the new Body Armor bumper...I am going to buy the Warrior collapsable tow bar and hook it to the d-ring mounts via either the body armor d-ring adaptors or the body armor ones...one uses bolts the other cotter pins...haven't decided which I am going to buy yet...but this is the route I am headed...I used to use a roadmaster system, but it limited uses with aftermarket bumpers...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #9 of 11 Old 05-09-2016, 10:27 AM
NEDJARRETT
I have a SmittyBilt front bumper with d-ring mounts on my 2015 Wrangler JK. Because of the aftermarket bumper, I cannot attach a standard baseplate. Everyone says to just buy the Blue Ox adapters and tow right from the existing d-ring mounts. My question is: won't this wear through the powdercoat on my bumper and cause it to start rusting?
NEDJARRETT is offline
post #10 of 11 Old 05-09-2016, 02:03 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Any bumper that mounts to the frame with side plates can be adapted to tow. If the bumper only mounts with the four bolts per frame rail - I would be very hesitant to use it without fabbing some side plates. That's really all a base plate does - is mount three dimensionally not just bolt up flat (as well as connect low enough to match the receiver height of tow veh).
My Garvin has recovery eyes at the right distance - my roadmaster sterling all terrain bar could be attached (we use on the stock 12 sport - so cool even my 75yo mother can hitch and unhitch it) but I haven't wanted to tow my 11 with it because of height (3" lift and 35s), so haven't addressed sideplates. To have a level bar I would need my RV receiver 2' higher.
But with ANY bumper - using the recovery eyes ONLY if the eye is a through weld - that is the eye has a plate and comes through the bumper, welded behind - not just welded TO IT.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 11 Old 05-10-2016, 10:16 AM
HemiJK37s
2011 JK Wrangler
try this as a solution, I have been running it for years with no problem. Should not come in to contact with most bumpers, if any.
http://www.ebay.com/itm/Tow-Bar-Adap...tR7vzw&vxp=mtr
HemiJK37s is offline
Bumper for towing evergin TJ Wrangler Technical Forum 3 10-25-2010 12:30 PM
Towing with non tow-rated bumper? sstaurus Wrangler General Discussion 3 12-31-2009 02:37 AM
New Front Bumper Suggestions- Towing luk4mud TJ Wrangler Technical Forum 3 08-31-2008 08:25 AM
Bumper suitable for towing black92renegade YJ Wrangler Technical Forum 7 07-11-2008 02:41 PM
best bumper for towing? ltdanyj TJ Wrangler Technical Forum 8 09-28-2007 09:50 AM
