Towing a boat - JeepForum.com
post #1 of 12 Old 01-21-2012, 09:07 PM Thread Starter
jkrgv
Towing a boat
I have 08 unlimited, auto, 4x4, k&n cold air intake, superchip programmer, modified exhaust. Looking to tow a 18' pontoon boat with a weight of 2000lb. So I'm looking for anyone who has towed something of similar weight and shape. And if it's going to be a problem? Thanks in advance!
jkrgv is offline
post #2 of 12 Old 01-21-2012, 09:16 PM
Twocylinder
Thats only 1/2 what its rated, less trailer and gear in the boat.....
Your good to go
Long hauls Trans cooler...
___________________________
2008 Wrangler
Red Rock Crystal Pearl
SWEEEET!
Twocylinder is offline
post #3 of 12 Old 01-21-2012, 09:23 PM Thread Starter
jkrgv
I'm going to definitely put a cooler, had an issue once on my ford ranger with a 3.0 pulling a boat. Got hot and blew fluid out of front pump seal.
jkrgv is offline
post #4 of 12 Old 01-21-2012, 09:59 PM
theredmonster
should be fine. pulled our 25ft long and 5500 pound camper on a 2 1/2 hour trip one way with no problem. thats with the old 08 jku not our 11s we have
12 half door wallet killer in the making
theredmonster is offline
post #5 of 12 Old 01-22-2012, 12:17 AM
JK4Three
2009 JK Wrangler
I recently bought a highwall Chalet A-Frame pop-up, a little over 2000# loaded. I don't even know it's back there (just kidding, but it seems everyone says that). I definately know it's back there, but it has been a surprisingly easy tow and I don't have the electric brakes connected yet. Haven't been up the local mountains yet, but through the hills it holds 65 mph fine downshifting in the 3-4k rpm range (auto) on the steeper ones. With a single axle and standard hitch I thought it would bounce the back end some, but it doesn't.
JK4Three is offline
post #6 of 12 Old 01-22-2012, 09:06 AM Thread Starter
jkrgv
In south Texas we have constant wind, going toward the coast and wind pushing on the way back. Maybe if a put a cover over it when towing will lessen the drag. Maybe a wind deflector on the hardtop may help. Removable of course!
jkrgv is offline
post #7 of 12 Old 01-22-2012, 09:09 AM
Prot
Prot's Avatar
2014 JK Wrangler
What gears do you have?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #8 of 12 Old 01-22-2012, 09:14 AM Thread Starter
jkrgv
Stock gears, it's auto and 4x4. I've modified with a superchip programmer at 93 octane setting(makes a big difference). K&n cold air and modified exhaust. I'm assuming 3.73
jkrgv is offline
post #9 of 12 Old 01-22-2012, 10:16 AM
Prot
Prot's Avatar
2014 JK Wrangler
It will be fine, but if you want easier towing, figure out what tire size you plan on staying with and then regear accordingly. JK's are notoriously under geared, especially 2007-2011 automatics.
Generally accepted recommendations for different tire sizes for automatic 2007-2011's are as follows:
32"..........4.10 or 4.56
33"..........4.56
35"..........5.13
37"..........5.38
Not only will it have more get up and go and tow better, the transmission will not work as hard. It will also alleviate gear hunting, over revving, and other common annoyances.
Prot is offline
post #10 of 12 Old 01-22-2012, 03:05 PM
jrmandryck
You should be fine, but I think the trans cooler is a great idea. i put one in mine and I don't even tow just a piece of mind thing
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #11 of 12 Old 01-22-2012, 03:47 PM Thread Starter
jkrgv
Will the superchip "towing" program help. I have 285/65/18 tires
jkrgv is offline
post #12 of 12 Old 01-23-2012, 04:43 AM
mrsig
My boat with stock 4.10
Now my 18' camper: I do have E brakes, a tow sway bar and a Trans cooler.
07 JKU To see mods & my Jeep in Action @
CEO of Black Sheep 4x4s
Member of CCJ, White Jeep Club Member #137.
mrsig is offline
