Tow weight rating - how important? - JeepForum.com
post #1 of 17 Old 02-27-2007, 03:34 PM Thread Starter
jeepers3
0123456789
jeepers3 is offline
post #2 of 17 Old 02-27-2007, 03:54 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
Do either of them have their own brakes?
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #3 of 17 Old 02-27-2007, 04:17 PM
luckyjeeper
luckyjeeper's Avatar
I personally believe that with a lot of care and experience driving, a jeep will pull 5000lbs. Stopping and controlling it is another matter all together. The longer wheel base of the unlimiteds will greatly help that, but that's why the rating is 3500 on unlimiteds and only 2000 on SWB. Personally, I'd not pull more than 2500 on my SWB, so that would put you at about 4000.
how much is that thing going to weight when you have it fully loaded btw?
electric brakes on the trailer would help. A weight dist. hitch would greatly improve sway and control. That tongue weight may be the clincher tho!
Anyone else with experience with this on a JK 4dr?
patrick
2007 JK X 2dr. 6spd.
Steel Blue Hardtop
Virescit Vulnere Virtus
luckyjeeper is offline
post #4 of 17 Old 02-27-2007, 06:01 PM
TexasChopper
If you are planning on a lift in the future.....I pulled my 6X10 enclosed trailer with 2 dirt bikes and gear over the weekend, and let say me it was a handfull. Both hands on the wheel. I would say total weight of the trailer loaded is 2000lbs. I do not have brakes on it, but just going down the road and through the backroads it was tough. I should add I don't have the Unlimited as you do... 2DR 6spd, 4.10's..and 35's
TexasChopper is offline
post #5 of 17 Old 02-27-2007, 11:28 PM Thread Starter
jeepers3
0123456789
jeepers3 is offline
post #6 of 17 Old 02-28-2007, 06:33 AM
PeteC
Originally Posted by jeepers3
No interest at all in ever putting on a lift or bigger tires. I figure well-paid, highly-educated engineers know more than I do about suspension and gears and handling and such and would prefer to leave my vehicle's basic design to those who know a lot more than I do (:
You should take your own advice when it comes to the towing capacity of your vehicle then. The same group of engineers came up with these limits and, I am sure, for good reason.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #7 of 17 Old 02-28-2007, 07:54 AM
daveshan
Feeding the money pits
daveshan's Avatar
Towing capacity vs factory limits is also a common topic over on the Super Duty forums.
The general consensus is just because it will tow the load doesn't mean it's safe or legal. Main concern is in case of accident if it's found you're over the rated capacity of the vehicle you open yourself up to the potential of expensive legal liability issues.
It probably will move/stop it OK, heck I used to tow a 21' commercial lobster boat with my stock '61 Willys wagon, not the smartest thing I ever did but I got there and back. Today I'm older and wiser and wouldn't take the chance, probably better to downgrade a bit and stay legal.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #8 of 17 Old 02-28-2007, 08:35 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Originally Posted by Government of Alberta DOT webiste
Is there a limit to what I can tow behind my car? Can I tow more if I have a bigger vehicle?
Whenever your vehicle is being operated on a highway in Alberta, you, as its owner and/or operator, are responsible to ensure that it is in safe operating condition, including being safely loaded. Your vehicle manufacturer assigned it three ratings: a Gross Vehicle Weight Rating (GVWR), a Gross Axle Weight Rating (GAWR) for each axle, and a Gross Combination Weight Rating (GCWR), which is sometimes expressed as a maximum trailer towing capacity. The GVWR is the maximum weight that your vehicle may weigh on its own wheels, the GAWR is the maximum weight that an individual axle may carry, the GCWR is the maximum combined weight of both your vehicle and any trailer it may tow, and the maximum trailer towing capacity is the maximum trailer weight that your unloaded vehicle may tow. Both the GVWR and the GAWR appear on the manufacturer's final compliance label found on the inside area of the driver's door. The GCWR or maximum trailer towing capacity may be found in the owner's manual. Note that the GCWR, or the maximum trailer towing capacity, may change with different drive train combinations, specifically different engines, transmissions and differential ratios. If the GCWR or maximum trailer towing capacity is not in your owner's manual, you will have to contact your vehicle's manufacturer. Do not exceed your vehicle's manufacturer assigned ratings; exceeding your vehicle's assigned weight rating is an unsafe practice.
According to this, it would be a better choice to purchase the lighter trailer and err on the safe side than to get the heavier one which could put you over-limit and into dangerous situations.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #9 of 17 Old 02-28-2007, 08:46 AM
nierace
nierace's Avatar
2003 WJ
It definately would not be a fun ride for a long trip. Doing local things you could get away with it...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #10 of 17 Old 02-28-2007, 09:33 AM
SecondTJ
SecondTJ's Avatar
i think going almost a 1,000 lbs over the max capacity is pushing it too much
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #11 of 17 Old 02-28-2007, 10:49 AM Thread Starter
jeepers3
Evolution E2 weight limits: loaded vs unloaded
0123456789
jeepers3 is offline
post #12 of 17 Old 02-28-2007, 10:54 AM
luckyjeeper
I just noticed that it says in the hitch reciever information:
3,500-lb tow rating, 350-lb tongue weight rating with weight distributing equipment; otherwise 2000-lb tow rating, 200-lb tongue weight rating, 2" opening, Same as Production, Hitch Ball and ball mount sold separately.
Does your trailer come with the weight distributing tongue? I remember we used to haul horses with a ford explorer that used this and it helped with the sway, control and tongue weight.
Those numbers (weights) you quoted above sound much more doable. I would suspect you won't have any troubles. Just take care, be safe, right?
good thread!!
patrick
Steel Blue Hardtop
post #13 of 17 Old 02-28-2007, 11:11 AM Thread Starter
jeepers3
0123456789
jeepers3 is offline
post #14 of 17 Old 02-28-2007, 11:29 AM
NaeKid
NaeKid's Avatar
In other news - this trailer has electric brakes, so I have been reading up on that too. It seems you need some kind of electric brake controller installed in the Jeep. Does anyone know anything about this with respect to the 2007 Wrangler? Anyone done it? Recommendations?
The electronic brake controller would be something that the trailer-dealership would be able to provide and install correctly for towing that trailer. Most hitch-shops will be able to do the same thing.
You can ask at your dealership where you bought the Jeep if they have some kind of deal for hitch and wiring to be installed for a standard 7-pole system (like they put onto Grand Cherokees).
Hope this guides you in the right direction for safe towing!
You might also want to check out our Tow-Rigs / trailering section here at JeepForum for more general answers too your questions as well.
Silver
NaeKid is offline
post #15 of 17 Old 02-28-2007, 07:34 PM
jeffmarion
Here is what I do not understand. How does a Jeep liberty have a higher towing capacity than the new Wrangler, 5000lbs to 3500 lbs.? They have a similar engines with similar outputs in HP and torque, the Wrangler has a longer wheelbase by 12. The Wrangler has a 112 wheelbase vs. 104 for the Liberty. The Wrangler has a wider track width by 2, and is a body on frame design while the Liberty has a uni-body construction. The Wrangler also has a stronger rear axle.
jeffmarion is offline
towing weight and tongue weight jeepy01 TJ Wrangler Technical Forum 1 07-04-2009 06:15 PM
Smittybilt SRC Tow Rating JohnA56 TJ Wrangler Technical Forum 5 04-05-2007 09:50 AM
Tow Rating Bult4mud JK Wrangler Technical Forum 3 12-12-2006 09:54 PM
What class and weight rating for a trailer hitch? mjkolb02tj TJ Wrangler Technical Forum 20 09-09-2005 03:47 PM
swr rating robhmaurer TJ Wrangler Technical Forum 2 08-30-2002 04:31 PM
