Towing Capacity - Page 2 - JeepForum.com
post #16 of 34 Old 07-10-2013, 09:10 AM
jchappy
2011 JK Wrangler
It's not what you can tow safely
It’s what you can STOP safely
Anyone can over tow but when SHTF are you going to be able to handle your load and stop in a safe manner.
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #17 of 34 Old 07-10-2013, 10:00 AM
ronjenx
ronjenx's Avatar
Itís what you can STOP safely
Starting...towing...stopping... It's all part of the picture.
ronjenx is online now
post #18 of 34 Old 07-10-2013, 10:20 AM
mello
Probably 90% of the public just worries about if vehicle can move load not if it can stop it. People assume if it can tow it then it can stop and that is far from the truth.
mello is offline
post #19 of 34 Old 07-10-2013, 04:39 PM Thread Starter
Cmp8254
Thanks for all of the replies! So is it safe to say we are al in agreement that my rig is rated at 2,000, but with higher gear ratio, it could be increased to 3,5000?
Cmp8254 is offline
post #20 of 34 Old 07-10-2013, 05:01 PM
deerassassin22
2011 JK Wrangler
IMO yes it can be as long as the gears are correct. I just purchased a cargo trailer for my 2011 JKU (Rubicon) and my 2 Harleys . I installed a 7-pin connector with Brakes and when I purchased my trailer I order it with the Electric Brake upgrades as well, granted I have a 7x12 Single Axle Dry is 1,300lbs 2x HD's and I'm at 2,500lbs so no issues. I also took the time and installed a bigger transmission cooler as well and soon probably an oil cooler as well as added perks to ensure safety and such. And if you lift your vehicle the center of gravity shifts so a drop hitch would be needed along with more concern about load/weight placement and such. thats .02
Cobra 29 CB, 4ft Firestick Antenna, Skid Row Evap Skid, Rockhard Engine Skid, Rockhard Tranny Skid, Mesh Grill Mod, Mastercraft Grab Handles, Front and Rear ARB Diff Covers, Smittybilt Rock Rails, KC 130Watt Long Range Lights, Delta Light Mounts, TorqFlo tranny cooler, Hood Louvers, Drake Hood Pins, AEV Snorkel, Smittybilt 10,000 Winch, Rockhard Shorty Bumper with KC 100watt Slim Light Driving Lights, JKS ACOS Front System, Breather Extensions.
deerassassin22 is offline
post #21 of 34 Old 07-10-2013, 05:04 PM
Alaska-HWY JK
Check your zeros.
Alaska-HWY JK is offline
post #22 of 34 Old 07-11-2013, 10:59 PM
herculz
2010 JK Wrangler
Town 5800 in my jku from backyard to front yard moving our travel trailer of 33' tandem axle
herculz is offline
post #23 of 34 Old 07-12-2013, 11:00 PM
Downwindtracker
After towing many thousands of miles with a XJ Cherokee, I've learned a few things, mostly the hard way. Any trailer more than 25% of the tow Jeep weight should have brakes, more than 33% must have brakes. Trailer sway can be a problem and lift with it's higher CG will NOT help, but heavier rear springs and shocks will. And it's not just the trailer weight, but the frontal area that limits.
Downwindtracker is offline
post #24 of 34 Old 07-13-2013, 06:09 AM
KurtieR
I have towed a 20 foot Seadoo Boat with my 13 JKU all summer long. It does not have the max tow and is rated at 2000lbs max capacity due to the 3.21 gears. I installed some 33s and a 3" BDS lift and it tows the boat nicer than my buddy's avalanche! The BDS springs are much stiffer than stock and when the boat sits on it they level right out. Boat/trailer/gear is well over 3000lbs and I have had zero issues when starting/stopping! The tow numbers are very conservative, and in the end the lift is going to help!
KurtieR is offline
post #25 of 34 Old 07-13-2013, 07:34 AM
xSoFx
1987 XJ Cherokee
xSoFx is offline
post #26 of 34 Old 07-13-2013, 10:36 AM
panthermark
I don't even want to get started on why the +2012 auto JKU's with 3.21's can't tow 3500 pounds. I think it is a rip-off....but whatever. The tow rating was the main reason why I opted for 3.73's.
Jeep - It's a Jeep thing...you wouldn't understand.
Triumph - Go your own way.
I see why I'm a loner....and I love it!
panthermark is offline
post #27 of 34 Old 07-13-2013, 10:45 AM
Wavedatya
2010 JK Wrangler
I'm guessing vehicle tow capacity is based on wheel base, gears, horsepower, torque and what the trans will allow.
A lift kit doesn't affect any of those. Breaking is another consideration
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #28 of 34 Old 07-13-2013, 03:30 PM
ronjenx
ronjenx's Avatar
You are correct. A lift kit doesn't affect any of the items you listed.
I'm sure there are a few more items. too.
You don't think a higher center of gravity from being lifted will affect the rated tow capacity?
post #29 of 34 Old 07-13-2013, 04:14 PM
SubAtomicGenius
2011 JK Wrangler
The lift doesn't change your rating. There are several factors that can effect a towing rating, including: brakes/brake system, tire load rating, differential, transmission, chassis, drivetrain, etc. In this case, none of these have changed.
SubAtomicGenius is offline
post #30 of 34 Old 07-13-2013, 04:20 PM
ronjenx
ronjenx's Avatar
Oh well. Not much else can be said about it, then.
