Towing capacity? - JeepForum.com
post #1 of 15 Old 06-23-2006, 08:00 AM Thread Starter
wgwgoldwing
wgwgoldwing's Avatar
Towing capacity?
With the larger motor and 4 wheel disc brakes, has the towing capacity been increased in the new wrangler? Couldn't find it on Jeep's page.
Thanks,
WGW
wgwgoldwing is offline
post #2 of 15 Old 06-23-2006, 09:48 AM
ISurvivedNMU
I doubt it would increase. Its still a very short wheel base vehicle, even the 4 door, for towing anything.
2006 Jeep TJ Rubicon... Currie 4" Lift, ect...
2011 Grand Cherokee Overland
2015 JKU Hard Rock
ISurvivedNMU is offline
post #3 of 15 Old 06-23-2006, 12:21 PM
scottyc
I think I read 3500 somewhere...?
scottyc is offline
post #4 of 15 Old 06-23-2006, 03:03 PM
xfactor
Yes, it is 3500. I am still at a loss for how it can have a longer wheelbase than a LIberty, a 3.8 versus a 3.7....and still have 1500 less towing capacity.
xfactor is offline
post #5 of 15 Old 06-23-2006, 03:55 PM
ISurvivedNMU
What wieghs more, a wrangler or a liberty?
2015 JKU Hard Rock
post #6 of 15 Old 06-23-2006, 04:34 PM Thread Starter
wgwgoldwing
That's awesome. Thanks for the info, guess I'll wait for the 07...
WGW
post #7 of 15 Old 06-23-2006, 05:15 PM Thread Starter
wgwgoldwing
Just found this:
http://www.rockcrawler.com/reviews/j...2006/specs.asp
Looks like 3.21 ratio axles will tow 1000 lbs and 4.10 ratio axles will tow 2000 lbs, if I'm reading the chart correctly.
Bummer....I guess it's better than the existing 1500 lbs limit.
post #8 of 15 Old 06-23-2006, 05:17 PM
AOPAPilot
why is it I see Jeeps pulling people out of the mud all the time with such a sh!tty tow limit? How do they not break stuff?
AOPAPilot is offline
post #9 of 15 Old 06-23-2006, 05:56 PM
ISurvivedNMU
Guys, its about safety when towing. Short wheel bases are not safe to tow with. Longer trailers will push these vehicles all over the road, and jeeps do not weigh enough to stop heavy loads. Even if the tailer has brakes, it would be dangerous to pull anything at high speeds with such a light and small vehicle.
2015 JKU Hard Rock
post #10 of 15 Old 06-24-2006, 12:05 AM
ieatchickens
Thanks,
WGW
Since when is a 3.8 liter bigger than a 4.0 liter?
98' SE, Chili Pepper Red, grizzly wheels, 126AA/103AA to 129AA/105AA coil swap, 3/4" spacer, 31 Yoko Geolander AT, soft top, rear view mirror turned upside down, door straps twisted, rubicon wipers, optional factory rear sway bar, doors & top on.
Low Output 4 Cylinder Jeep Club Member #1
06' Grand Cherokee Limited, 4.7 liter V8
99' Grand Cherokee Limited, 4.7 liter V8
ieatchickens is offline
post #11 of 15 Old 06-24-2006, 01:16 AM
toplessjeep
Speaking of towing capacity. If the Gladiator(assuming its a JK platform) does eventually come with the diesel, will it have a towing capacity that will allow it to be a tow rig for a trail only Jeep? It is longer, and will be a bit heaviier I supposed but not much. I would really love to haul my trail only YJ with a Jeep Gladiator.
toplessjeep is offline
post #12 of 15 Old 06-24-2006, 12:04 PM
TurtleMacLeod
Releases say that the Unlimited will be capable of towing 3500 lbs, and the two package will include a Dana 44 rear.
My girlfriend might not splurge for the Rubi with the 44, but the tow package is a given!
TurtleMacLeod is offline
post #13 of 15 Old 06-24-2006, 01:52 PM Thread Starter
wgwgoldwing
Whoops! My bad. Good catch. Just assumed it was bigger since the V6 lists 205 hp versus the I6 at 190 hp. I guess the correct wording should have been "more power" versus "larger motor".
I stand corrected.
Thanks,
WGW
post #14 of 15 Old 07-02-2006, 07:48 PM
west_dt
Why is the towing capacity only 3500 still when the wheelbase is longer than the current LJ. The liberty and the Cherokee are both rated to tow 5000 lbs. Do you think that it is rated this low due to the current engine and transmission and when they offer different engine options the tow rating will be larger then? I am really concerned with this because the boat I am purchasing will weigh around 4000 lbs with trailer and I would like to get a jk to tow it when my current xj needs to be upgraded. Do you think it will be a bad idea to tow 4000 lbs with the new jk unlimited, as long as I have trailer brakes?
west_dt is offline
post #15 of 15 Old 07-02-2006, 08:15 PM
pbrutsch
When they rate a vehicle's towing capacity they take into account:
* wheelbase
* weight
* transmission (ie auto vs stick)
* transmission cooling
* brakes (there are reasons why 3/4 or 1-ton trucks are rated for more than an otherwise-identical 1/2 ton truck)
* suspension (yet another reason for the above)
* chassis (why a 3.8L V6 in a minivan is rated to tow less, but makes more power than, the 3.7L in a KJ)
The towing capacity is a recommended maximum: a CRD Liberty is rated for 5000 lb, but can quite easily tow 6500 lb. Ultimately it's a safety issue - stopping and maintaining vehicle control.
A JK Unlimited will weigh more than a TJ (short or long wheelbase). Heck, they're probably applying the same max recommended towing weight to all JKs, regardless of wheelbase If it has the towing package (for the transmission cooler and what not) I think it'll safely tow more than the recommended, and I don't think a 4000 lb load will pose a problem.
Just don't tell the dealer, and make sure you have trailer brakes - for an extra margin of safety
Real Jeeps don't need no stinkin' spark plugs!
pbrutsch is offline
TJ Towing Capacity firemedicjeeper TJ Wrangler Technical Forum 68 07-29-2016 01:53 PM
towing capacity 08saharajk JK Wrangler Technical Forum 16 11-07-2008 01:29 PM
towing capacity 2442george JK Wrangler Technical Forum 3 01-19-2008 10:09 AM
Max Towing capacity??? GoGo YJ Wrangler Technical Forum 7 10-28-2003 01:25 PM
Towing Capacity redrubi04 TJ Wrangler Technical Forum 4 09-04-2003 11:07 AM
