Quantcast tow package? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > tow package?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 07-10-2008, 11:15 PM   #1
jeff408
tow package?
What is the difference between the jeep with the tow package does it have a bigger radiator or is it just the tow hitch and wiring on a six speed? Any help would be appreciated.
jeff408 is offline   Reply With Quote
Old 07-11-2008, 12:41 AM   #2
waterboarder
waterboarder's Avatar
Tow package gives you the hitch, wiring, different gears, and no rear tow hook.
Has no effect on radiator or transmission.
Unfortunately, they give you the cheesy flat four connector instead of the nice 7 pin connector that they sell as an add-on for $110 or whatever.
waterboarder is offline   Reply With Quote
Old 07-11-2008, 05:02 AM   #3
jeff408
thanks for the help
Old 07-14-2008, 03:50 PM   #4
Canyonero
the 4 to 7 connector was $15
Canyonero is offline   Reply With Quote
Old 07-14-2008, 05:03 PM   #5
Prot
Gold Member
Prot's Avatar
Mine came with the towing package and it had the 7 pin round type connector. I wish the towing package included a larger transmission cooler for the automatic for added peace of mind.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/
http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html
Prot is offline   Reply With Quote
Old 07-14-2008, 05:04 PM   #6
waterboarder
And does it magically extend wires into the tow vehicle as necessary for trailer reverse lights, electric brake controller, and an auxiliary hot wire for accessories?
Glock Forum
